Old 03-25-2019, 09:17 PM   #141
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by chozn4service View Post
I have the American Thunder Flowmaster exhaust with the Scavenger X pipe and it sounds down good to me and is everything I ever wanted in an exhaust.
That is how mine sounds with the valves open. My complaint is when the valves are closed, they don't seal and make a hissing sound.
https://youtu.be/rMmg8eJdqC4
Old 03-26-2019, 07:23 AM   #142
70chevelleSS
70chevelleSS's Avatar
Drives: 2017 Camaro SS 1970 chevelle SS
Flowmaster American Thunder Dual Mode Axle-back (NPP) for 2016+ Camaro SS & ZL1
Yea mine definitely doesn’t sound like that when closed. I wonder if your valves have gotten dirty somehow or collected buildup which may keep them from fully closing?
2017 camaro SS A8
FBO With all porting and tuning done by PRAY
70chevelleSS is offline   Reply With Quote
Old 03-26-2019, 08:57 AM   #143
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
Mine either.... as stated above, maybe some build up on them? Wonder if maybe shooting them with some carb cleaner and using an old tooth brush and then spraying again might resolve the issue. I’ve have mine virtually since getting the car new in 2016 and still sounds great and seemed to have gotten deeper along the way.
I’d like to do headers but seems as tho they won’t mate up to the Scavenger X so I’ve been told and ARH and KOOKS wants to sell be a catback, tho MOTOFIRE on IG says it will work. Just need confirmation before I make that move but I can only imagine what it would sound like.....
Never grow up, it's a trap!
chozn4service is offline   Reply With Quote
Old 03-26-2019, 09:18 AM   #144
KingLT1
KingLT1's Avatar
The exhaust is brand new. I even tried oiling the valve shafts. When I shine a light in the pipe, the valve doesn't look concentric with the pipe. I must of received a axle back built on a Monday.
Old 04-05-2019, 06:00 PM   #145
KingLT1
KingLT1's Avatar
Still no word yet from Flowmaster. CS rep said he is still waiting to hear back from the product group.
Old 04-05-2019, 06:11 PM   #146
70chevelleSS
While I have not noticed the noise that yours makes, I have noticed that my valves don’t shut 100%. Essentially I can put mine in stealth mode, and still get some flow on the outer pipes. It gets quieter if I cover the outer pipes with my hands. I assumed this was just the nature of these valved exhausts, but it could be related to the problem you are experiencing.
2017 camaro SS A8
Old 04-05-2019, 06:37 PM   #147
KingLT1
KingLT1's Avatar
It is but mine don't close as far as they do on initial startup after I have driven it and that is when they start making the hissing noise. If I use a screw driver I can push them closed 1/16" or so and the hiss goes away, then the sound is similar to what you describe.
I'm going to try some stuff in the exhaust valve tuning and see if I can fix it. It almost seems like the valves need to be turned a tad further then the controller is turning them in order to seal. I am going to try using a value higher then 100 in the closed cells and see what happens.
Old 04-05-2019, 07:18 PM   #148
6spdhyperblue
Drives: 2SS 1LE
Anyway to cheat on the valves and get them to turn a bit in that direction and retorque the bolts? Are they the oem actuators that boot in there?
Old 04-05-2019, 09:08 PM   #149
KingLT1
KingLT1's Avatar
Yeah OEM actuators. I'm going to try some things and see what happens.
Old 04-07-2019, 02:54 PM   #150
MAGAUSA
MAGAUSA's Avatar
Drives: 2017 Hyper Blue 1LE
Mine has that hissing sound with the valves closed too. Much better than the stock "rattle" but still annoying.
MAGAUSA is offline   Reply With Quote
Old 04-08-2019, 08:37 AM   #151
KingLT1
KingLT1's Avatar
Thanks for reporting. Yes I agree, I will just leave the valves open at idle and cruising, then have them close in 8th gear so it eliminates the drone.
Old 04-08-2019, 08:39 AM   #152
6spdhyperblue
Drives: 2SS 1LE
Does it hiss at the low cfm at cruise or just when pushing a bunch of air through them?
Old 04-08-2019, 09:24 AM   #153
KingLT1
KingLT1's Avatar
its only noticeable at idle with the exhaust valves closed(touring/stealth) when you stand behind the car, or backing into the garage with the windows down. Most probably leave the car in sport and never notice it, but since I have cat deletes, it makes the exhaust significantly louder. I had my valves programmed to stay closed in all modes until 3-4k rpm then open.
Old 05-06-2019, 09:37 PM   #154
KingLT1
KingLT1's Avatar
Just an update...Holley performance group is sending me a brand new axle back exhaust. It's been a slow process but nonetheless they are taking care of me.
american, axle, dual, flowmaster, npp
