#141 |
![]() Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
#142 |
![]() Drives: 2022 ZL1 1LE Join Date: Sep 2015
Hi all,
Sorry for a late follow up, been busy with lots of other issues at home. I had my installer put in the Kooks Axle back system, will all other exhaust factory stock. When it first started, I was very impressed. Deep, throaty sound like an American muscle car should have, with no higher pitched raspy sounds. Then I drove it out onto the roadway. At every single RPM point where I drive the car, other than full throttle or idle, the drone...well not really just a drone, a gigantic vibration better describes it, occurred. Between 1900-2500 RPMs, inside my beautiful car it sounded like a muted coffee can with ball bearings being shaken on a paint can shaker. The side windows hummed, the rear glass vibrated, and the entire trunk area, mostly from the thin metal factory suitcase heat shield, resonated almost beyond description. It was completely unbearable. On a deceleration in 2nd or 3rd gear, another surprise...A gigantic humming sound that almost sounded like a giant electric motor slowing down. Having heard this system on many videos, and on a local persons Gen 6, I really didn't expect what I got. It was so bad, I only drove the car from the shop to my house, then back to the shop to have my stock suitcase reinstalled at the installers next open appointment. None of the above noted problems existed before or after with the factory suitcase. I believe this system is just not going to work with (Most) M-6 and ZLE cars. It may be that it's just my individual car's own harmonics. Mine was, without any doubt, the worst sounding exhaust (Internally) I've ever added to a car. Reading about some folks more recent efforts to tame similar issues, it is apparent that the Kooks system can be fixed, but that would end up costing as much as the more expensive systems out there, and most of which the sounds I didn't care for. I am now extremely happy to be back with the stock system with the #51 fuse pulled. It should be a touch louder, but I wasn't that unhappy with it to start, and for the cost of the Kooks, it was worth a try for me. I'll sell off the very slightly used Kooks here locally to recoup some of the cost. As a side, with the Kooks installed, the car certainly did feel like it had a bit more punch...but that trade off was more than not worth it. Sorry I didn't make any videos of the horrific sound show it made, but I just didn't feel like setting up the GoPro...but I think you can all get the basic idea, though. Good luck with everyone's exhaust system hunting...Gonna stay stock for mine. JJ
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!! 2021 F-250 FX4 2023 Hyundai SF Calligraphy |
#143 | |
#144 |
Sorry you threw in the towel on the Kooks so soon. Just in case you wanted to give it another whirl, just have some J-pipes fabbed up to go with them. Still ends up being cheaper than most anything else out there.
#145 |
![]() Drives: 2017 ZL1 Join Date: Jun 2012
I spoke with him also. Don't know if he just gave up too soon or the system on the ZL1 1LE may be absolutely too much for some. It has slightly different trans gearing, lacks some insulation, and has some less dampened suspension contact points that could've all made his situation worse than a standard M6 ZL1. But with all the rattles and noises he mentioned, I'd almost question whether there was a clearance issue going on with the install. Seems like the system could've possibly been contacting something under the car. Hard to see how, but I've seen it happen before on exhaust installs.
#146 | |
I would have done exactly the same thing.Your comments are quite the stretch. |
#147 | |
The fitment of the Kooks was not the issue. There was no contact vibration from the system, all the rubber busings were perfect, and everything was properly torqued. My installer is a true pro, and treated the car like it was his own. I watched the entire install. I really believe it was just a matter of the harmonics in MY car. Possibly a loose panel or shield or ???? that did not get affected by the stock system but was by the Kooks. The solid suspension bushings in the ZLE could have added to the cause as well. I could have messed with it a lot more, Dynamated everything, added another resonator and on and on...but it's just not worth my time now for a stock setup that I'm not that unhappy with. JJ
#148 |
I'm not declaring he gave up too soon, just said that in reference to the previous post where "threw in the towel so soon" was used. I personally spoke with both of these guys. Dont get how these comments are a "stretch". The things I listed are obviously differences between the base zl1 and ZLE that could contribute to what he described.
#149 | |
#150 |
Well, these aren't the only cases I'm aware of where people have purchased Kooks axlebacks based on my recommendation. One person I know of so far has removed his system, and that's the gentleman in this thread with the ZLE. I drive my car every single chance I get and have never once thought about taking my exhaust back to stock. I'm not deaf, so obviously there are some key differences between a10s, m6's, and 1LE's as far as harmonics are concerned. I still stand by my opinion of this being the best sounding option out there for these cars. I know people's drone tolerances are different, but what the gentleman in the 1LE describes sounds like more than just that. I was disappointed to hear that these two people had issues with their systems, based somewhat on my video, that cost them additional time and money, so I reached out to them and spoke with them weeks ago. Still dont get how you're saying it's a stretch that a car with less insulation, solid body to suspension mounting points, and different trans gears wouldn't have an affect on drone. Plus, all it takes is a slightly twist the wrong way of those mufflers at install and they will contact the rear subframe. If his back window was rattling, this could've surely been a possibility also. I said from the beginning for people that wanted this system to be ready for more drone than stock, but nothing extreme.
#151 |
Hey all,
No upset here with me. It was worth a try as far as I was concerned after hearing the Kooks system. I still believe the cost of many of the other popular axle back systems is way over what they should be, any many are not the sound that I like. If I was to ever try anything else, I might consider a custom fabricated set of mufflers from a '15 Z/28, fitted onto my stock system. Those were about the best sounding stock mufflers I've heard from an America car in ages. But I'm not sure if the fitment might not be too much of an issue. Anyway, for now, and likely forever, I'm glad to be back to stock...it works for me.
#152 | |
#153 | |
#154 |
![]() Drives: 18' A10 ZL1 , 18' F150, 04' MSM Join Date: May 2018
Just to add to the discussion, I haven't had any issues with drone with the AWE Touring non-resonated catback on my A10.
Seems like a good middle of the road solution with regard to deep muscle car sound and the higher pitched Corsa. Seems like it has a similar right foot controlled sound level. |
