Old 08-24-2017, 07:58 PM   #141
Icyrain
Drives: '17 SS 1LE, Hyper Blue
Originally Posted by JoeCastigs94 View Post
Can someone please explain in detail what that screen does and how it works? Getting my car in about a week and thats the only thing im confused about. I know u have the few modes by the shifter so what does that screen do? Is it just for start up purposes or what? haha Thanks
-Joe
The button by the shifter will select touring, sport, track, rain/ice settings and apply all those settings to your steering, exhaust, and suspension. Kinda like a preset. I think the rain/ice one might only be if you have the eLSD that is standard the 1LE or ZL1 though. For example, if you use the button by the shifter to put it in the track preset, then on the 1LE your steering is set to track, NPP exhaust is in track (loud) mode, and suspension for MRC dampers are set to track mode (firm). This is great if you want everything adjusted quickly. But say you like the steering kinda agressive (sport), you like the exhaust loud (sport or track...seems the same) but you're on a bumpy road for the next hour and you'd like your MRC suspension to be a little softer than track mode (comfort/touring or sport). To change just one part you go into the menu on the radio and can adjust it individually. Hope this helps.
Icyrain is offline   Reply With Quote
Old 08-25-2017, 10:11 PM   #142
Epx998
|Engineer|
Epx998's Avatar
Drives: 2016 Camaro SS
Menu overrides the presets (auto-select) - the menu vanishes because the head unit is garbage. But happens from time to time when you remote start the car - only time i've seen it is with remote starts.
Epx998 is offline   Reply With Quote
Old 09-20-2017, 07:38 AM   #143
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
Dealer replacing my head unit as part of the bulletin. I’ll report back after my own testing
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
Adrian97c is offline   Reply With Quote
Old 10-29-2017, 01:01 PM   #144
subsonic0702
Drives: Procharged 2017 2SS
Add me to the list. I contacted chevy service in this thread. Hopefully they'll get it sorted out for us as it is a nice feature to be missing.
subsonic0702 is offline   Reply With Quote
Old 10-29-2017, 09:53 PM   #145
miketan
Drives: 2018 HBM SS 1LE
On my lemon before I got it swapped out last week I had this issue. I did get the radio replaced and it reduced the frequency from almost daily to once a month but it still occurred. I noticed what triggered it for me was opening the passenger door before starting the car.
miketan is offline   Reply With Quote
Old 10-30-2017, 12:48 PM   #146
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
I believe this is true as well…that it only happens when you remote-start the car. I was experiencing the problem intermittently. It wasn’t really a problem for me as I don’t switch modes very often and have Fuse #51 pulled.
But I was curious, so I decided to test a theory. I was thinking the issue was happening because of timing. More specifically, I was thinking that if I remote-started the car before the car was fully awake, it might cause a miss of some of the startup sequence steps and therefore not display the driving mode menu and other associated menus that seem to be missing when this happens.
So, I started following a regular ritual Every time I remote-started my car for the last three weeks. Rather than just hitting the lock button and then hitting the remote start, I would fully unlock the car by hitting the unlock button twice, then I would lock the car with the lock button, then remote start. I ran this test for a good 3 weeks, with flawless results. I have not lost the driving mode once, nor any of the temp settings etc. in that time.
It’s working for me, hope it works for some of you! It’s not a fix, but it really helps avoid an annoying problem consistently.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 11-03-2017, 10:59 AM   #147
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
happened to me as well. then my car went into security mode or something and none of the electronics worked at all. shut it off for a few minutes and restarted it and everything has been fine ever since.
Kise is offline   Reply With Quote
Old 11-14-2017, 05:14 PM   #148
off1c3r
Drives: 2017 Camaro 2LT 50th
I haven't followed this topic since March or so... and this still hasn't been resolved? 17-NA-186 still doesn't have an actual repair procedure? I never got mine fixed.
2017 50th Anniversary Edition 2LT V6
1100 - 09/26/2016 | 3000 - 09/28/2016
3100 - 10/04/2016 - TPW: 10/17/2016
3300 - 10/06/2016 | 3400 - 10/06/2016
4300 - 10/17/2016 | 5000 - 10/28/2016
off1c3r is offline   Reply With Quote
Old 11-14-2017, 08:12 PM   #149
PnCRedJwl2SS
Howdy! Pete here...
Check out my temp-fix above. I'm still doing it and it's still working for me 100% of the time!
I'm surprised I haven't seen reactions from others trying this too. Anyone...? Bueller...?
PnCRedJwl2SS
Ordered from GM
Old 11-15-2017, 07:42 AM   #150
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
Seems like that would be a clue for the software guys!
I've not checked for Driving Mode lately, but will start looking again.
TonyNo is offline   Reply With Quote
Old 11-15-2017, 11:16 AM   #151
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
When I had my '16 2SS/A8; I've had the driving mode setting disappear once in a while, and I never remote started my car ever. Whenever it did disappear, by the time I'd go home from work after sitting all day, the setting was back on the screen.
nancygrl is offline   Reply With Quote
Old 11-21-2017, 05:04 PM   #152
off1c3r
Nice work! Not a horrible work around.. doesn't really add any time or inconvenience. I wonder if locking the vehicle via the onstar remote app, then remote starting would have the same effect?
Old 12-04-2017, 12:38 PM   #153
PnCRedJwl2SS
Howdy! Pete here...
Worth a try! If you do, let us know how it goes...
PnCRedJwl2SS
Ordered from GM
Old 03-14-2018, 03:35 PM   #154
davef
Drives: 2017 SS 1LE Garnet Red
It's not always a remote start issue, my car doesn't have remote start and it's happened 2 times that I know of. I don't change my settings much so it could be happening more than I'm aware of. I'll try the service bulletin on page 9 of this thread. It does seem to fix itself after a short shut down time.
davef is offline   Reply With Quote
