01-01-2024, 11:22 AM | #141 | |
However, if you think about it, the only relays that make sense for this is the fuel pump and starter relays. This must be similar for the Mustang and the Challenger, or other often stolen models, which isn't a lot to research and remember even in total. So the solution works against the dumbest of the dumbest, and I don't know how much of the "thief population" that represents.
01-01-2024, 11:31 AM | #142 |
Drives: Chevrolet Blazer Join Date: Oct 2021
Happy New Year to my Camaro 6 Forum Brothers and Sisters.
This discussion is very interesting and I have to admit I've learned a lot about anti-theft protection. Although I doubt most of the morally deprived car thieves would invest time on this forum but openly discussing these available options does provide useful reference material. Of course, no one can simply walk up a vehicle and know which anti-theft options are employed but, we are providing some clues. Nevertheless, this discussion is valuable to anyone who owns a Camaro and would like to keep their car from getting stolen.
2023 2SS 1LE Radiant Red, A10, PDR, Black Lugs, ACS Rock Guards, ACS ZL1 1LE Side Skirts
01-01-2024, 12:40 PM | #143 | |
Drives: 2000 WS6 Join Date: Dec 2014
I've done maybe 25 stereo headunit installs on older cars, mostly adding AA/CarPlay capability to pre-2016 cars/trucks, some requiring complicated/expensive adapters for the CANBUS, wheel controls, front/rear cameras, integrated climate controls, etc. There's always that moment when you have everything connected and you power up for the first time. It's when you know your two hour job will turn into an additional 3-4 hours of troubleshooting or not. Now think of that kind of moment but looking at jail time if you can't resolve it fast enough, or you just shut the door quietly and move along, undetected. |
01-02-2024, 12:47 AM | #144 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Question about that NoStart Remote Relay device. Does the relay have constant power so that it can be cycled to blocked or on status? Wondering if the ignition would have to be on.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
01-03-2024, 01:39 PM | #145 |
Drives: 2022 Camaro 1SS 1LE Join Date: Nov 2021
What about one of these generic anti theft relays on the fuel pump or starter?
https://www.amazon.com/ANZAGA-Genera...75&sr=8-9&th=1
2022 Camaro 1SS 1LE 6-speed
01-03-2024, 01:56 PM | #146 |
I have the old school first generation remote controlled mild to wild exhaust cut out system that I’ve been playing with on different fuel, starter, ignition fuses. This is my busy time at work so I haven’t had time to try it out on everything yet so as to come to a suggestible conclusion.
01-03-2024, 02:32 PM | #147 |
Drives: 2016 2SS Convertible Join Date: May 2012
I experimented with mine a bit (car is in storage for the winter). The relay doesn’t seem to have constant power. The starter relay is disabled automatically when the car powers down (along with the lights and radio). You have to manually press the Camaro’s Start button to power it up and then you can use the relay’s remote to enable starting. The downside seems to be that Remote Start from the Camaro fob is disabled. That would be inconvenient for people that want to use Remote Start to warm up their car in winter.
01-03-2024, 02:43 PM | #148 | |
01-03-2024, 02:45 PM | #149 |
ordered the mobilstics one
going to do a dummy obdii port going to also use a gun, axe and acid as a last resort
01-03-2024, 02:51 PM | #150 |
01-03-2024, 06:19 PM | #151 |
OSCM(SW) USN Ret.
Drives: 2023 Camaro 2SS-1LE VOM 6M Join Date: Apr 2023
I prefer well placed punji pits with claymores!
2023 2SS-1LE VOM, 6M, SR S-TBrace, A-PDL's, Fuzzy suede KP's, NAV
1100 3/29/23 2000 3/30/23 3300 5/1/23 3800 5/4/23 4200 6/1/23 6000 6/6/23 |
01-04-2024, 01:24 PM | #152 |
Drives: 2021 LT1 Camaro Join Date: Dec 2020
Well, the relay attack doesn't really worry me, but the key clone obd one does.
The OBD port lock combined with a steering wheel lock might be enough for when you have to park somewhere you're not super comfortable with. If you're parking every night somewhere exposed you're going to need more though. The real issue is that you can surf over to amazon and easily buy basically a car theft tool. That's super wrong. |
01-04-2024, 09:26 PM | #153 |
Drives: 2021 LT1 A10 RS Join Date: Feb 2021
Soler engineering, and their throttle module has a throttle disable mode for the throttle via app. They can break in but do nothing after that. Pretty good piece of mind.
01-05-2024, 12:07 AM | #154 |
Electrical Engineer
keep in mind that any module is easier to bypass than any OBD interface. A set of alligator clips can bypass any aftermarket module. it's easier for me to find aftermarket wiring than relocated OEM wiring.
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 34k mi. @ Sept 2024 New Engine @ 22,600 mi. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
