Old 09-05-2016, 02:33 AM   #141
JaxChris
You could remove the Bose amp from the equation entirely for another 500 or so. Get a MOST bus DSP and then provide your own amp for the speakers. I think all of them have a model with software control that will let you selectively choose which signals get mixed and which are ignored (like ANC, OnStar, etc).
Check out: (just some off the top of my head)
mObridge
Rainbow Audio
Arc Audio
Mosconi
Old 09-05-2016, 07:11 AM   #142
brutusvk
Drives: future 2016 SS
I am using the fosgate 3sixty.3
brutusvk is offline   Reply With Quote
Old 10-06-2016, 09:42 AM   #143
rockmover
rockmover's Avatar
Drives: Camaro 2016 2SS
Adding 10/12" Sub
So where is this thread ending? I really would like to add a nice 10 or 12" sub to my 2SS, but if no one can figure this out than whats the point? I certainly don't want to take my car to a custom install only to have the same issues everyone else is having.
What is really needed to correctly install a single sub in a 2SS.
Obviously a sub and amp...
JL Audio 10", CS110TG-TW3
JL Audio JX500/1D
But is this needed?
http://www.audiocontrol.com/car-audi...-upgrade/lc2i/
or is it a waste? Do I need to get a MOST unit and throw the bose stuff away?
Again I just want to add a nice single sub in the trunk to reduce the load on the other speakers and get a little better sound. I have no problem spending $1000 if needed, but I'm not looking to spend too much more.
Thanks in advance, and Im surprised there is not more info on this subject out there as the speakers do kinda suck in all factory cars....
rockmover is offline   Reply With Quote
Old 10-06-2016, 10:44 AM   #144
nearwater
nearwater's Avatar
Drives: '17 2SS 50th
I too would like to figure this out, as I'm having the same problem with unbearable noise from the sub.
I'll try to troubleshoot the problem by playing with the ANC signals and see if it goes away.
But I have this bad feeling that I won't be able to remedy the issue...
We will see.
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
nearwater is offline   Reply With Quote
Old 10-06-2016, 05:42 PM   #145
Hyper1SS
Hyper1SS's Avatar
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP
Here is a picture of the back of the radio. You pull the center piece off the center of the radio around the knob on the front and there are screws holding the radio down. The radio than hinges upward to get to the wires to disconnect. Hope that helps!
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates.
Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges
Order ID: TDHQMS
1100 on 01/07/2016 at Penske Chevrolet
6000 on 02/23/2016 Delivered to customer
Hyper1SS is offline   Reply With Quote
Old 10-06-2016, 08:06 PM   #146
JoeAyalaM
Drives: Audi S6 V8TT, Volvos XC60 & S60R
JL Audio JX500/1D
But is this needed?
I used to be a huge AudioControl fan years ago. I have had bad experiences with the processors bought lately, so I will not buy from them again.
However a JL Audio processor saved my latest installation, it was a CleanSweep DSP, now discontinued for another more advanced model.
Installing a Sub only without upgrading the rest of the system, may not turn out that well, there needs to be balance between frequencies, and the Camaro lacks mid tones in the front, so more bass will make mid tones appear even lower.
Edit: I now believe that the main problem with the Bose system is that the subwoofers get distorted badly when playing low notes at higher volume levels, the rest of the system is pretty good. May be a sub and bass blockers for the stock subwoofers will do just fine, I will try it and report findings, I will need to build the bass blockers for the 2 ohm speakers at 150 or 200 Hz.
JoeAyalaM is offline   Reply With Quote
Old 10-22-2016, 10:13 AM   #147
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
I getting noise interference when pressing the gas pedal. I had this problem after the system was installed and they fixed it in 5 minutes, but I did not ask them what they did. After a auto accident I am now having the same problem. A freind told me the power and rca cables are to close somewhere but they appear to be running to opposite sides of the car. I am getting a loud buzzing noise at 2500 rpm even when I mute the radio, it is really loud. Looking for any advice.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 10-22-2016, 10:49 PM   #148
lDejavul
lDejavul's Avatar
Drives: Camaro SS
Look at your grounds. Most likely something isnt ground properly anymore. Thats if you cut the ANC mics from your amp.
Kooks ceramic coated headers -1 7/8 in. x 3 in
Pray ported 95MM TB
Pray ported MSD IM
Rotofab CAI
BTR 225 CAM
PRC 312 CC Ported Heads
Katech Oil Pump
DSX Flex Fuel E-85 kit
QTP exhaust cutouts
Full JLAudio Stereo Build w/ 13-W6
lDejavul is offline   Reply With Quote
Old 10-22-2016, 10:53 PM   #149
JoeAyalaM
Try checking all the grounding points, sounds like you could have a fault ground connection.
Old 10-24-2016, 12:33 PM   #150
bybcous
bybcous's Avatar
How do I cut the microphone on my amp, im not sure if something was rep plugged up while they were putting my car back together, the guy at a local audio shop said make sure the mic to the noise cancellation is disconnected
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 11-04-2016, 10:26 PM   #151
pdiddy972
Drives: 2017 Corvette Stingray Grand Sport
Anyone get the straight scoop to get a clean install?
pdiddy972 is offline   Reply With Quote
Old 11-06-2016, 11:33 AM   #152
ctrlz
mObridge
Rainbow Audio
Arc Audio
Mosconi
This would be the starting point, especially if you can pull the MOST feed off right at the rear amp connector. Haven't seen anyone use one of these yet.
Old 11-07-2016, 07:47 AM   #153
Snoman
H-Town Camaro Club
Snoman's Avatar
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP
Originally Posted by gblaue View Post
Originally Posted by cellsafemode View Post
MOST utilizes a fiber optic cable as it's bus. Do you have any pictures of this either at the oem amp or the BCM (if bcm, then the bcm sends pre-amp analog over to stock bose amp).
mObridge
Rainbow Audio
Arc Audio
Mosconi
There is no MOST, Fiber Optic, or any other central media stream core in the Camaro. The technology was coined in the late 90s as an alternative to fiber and to generate their own royalty fees. Most of the Car Audio industry had already rejected digital interconnects before the turn of the century though there are a few rare exceptions. Those that do offer it, have limited options and generally incompatible with anyone else and most are not even sold here in the United States.
While GM appears to be using MOST with some of their larger vehicles, the Camaro utilizes the IDB-C "media connector", aka "Molex". Rainbow Audio has options to use an Ethernet cable, but such a transmission line compatibility is extremely rare. Furthermore, since their only real benefit is to assist with 'balanced levels', worthless as electronics today have no balanced issues. Arc Audio discussed adding it in 2015, but never did and Mosconi has no digital interconnects.
The only thing running between the head unit and the amplifier at the rear of the Camaro are 20-22awg copper analog signal wires.
Snoman is offline   Reply With Quote
Old 11-07-2016, 10:58 AM   #154
ctrlz
I think we need the pin-out for the X4 connector. That is the only one not posted yet. Incoming signal is supposed to be MOST on x4.
