Old 03-09-2017, 08:20 PM   #141
glenB
Drives: Chevrolet Camaro SS
Vintage ---- You're taking this better than I would, not so much the failure, that unfortunately happens, but the part of the delay on the teardown. It would have me fuming, IMO there is no reason to take so long to make a decision, regardless of a teardown.
glenB is offline   Reply With Quote
Old 03-09-2017, 09:03 PM   #142
Vintage
Drives: 2017 SS 1LE
Thanks - I am trying to behave and not overreact. However, I am less than 24 hours from losing it as they will have had 2 working weeks to tear down the engine.
Vintage is offline   Reply With Quote
Old 03-09-2017, 09:13 PM   #143
BigShow1960
BigShow
BigShow1960's Avatar
Drives: 2017 1 Camaro + Chevy Avalanche
I'm planning on buying a 1LE is 2-3 months...watching intently.
BigShow1960 is offline   Reply With Quote
Old 03-09-2017, 09:30 PM   #144
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Have the techs even taken the valve covers off to look for a broken valve spring or dropped the oil pan looking for a spun main bearing or something along those lines? I hope it all works out.
RUQWIKR is offline   Reply With Quote
Old 03-10-2017, 10:15 AM   #145
Vintage
Drives: 2017 SS 1LE
UPDATE - message left for me this morning by my service advisor. I have called back and now we are playing phone tag. However, this is the message "we got into your motor and the #3 piston is broke; now we are waiting on GM to tell us what to do." That's it, no other information at this time for you folks but as soon as I speak with him I will let you know.
What should I ask about a "broke piston," which makes no sense to me but I am no mechanic? Does he mean rod came loose - if just the piston "broke" then I think it would keep running just with a little less power?
Regardless, I am hoping GM says fix it under warranty. Now, assuming that happens, is it really as simple as dropping in a new piston. I mean, the car stopped running on track. Sorry for rambling.
Old 03-10-2017, 10:20 AM   #146
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Service advisors aren't usually very tech savvy...so who knows what that means. It's just way to broad of a statement. All I know is if this was major damage, and metal shavings went all over the motor, I would want a new motor...not just a partial repair.
Old 03-10-2017, 10:21 AM   #147
DFW1LE
DFW1LE's Avatar
Thats not a very good description by the service advisor. As you indicated was it a due to a rod failure, piston ring failure, damaged due to valve strike or dropped valve, etc.
Old 03-10-2017, 10:31 AM   #148
Vintage
Drives: 2017 SS 1LE
UPDATE 2 - I have now spoken with SA. "The #3 piston let go and dropped. When that happened, it destroyed the motor and you need a new motor. We have submitted a request that you receive a new motor under warranty and we are waiting to hear from Chevy. We do not know why it failed and it does not appear that you did anything - there is no way to tell why it broke."
I continue to be hopeful. Please remember that this happened at about 4k rpm in 2nd gear while accelerating. Strange and uncommon but not unheard of apparently.
Old 03-10-2017, 10:34 AM   #149
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Piston dropped or valve spring broke (valve dropped) taking out the piston?
Old 03-10-2017, 11:00 AM   #150
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
All good signs by the advisor… Everybody's right ....they're just not technical, so far it sounds like you're getting taken care of. Nothing out of the ordinary so far from GM.
With no signs of abnormal operation by you, which is documented, GM is not about to give you a hassle on this. Stuff like this can end up on YouTube. And They certainly don't want that with the new introduction. It may be another week before The warranty expense goes up and down the chain, to get approved. Not abnormal.
Old 03-10-2017, 11:16 AM   #151
Tomiboy
Drives: 2017 Hyper Blue 1LE
Sounds like things are headed in the right direction. Hopefully it's back together by your next track day!
Tomiboy is offline   Reply With Quote
Old 03-10-2017, 11:31 AM   #152
Vintage
Drives: 2017 SS 1LE
Agreed - can they just swap me a new 1LE? I know, I know, I am getting ahead of myself but I just want to drive and at this rate it will be another month before I am back in a car with a different motor than original. I will be grateful if the warranty request is approved - just ready to DRIVE!
Old 03-10-2017, 11:35 AM   #153
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
They will not give you a new car. They will replace the engine. Unless for some reason they can't get that engine......
You may want to talk to the service manager after the repairs are complete about a "trade assist" with GM, then they would get you a new car, but you'd pay some money for using the car so far .....etc,etc.
Old 03-10-2017, 11:47 AM   #154
SpeedIsLife
Drives: Current Camaro-less
Keep in mind you'll likely not be getting a new-new LT1..you'll be getting a certified rebuilt LT1 (if past history is any indication).
