Old 07-28-2016, 01:42 PM   #141
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Originally Posted by Goertz View Post
Ok so updates for today:
Sleep Apnea test results, I quit breathing 10 times in my sleep. Being the VA though it will take 6 weeks to get results back and see what follows next. And apparently out of a 8 hour night only got about 3 hours of sleep. Guess this could explain why I'm always so tired
I had a lot more episodes than ten, my setting are pretty high also, like its set at 15. Gotta love the VA, I get all my health care done there, they take pretty good care of me.
How goes the build?
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 07-28-2016, 04:11 PM   #142
Goertz
Goertz's Avatar
Drives: 2016 1SS Auto
Turbowerx filter comes in today finally
The other pump should hopefully be in by next Friday. I would be putting things back together today to test out our relieved gears but it's leg day at the gym and I'm pretty much going to be dead when i finally make it home haha
Tomorrow We'll put it together and hope the turbowerx pump holds out. We've will have done everything imaginable to fix it minus taking the motor apart and putting new brushes in it
Va has done a pretty good job for me so far.
Goertz is offline   Reply With Quote
Old 07-29-2016, 08:37 PM   #143
Goertz
Goertz's Avatar
Pulled every trick we can for the turbowerx pump with no success.
Just waiting on next scavenger pump to come in at this point now.
Old 07-29-2016, 09:27 PM   #144
Fergy
Fergy's Avatar
Drives: 17 Camaro SS2, 93 C1500 Silverado
You can see in this picture how there rotors were rubbing the pump cover and have galled up. We are going to try taking off .003 and see how that goes.
Honestly that looks like normal wear, i have worked in the energy and gas industry for a few years on top of my time in the military as a mech. and seen that on many oil pumps that lasted 20+ years
17 SS2, Nightfall/Kalahari, M6, muffler delete, skip shift delete, wideband O2, Flex fuel sensor
Fergy is offline   Reply With Quote
Old 07-29-2016, 10:55 PM   #145
Goertz
Goertz's Avatar
My dad ( engineer) thinks one of th e armature is going out on it. Turbowerx offered to check it out for me so I'll likely mail it out Monday. I'm expecting my tracking number for my new pump around then as well so hopefully things can get moving again next weekend.
Old 07-29-2016, 11:13 PM   #146
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
A diaphragm pump will do the trick.
Atomic Ed is offline   Reply With Quote
Old 07-30-2016, 08:53 PM   #147
1KillerSS
1KillerSS's Avatar
Why not do a 911 oil pump? Super reliable.
Build thread
Old 07-30-2016, 09:22 PM   #148
Goertz
Goertz's Avatar
Can you send me a link
I've tried looking into that and for future purposes we are. Actually looking into designing and building our own electric mini dry sump system.
Old 07-31-2016, 07:28 AM   #149
Goertz
Goertz's Avatar
Hung out with the HP Motorsports guys and swapped knowledge last night.
Recipe to more power on factory fuel system according to them.
32% larger fuel pump overdrive cam lobe with lash cap for lt1 fuel pump will net 800-900 whp worth of fuel on stock injection pump, injectors and lift pump.
With z06 injectors and injection pump and 32% overdrive cam 1000whp worth of fuel.
To get 1100-1200 fuel need either a bigger lift pump in tank or a surge tank that the factory tank pumps to then larger pump push to front
With all that said figure 40% less power if using e85. Those numbers were gas only.
So we still like my supplemental fuel plans the most for getting up the power.
Oh yeah and i asked about the lt1 ring lands going and they said 700-740 whp zone
Old 07-31-2016, 09:29 AM   #150
1KillerSS
1KillerSS's Avatar
Sorry I don't have a link, but I'm sure some time google searching will show you what your after. Its a super reliable, used for engine oil, they have scavenge pumps for their turbo applications, but I would be looking for a 911 930 engine type oil pump.
Build thread
Old 08-05-2016, 03:50 PM   #151
Goertz
Goertz's Avatar
Got tired of waiting on that Shurflo so I ordered a Tilton Constant Duty 1-2gpm pump from summit (my shurflo will be delivered by next Thursday). Comes in tomorrow, I'll also be taking my wife out to see Suicide Squad tomorrow so install will wait till Sunday. Should be back up and running on Sunday. Luckily the shop dyno is back up and running again also so early next week can finally get some dyno time then track on Friday and see if we can muster a decent number.
After it is up, going to drive it hard for a solid 1-2 weeks and really beat the heck out of it.
We are finalizing our oiling system (currently just going to be packaged with a return to engine type system, a stand alone oiling system will be under way next month)
I have a hookup for a very nice professional website from a guy who works with CBS news so that will be under way before the month is over.
DBA is in and getting all other things in order.
My graphics artist guy is working to finalize the logo for us.
Plan is to drive the heck out of the car and iron out any remaining bugs then around the 20th take it down once again to build all fixtures. After all fixtures are built I have to build 1 complete kit out of the fixtures to install back on my car and 100% verify a bolt on installation (this is when I'll do a install video). The final install will be fully Lava Header wrapped and my turbo blanket installed.
We're a little behind schedule with where we wanted to be for release at the beginning of August but we are further along than anyone else with a turbo kit I'm pretty certain.
Expect website to operational and full blown Camaro6 Sponsorship to be underway around the end of August. Really excited and looking forward to bringing a solid product to the community.
Old 08-05-2016, 08:22 PM   #152
1KillerSS
1KillerSS's Avatar
Good luck man! AGP has a kit I think, either way I know there doing turbo installs.
Build thread
Old 08-06-2016, 11:23 AM   #153
Tcamaro
Drives: 16' 2SS
Is there a guess on price?
Tcamaro is offline   Reply With Quote
Old 08-07-2016, 03:05 PM   #154
Goertz
Goertz's Avatar
Hot rod is back up again.
Going to see about getting on the dyno tomorrow and get new pics. The new oil system looks amazing and is working perfectly
