Old 06-22-2019, 02:04 PM   #141
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
Originally Posted by vtirocz View Post
Thanks for providing all this detail. I have a few comments and questions:
  • I'm surprised the air flow at the closed position (5%) is not impacted compared to stock. From the pictures, it looks like there's a higher effective flow area with the throttle blade closed. Can you comment on this?
  • Is idle stability / speed impacted at all?
  • The extent of the modification doesn't reach the hot (closed loop) idle region. It starts blending tangentially from cold idle (open loop) and out. You'll be able to idle at a target +/-30 rpm at any temperature and altitude, which is typical of the stock TB performance.
  • Is the control module targeting a MAF command and adjusting accordingly? Over time, will it "learn" back to similar response levels to stock in order to hit the same air flow commands?
  • No, long term performance shows no changes in this regard. Seems like fuel follows airflow, and spark timing is the limiting tool the ECM uses to reduce torque. If torque limits for any given set of conditions are not exceeded, then, timing won't get on the way.
    It only takes installing the stock TB back, to remind us.
  • I'd like to see a Torx style screw used vs. Phillips. In the first close-up, it looks like the Phillips head is buggered up a little bit from being tightened down. The stock throttle body uses the Torx style with higher torque capacity before deforming the head.
  • Mee too. But we would not be able to countersink them. The head deformation comes from peening the screws at the other end. We locked them with high temp thread locking compound and then peened them. They are more like a riveted screw, not going anywhere.
  • If this impacts air flow and thus power levels, I'd argue that it could be considered something that could void the powertrain warranty if GM / dealer techs wanted to. It might have a relatively small impact on power levels and mechanical limits, but it would be hard to prove that it has no impact.
Correct, but I'd think the burden of proof is on them. But I would not give them the chance to start that argument. I have never heard of anyone having problems b/c of one these, or the likes.
In summary, think of it as an OEM TB that came out of the line flowing near the maximum it was allowed in the design.
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 06-22-2019, 02:26 PM   #142
Originally Posted by DougCBJ View Post
How do i ship the core back, i'm not seeing anything in the package with instructions on this.
Nothing special, just ship to our address on label (also on our website). As long as we can see your name on label or any other entry that we can trace back to your order, you should be fine.
Old 06-22-2019, 05:26 PM   #143
DorkMissile
DorkMissile's Avatar
Drives: DZ
I received my SolerPerf TB in the mail yesterday morning - once I had the battery connected for a couple of hours I dug into putting the TB on and it took about 5 minutes (my car no longer has an airbag since I have a S/C on it).
I had tried a ported TB from my tuner earlier in the year and it improved on the part idle driving some, but nothing like the Soler. It works 100% as advertised - throttle is crisp like a well tuned carburetor (I have a bone stock 1988 Monte Carlo SS that has a electronic controlled QuadraJet on it, and though the car isn't fast, the throttle response is excellent - the Solar TB is probably 98% as good as it).
My car is a manual and with the factory dual mass flywheel the clutch can feel really "dead" when it starts engaging. Couple that with the factory TB setup (which feels like you are pushing a rope), it can be challenging to get consistent movement from a dead stop. I found myself using the RevMatch quite a bit so it was a little easier to live with when doing city driving (like rolling corners at stop signs, lights, etc....) because the throttle was so dead feeling at low throttle positions.
The Soler works so well for me that I don't need the RevMatch anymore and I am able to "blurp" the throttle during shifts with no issues at all. Its fun to drive a stock again
DorkMissile is offline   Reply With Quote
Old 06-22-2019, 06:06 PM   #144
yankee
yankee's Avatar
Drives: 2018 Camaro LT RS, 2015 Mazda 3
Hi! Will this work on 2.0 Turbo? Sorry if it’s a lame question but I am not technical. Thanks!
yankee is offline   Reply With Quote
Old 06-22-2019, 06:57 PM   #145
Sorry, this P/N only fits the 6.2 V8's of the 6th generation. We are planning to expand through the GM lineup, slower than we wish, but we'll get there eventually.
Thanks for asking,
Old 06-22-2019, 07:26 PM   #146
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
Do you take PayPal for payment?
ssmike is offline   Reply With Quote
Old 06-22-2019, 07:27 PM   #147
guapo
Emerald Coast Camaros
guapo's Avatar
Drives: 2017 50th Camaro LT2/RS
Looking for one for the 6th gen V6. Just looking for a little better throttle response. My 2013 V6 is much better with the VMAX ported TB..
2017 LT2/RS, 50th addition. Airaid CAI, Solo Performance Axle back, sunroof, Smoked Led Markers
guapo is offline   Reply With Quote
Old 06-22-2019, 07:44 PM   #148
guapo
guapo's Avatar
Originally Posted by Mike@SolerPerformanceLLC View Post
We are in Daphne, by the Mobile Bay. You are welcome to stop by when you are around.
Thanks,
I like that Im in Crestview and would love to come get one and install it when you make the V6 option...
Old 06-22-2019, 09:42 PM   #149
Alain
Alain's Avatar
Originally Posted by angryBits View Post
Thanks Alain, it's "out for delivery" !
You know... if this does fix it... I'm going to want my M6 back
Haha
2018 ZL1 1LE/Red hot
Old 06-23-2019, 08:32 AM   #150
Yes, we do. Thanks!
Old 06-23-2019, 08:34 AM   #151
Absolutely, you are very welcome to stop by. Stay tuned, as we plan to develop these for other engines. Thanks!
Old 06-23-2019, 09:21 AM   #152
Spedee
Spedee's Avatar
Drives: SS
Order placed. Sending my OEM throttle body in. Still had my OEM after purchasing the Tony Mamo unit. This will be another great comparison.
I was impressed with the TM. From what I have read and conversations with Mike this is the next level of improvement.
Anyone want to buy my Tony Mamo unit???
Spedee is offline   Reply With Quote
Old 06-23-2019, 09:26 AM   #153
guapo
guapo's Avatar
Keep me posted, If you want a test mule I might be down for that. It is my daily driver. My Current mods are airrade in intake with KN filter and a solo performance cat back with x pipe and J pipes.
Old 06-23-2019, 09:32 AM   #154
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
Oh. I completely didn't realize you guys were that close to me. Maybe when I get back from this deployment I'll swing on by and check out your guys' place and pick up a throttle body.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
