#141 | |
![]() Drives: 2020 ss Join Date: Nov 2019
2020 Camaro SS
Heads,cam,hi-ram,hhp tcm |
#142 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
You did a great job on that. Certainly a lot more work!
#143 |
![]() Drives: Chevrolet Camaro Join Date: Nov 2019
does anyone know if you can fit a 103mm tb to a ported lt2 manifold?
#144 |
![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
OP, did you shorten the pipe coming into the opening?
#145 | |
![]() Drives: Chevrolet Camaro SS 1LE Join Date: Sep 2020
#146 |
#147 |
I used epoxy then body filler. . I'm working on another gloss black lt2 over the weekend
2020 Camaro SS
#148 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
So you are probably pulling about 500hp at the crank instead of 455 now if you gained 30 RWHP.
#149 |
![]() Drives: 2018 Camaro SS/1LE Join Date: Jan 2018
I hit up emblempros and they said there already working on a direct fit overlay sticker/emblem that will make it say Camaro instead of corvette.. not sure when it will b out but might b worth the wait
2018 SS/1LE... summit white.. E85 ,Ported LT2 IM, Roto Fab, soler performance ported throttle body, secondary delete, mbrp axle back, tuned by CCNC
#150 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Thanks for the info much appreciated.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
#151 |
![]() Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
Nice
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake |
#152 |
![]() Drives: Camaro 2SS AT NPP F51 EU 2018 Join Date: Aug 2018
I've installed the lt2 intake now, too. With the Lt1 intake was on full load lambda 0.82-0.83. Now 0.78 ! Does the tune have to be changed or why is that?
#153 |
Likely because the throttle body placement changed relative to the air box, the intake hose is clocked on a different angle and is drawing air differently across the MAF. Also, you could be pulling deeper into the MAF curve and it needs to get rescaled to stay in that window.
Should be easy enough to trim that back in line
#154 |
I just peeled off the Corvette lettering with a heat gun and replaced it with some wrap for now. I will add their sticker emblem depending on their design.
