#1485 |
![]() ![]() Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
Update;
Tires used on the pass: MT R 305/17. M&H 28x4.5 Performance Mods (if any): LTH CAI PIM PTB UDP e85 gears W/R Converter Category submitted for: Please List the Category or Category # 3 R/T.......... 60'.............1.48 330'...........4.451 660'...........6.915 660’ mph...99.94 1000'..........9.046 1320'..........10.851 1320’ mph…125.66 Name of the track: Atco Date of pass: 06/26/2018 Weather conditions: Include Density Altitude if known. (Optional not required)+1100
#1486 |
![]() ![]() ![]() Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Tires used on the pass:MT R 305/17, MT 28x4.5
Performance Mods: CAI, PTB, PI, LT w/HF Cats, E85, Tune, Drag Pack, "W/R", -Neg camber Track Alignment* Category submitted for: #3 R/T.......... .007 60'............. 1.727 330'........... 4.837 660'........... 7.385 660’ mph... 96.62 1000'.......... 9.580 1320'.......... 11.444 1320’ mph… 120.63 Name of the track: New England Dragway Date of pass: 7/11/2018
#1487 | |
![]() Drives: 16’ 2SS A8 HBM Procharged Join Date: Jun 2017
I am jealous of your launches. You literally were 2 thousands of a second faster than my run of 11.446@124. That is one fast vert.
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
#1488 | |
#1489 |
![]() Drives: 2017 Camaro 2SS Join Date: May 2017
I know this setup has more in it this was the last run of the night showed up hour before closing and was unprepared this pass was on a fresh bottle that I only had time to heat up to about 700psi... run before this it had 950psi and trapped 123mph on a almost empty bottle. I have window switch kicking on at 2700rpm and shutting down at 5900rpms I was playing with it trying to kill it right before shifts but think im going to try and come on sooner and set it at 6k and see what happens would like to see low 11s before doing the longtubes, tune and 200hp jets I think mid 10s is totally doable with this setup would like to get the M6 up on the list sure the A8s are fast but I still like my M6 car. This run was also against driven2exceSS, cool to meet someone off the forum at a local track its a small world we live in. Also had someone filming all the runs I found out I attached the link below last run was the 11.5
Tires used on the pass:MT Street S/S radial 305/18, stock SS fronts Performance Mods: nitrous express wet kit with 100hp jets (actually has a .028 fuel since i did not have the .027 fuel it called for on the 100hp) stock tuning w/6510 plugs .028 gap, stock exhaust, air box mod w/green filter Category submitted for: #5 R/T.......... .329 60'............. 1.812 330'........... 4.889 660'........... 7.466 660’ mph... 96.45 1000'.......... 9.673 1320'.......... 11.531 1320’ mph… 121.92 Name of the track: New England Dragway DA 867 Date of pass: 7/11/2018 ![]() https://youtu.be/nJQDC3qht8c
2017 Camaro 2SS M6 100% stock at the moment
1.839 60' 12.113@114.95MPH 6/9/17 12.267@115MPH 5/17/17 12.374@116.83MPH 5/10/17 |
#1490 |
![]() ![]() ![]() ![]() Drives: 2018 ZL1 A10 Join Date: May 2012
Please add to list Category 8 2018 ZL1 A10
Tires used on the pass: MT DRs 305/35/20. Stock front 285/30/20 Performance Mods (if any):none Category submitted for: 8 R/T..........0.275 60'.............1.783 330'...........4.963 660'...........7.543 660’ mph...96.18 1000'..........9.745 1320'..........11.609 1320’ mph…120.73 Name of the track:Rolling Mix Raceway, Prince George BC Date of pass:July 13, 2018 Weather conditions: DA 3410. 19 Degrees Celsius. Cloudy and cool.
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
#1491 |
![]() Drives: A10 ZL1 Join Date: Mar 2018
I went for the first time the other night. My burnouts sucked. Should I just use the line lock option?
#1492 |
That’s what I do.
#1493 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
I just turn everything off and use my left foot for the brake and right for the gas.
Full exhaust, lower pulley, E35 -10.36 at 133 mph 690 DA straight from the street with a slight spin at launch. TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
#1494 |
![]() Drives: 2017 1SS Join Date: Jul 2018
Lane 2 12.16@113. A8 Bone stock 1SS, factory runflats. Sorry it’s sideways
#1495 |
![]() Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10 Join Date: Feb 2017
Tires used on the pass: MT ET Street R 305/45R17
Performance Mods (if any): Lower Pulley, Headers, Cat Delete, Exhaust, CI, PT, Meth, and tires. Category submitted for: Please List the Category or Category # (8) Camaro 2017+ LT4 ZL1 Bolt On's No Internal Mod's (Stock Displacement) R/T........... .376 60'............. 1.638 330'........... 4.560 660'........... 6.956 660’ mph... 104.87 1000'.......... 9.026 1320'.......... 10.786 1320’ mph… 126.31 Name of the track: Woodburn Drag Strip Date of pass: 7.21.18 Weather conditions: Include Density Altitude if known. (Optional not required) DA 649
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer |
#1496 |
Great pass TDS. If you can get that Z into the mid 1.50's 60 ft you'll be stellar. Mph seems a little low, how much are you above sea level. Congrats.
#1497 | |
Only 157' Did some data logging for my tuner, He is trying to figure out why it week on the big end. I agree mid 1.50's with a little more speed on the big end we will really be getting somewhere.
Travis
#1498 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Tried a new category for my 2017 SS A8, that being LT-1 power adder. Used a base ECS/Paxton supercharger with the standard pulley for a stock motor. Also new are the 17" front wheels. W/R was just a smaller battery to offset the weight of the driveshaft loop. All of the seats were in the car.
Tires used on the pass: MT ET Street S/S 275/40-17 rear, MT Sportsman SR 26x6x17 front Performance Mods (if any): DRs and Skinnies, PTB, W/R, Supercharger Category submitted for: (5) Camaro SS 2016+ LT1 Power Adders Stock Displacement (IRS Street Registered) R/T.................. .255 60'..................1.639 330'.................4.618 660'.................7.032 660’ mph........102.06 1000'................9.135 1320'...............10.929 1320’ mph…......125.38 Name of the track: New England Dragway Date of pass: July 21, 2018 Weather conditions: Temp in low 80s I think it was. Timeslip below, solo run in the left lane. |
