#141 |
![]() Drives: 2021 Camaro LT1 6MT Join Date: Jan 2021
Chevy definitely needs better marketing for the LT1, I didn't know it even existed until mid December, and I signed my lease on Dec 31.
The lease deals were so insane it was hard to say no. My LT1 msrp was $39,470 and I got it for under $270/mo sign and drive. I priced out a low optioned 1SS with lower msrp and the payment was in the $475/mo range. Now if I was purchasing, then yes I'd take the 1SS over the LT1 in a heartbeat. |
#142 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
#143 |
![]() Drives: 2016 2SS Convertible Join Date: Dec 2019
Check your RPO codes on the build sheet (I don’t think the newer cars have the decals anymore). My ‘16 SS lists KD1 as “Cooler, transmission oil” as one of the components. Could be a different RPO on the newer models, but the build sheet lists each one by code and description.
Email to socialmedia@gm.com with your VIN and request the build sheet if you want it, you’ll get it within a day.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
#144 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
Chevrolet Parts Direct shows a separate oil cooler.
PN- 22960693 Fits all Camaro non-supercharged applications
#145 |
![]() Drives: 2020 Camaro LT1 Join Date: Feb 2020
My LT1 A10 has the transmission cooler according to my build sheet. The build sheet also said I had an engine oil cooler too. All the other cooling however is not there and only available on the 1SS or higher trims like the diff cooler. The Manual transmission from what I read in the LT1 does not have a cooler. |
#146 | |
#147 |
#148 | |
My engine oil cooler is also KC4, so codes probably haven’t changed.
#149 |
Oh sorry yes it shows as KD1 for the Transmission Cooler. The 10 speed is MX0
#150 |
![]() Drives: 2017 Chevy Camaro 2SS A8(current) Join Date: Dec 2019
what are the rear gear ratios on the A10s
#151 |
#152 | |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
We need non V8's to be Camaros, period. Some level of upgrades gets you to the RS, but it's not a V8. The LT1 should be pretty much what it is, but without the speed limiter, and with better tires and should be called an SS with a little more attention on marketing what SS stands for. The SS 1LE should be tuned up just a bit for a few more horses and a bit more torque and be the Z28. Maybe a focus on the odd circumstances of the Z28 designator. ZL1 stays the same. I think those are a lot easier to market than the insanity they currently have. 1LS, 1LT, 2LT, 3LT, LT1, wth? Nothing wrong with the cars mind you, just the stupid designators. |
#153 | |||
Dumb Ass Deluxe
The 245's are like being on an ice skating rink. Quote:
I'd be all in for this car....
#154 |
Took possession of my 2021 LT1 November 20, 2020. Drove the car 5400 miles since then (all winter and spring) . I have been practicing on the street WOT pulls from a 20- 25 mph roll in second gear (in manual mode A10). Tires are warmed on cold sunny days by driving 5- 10 miles, black top warmed by the sun by noon hour, warmed tire pressure 27 lbs. The car will dead hook even on 45 - 50 sunny days. Actually took the car to the drag strip 1 week ago, did a easy 2.0 60ft and ran 12.0 on the stock 245 all season tire. Will a SS be any better? maybe on the but certainly not better on the street
