#141 |
![]() ![]() ![]() Drives: 2017 ZL1 Join Date: Aug 2016
well yea it is flexing but you can see it slightly getting pinched as well. keep in mind that its what? a 7th gear pull? could it be more drastic in 1st? also hood is open. you have to keep a very close eye on the smooth section of the intake tube. about a second or so before redline you can see that section gets slightly pinched. it may or may not be enough to cause problems... just worth considering...
#142 | |
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
I could not see any collapse in the video either but I'd be interested to see similar GoPro footage from a dyno run on either of the problem ZL1s discussed here. A 7th gear pull may not generate enough vacuum to illustrate the problem. As the OP described, the problem occurs primarily in 1st & 2nd gears WOT. |
#143 | |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
#144 | |
Cal
Edit: You do know that the air box is closed, right? Not trying to be a smart-@$$ - just not sure if you're familiar with the 6th Gen ZL1 intake. |
#145 | |
HAMMER PILOT
#146 |
![]() Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
Black Box Data Recorder
I am the OP. I got the data recording box installed on the car today. Unfortunately , it is raining here today. So, it will be tomorrow before I get a chance to take the car out and duplicate the issue. The data recorder actually transmits the data directly to GM realtime, so a resolution should be relatively quick. As a side note, the service techs and engineers have been very cordial and seem genuinely interested in solving this mystery. I will follow up ASAP.
#147 | ||
Cal
![]() Quote:
#148 | |
#149 |
Cal
I saw a slight change in shadows but even if that's deflection of the intake tube, it's not enough to make a difference. I believe it's possible for that rubber intake to partially or fully collapse but it seems to me more likely to happen at WOT in 1st or 2nd gear when there is maximum vacuum.
#150 |
![]() Drives: 17' Summit White ZL1 A10 PDR Join Date: Jan 2017
I do mechanical engineering work and own a 17 ZL1 A10... Perhaps the installation of a digital or analog manometer between the throttle body and filter would illustrate the point much better than the video.
Heck with black boxes and such.... I'd guess with the deflection I'm seeing in the video is probably 10" in of Hg or more. Whatever filter or air box combo that remove the restriction will make more power. |
#151 |
![]() Drives: 69 Chevelle SS396 2013 ZL1 Join Date: Mar 2010
Could be dropping fuel pressure at higher load. Direct injection in the lt4 needs around 2900psi I think.
#152 | |
#153 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Have you confirmed it's not this issue? http://www.camaro6.com/forums/showthread.php?t=490819
It doesn't sound exactly the same, but easy enough to check to rule that out.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#154 |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
Found this over on the HP Tuners forum. It's a 2016 SS with a magnuson supercharger that repeatedly hits a limiter at 5700 rpm. The cause turned out to be the rubber inlet tube collapsing.
https://www.hptuners.com/forum/showt...r-at-5-700-rpm
