06-05-2018, 11:30 AM | #141 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
I have a 15 1LE. My dad has a 15 Z/28. After test driving a 17 1LE, I decided to keep my 15, unless I found a Z/28 to buy.
06-05-2018, 12:52 PM | #142 | |
Drives: E92 BMW M3 Join Date: Oct 2012
J-Rod Built and Matt@FSP Tuned |
06-05-2018, 03:15 PM | #143 | |
Drives: 2018 1SS 1LE Join Date: Apr 2018
Granted, this is also on E85 but if you're doing heads / cam warranty doesn't matter anyways. Warranty is the only thing keeping me from switching to E85 + tune. Seems to be an easy 30-40+ HP gain. |
06-05-2018, 11:39 PM | #144 |
Drives: 2017 Camaro Join Date: Nov 2016
If a Krypton Green 1LE didn't lure me in when it did i'd be the proud owner of a super low mileage 2015 AGM Z right now. Both cars are equally amazing in my book. Go with your gut.
06-06-2018, 09:57 AM | #145 | |
Drives: Black Join Date: Jan 2017
I just compared the stock ls7 dyno to that heads/cam lt1. The heads cam lt1 absolutely crushes the ls7 on the top end. It’s not even close. Not talking about the actual numbers, just the curve. Heads/cam lt1 revs out like a coyote, but without the complete lack of power at lower rpm. It can’t scream to 8k rpm like the coyote, but a high rpm engine isn’t really about the actual rpm figure, it’s because they are typically motors that make their power later in the rev range. There are only two things I don’t like about the SS 1le and everything else is more than anyone could ask for. -the handling and grip is so high that it feels like it needs 100-200 more hp -the motor runs out of steam at rpm (which is more about driving experience than performance) So basically Heads/cam SS 1le = the perfect car |
06-06-2018, 12:09 PM | #146 |
Drives: '18 1SS 1LE Join Date: Sep 2017
'18 1SS 1LE Black, PDR
