09-30-2021, 01:49 PM | #141 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Not every 2019 has it, at least that's what I've read.
09-30-2021, 02:04 PM | #142 |
Drives: Black 2021 ZLE 10AT Join Date: Jan 2017
[QUOTE=KingLT1;11078305]I wouldn't want the trans to shift like the 2-3 does stock ever. That is torque management cutting spark and closing throttle on that shift creating a big delay which negates a lot of the potential of having the extra gears. I would want the A10 to shift like the 4-5 on every shift and that can be achieved with tuning.
Can I pay you to get it done? I just want it to shift like 2-3 all the time. I have a 2021 stock everything..pm me if possible |
09-30-2021, 02:19 PM | #143 |
Drives: 2019 ZL1 Join Date: Mar 2019
ZLE don’t ZL1 yes.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-30-2021, 02:20 PM | #144 |
Hahaha at least ya got a sense of humor … I like that
09-30-2021, 02:36 PM | #145 | |
You give them your car's VIN and they flash the stock TCM's calibration. Their 87a isn't totally "plug and play", because tune adjustments are absolutely required in the ECM in order for it to work correctly. There’s instructions listed on their invoice.
'20 ZL1LE A10.
LME 390, E2650, FBO. 1116/967. 15" conversion/Weld/MT ET Street R 325/50R15. 100 octane: 1.35/9.25/151 at 3500 ft. (only one pass so far). 100% meth/100 octane: Alky Twin 10+10 MAF; No dyno or ET. |
09-30-2021, 03:05 PM | #146 |
Petro-sexual
You're right. I have an invoice and did all that I wasn't sure if I was misunderstanding what the OP was saying. But yeah - like you said - all that stuff's there on the invoice. We'll see if it's all that easy...
09-30-2021, 06:14 PM | #147 |
We basically have to figure out how to launch and run the car down low at WOT, uninterrupted and unnecessarily affected by conservative GM programming, while achieving a certain wheel spin, say, 5-10%. It's going to take a bunch of hits, which, for me, means it will continue next spring.
'20 ZL1LE A10.
09-30-2021, 06:17 PM | #148 | |
10-18-2021, 10:13 AM | #149 |
Petro-sexual
Anyone having issues getting this TCM up and going? The car throws a message to shift into PARK and basically disables itself. Shoot - I didn’t even start the car or shift OUT OF PARK, and get that message. Like - I can’t even unlock the trunk… I can’t even turn the ignition off. I have to disconnect the battery in order to shust the car OFF. I disabled the P2544.
10-18-2021, 11:05 AM | #150 | |
2016 NFG 1SS A8
10-18-2021, 11:10 AM | #151 | |
'20 ZL1LE A10.
10-18-2021, 11:39 AM | #152 | ||
Petro-sexual
Thanks for your guys comments. I'm all ears for ANYTHING else you think might be relevant.
10-18-2021, 12:13 PM | #153 |
This is a new issue for me. How did you discover it?
'20 ZL1LE A10.
10-18-2021, 01:08 PM | #154 |
Petro-sexual
Which part of my difficulties? LOL...
You have to attack that TCM by removing the facia. It's not that hard, but there are a thousand fasteners (use an battery powered tool - it makes it faster - just keep it on a low torque setting to not strip or break anything). I was more pissed that I pulled apart half the wheel well to determine I needed to pull the whole facia. Have a buddy help you remove and install it though so you don't scratch anything. There are LOTs of clips, too. There's the DRL-harness that you have to address, so mind that. It's not that big a deal. I'm just irritated it's not working and I have to wait with my car blown apart. The TCM-issue is just weird. I'm, frankly, pretty pissed about this. I was on the fence already, not really having much trust in it working, but my confidence is waning in this product, so I might push to return it and seek a refund. I specifically asked if I needed to follow HPTuners' procedure, in conjunction, but maybe I'm just confused or something. I wasn't told to use HPTuner's procedure, but maybe that was implied.... In case you want more detail:
I left the car like that until I hear back from HHP. Any help is always appreciated. Thanks to everyone. Chuck
