Old 03-30-2024, 01:24 PM   #14953
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
It's the ultra cheap plastic cubby from the LT / 1SS
https://www.gmpartsdirect.com/oem-pa...panel-84004284
Thanks.
Wife and both have Pixel 6 Pro's and neither fit in that tiny ass space. It would be semi-convenient for it to actually accept one of our phones and work.
I'm contemplating hacking up one side of the console itself to make some more space and see how bad it actually looks to make the phones fit.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 03-30-2024, 04:12 PM   #14954
Camby
Camby's Avatar
Drives: 2023/2SS/1LE/RadiantRed/A10
Received and assembled this water deionizer for the Camaro, hoping to never again have to touch it with drying towels after a wash
We'll see how well it works, TDS here is in the low 100s, so water from the hose must not be left on the car for more than a few minutes.
That’s awesome! One of my goals too. I heard from pantheorganizer (or someone else maybe) that running it after the water softener improves the life of the deionizer filter material significantly while bringing water hardness down closer to zero. I plan to run a line into the garage from the basement for it when I can finally get one.
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
Camby is offline   Reply With Quote
Old 03-30-2024, 05:57 PM   #14955
Originally Posted by speedyink1 View Post
Did not know those were a thing.
You mean....I could not have to dry my car to avoid the spots? I use a battery leaf blower to avoid contact with the clearcoat with a light wipe to get residuals, but if I could skip that whole step that'd still save me some good time.
I finished the first test wash about an hour ago, and this thing is ***** amazing. TDS down to zero, water nicely rolling off the car and no spots after rinsing. Skipping the drying phase helps with "quality control", too, I got to see where I accidentally left bits of dust and dirt in place.
It was a bit nerve wracking to leave water on the car after all these years of trying to stay out of the sun and drying/wiping almost immediately, but the paint is super clean and truly spotless, very impressive. Saved me a ton of time and towels, too.
During the short "brake rust scrape off" drive afterwards I rolled the windows all the way down and back up, which of course smeared them with water, but it disappeared in 30 seconds leaving nothing behind (unlike before, when this meant having to clean them again).
The only regret I have is why the hell didn't I buy it sooner
Old 03-30-2024, 07:15 PM   #14956
Broooster
Drives: Sharkskin Metallic ZL1
I finally got around to installing my Soler Performance Throttle Body Controller, mainly for the "lock" feature, which works as advertised, but I'm sure I'll play with the settings also to get the most out of the unit itself.
Broooster is offline   Reply With Quote
Old 03-30-2024, 07:39 PM   #14957
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
I've been using their Simple Chuck for several months now. No spots, even in the hot Florida sun. Since it reduces contaminants in the water, the paint actually looks and feels better after each wash.
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods
BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune
BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP
LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit
SSShark is offline   Reply With Quote
Old 03-31-2024, 06:02 AM   #14958
Curr
Curr's Avatar
Curious about this, too...
Is it the same size as stock? Tune needed? Re-learn? Simple swap & go?
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Old 03-31-2024, 06:09 AM   #14959
sklippi2018
Drives: 2021 ZL1 A10
Very impressive.
sklippi2018 is offline   Reply With Quote
Old 03-31-2024, 12:15 PM   #14960
Broooster
The TB controller is just a little thing that plugs into the gas pedal. It allows for amplifying the gas pedals signal to the throttle body. One of the features that it has is a "lock" feature that kills the signal to the TB, so you can press the pedal all you want, the car will just idle. I really like the new model, it is bluetooth controlled so the screen part of the controller can be disconnected once it is paired with your phone. Or you can leave the screen part of the controlled mounted in your car, your choice. Check them out on the Soler Performance web site.
It's plug and play, no tune, and a fairly easy install (and removal if needed)
Old 03-31-2024, 01:05 PM   #14961
paradigm
Drives: 2022 Camaro 1SS 1LE
Installed a Corsa NPP axle back exhaust on my 2022 Camaro SS 1LE yesterday, and I am super happy with the sound:
paradigm is offline   Reply With Quote
Old 03-31-2024, 01:09 PM   #14962
Ha, yours was probably an even better deal with its higher capacity Great to hear it works well even in Florida, meaning I don't have to worry at all with our 95-98° max temps and lower humidity.
It's incredible to see how much less problematic city or well water would be if it weren't full of minerals and sediments and whatnot...
(We already have a 3-stage whole house filter, but I still had to buy the DIC-20 because the garden faucets are split off before the filter. It's just the way this house was built back in the day, super difficult to change without redoing the entire frikken plumbing literally from the ground up, which I'm nowhere near ready for.)
Originally Posted by sklippi2018 View Post
Very impressive.
Old 03-31-2024, 01:16 PM   #14963
Curr
Curr's Avatar
Ahhhh just the controller part!! I thought you had to use it in conjunction with the actual throttle body.
Thanks for the update (and yeah, had I just went to their webstite..)
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Old 03-31-2024, 01:49 PM   #14964
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
I bet it was nerve wracking not drying it off
Holy smokes, cool to hear it works so well! While my water doesn't sound as bad as yours, this is still something I need to invest in at some point. I only seem to have to contend with water spots in the summer heat around here, but what a time suck (I need both towels and leaf blower that time of year, I love the black color but hate it as well..). Not to mention I'd just feel better about the water I'm washing the car with.
Good to know, thanks!!
speedyink1 is offline   Reply With Quote
Old 03-31-2024, 01:55 PM   #14965
Ray3768
Ray3768's Avatar
Drives: 1977 Trans Am, 2024 Camaro 2SS
Today I swapped the factory SS push to start button with a ZL1 push to start button. Adding up-trim parts is certainly my jam. I decided to retain the stock silver bezel in lieu of the ZL1 piano black bezel because it makes the button visually pop a bit more. Watching this video made it easy, only took 10 minutes:
Think I'll do the Caddy door strike trim next.
-Ray
Ray3768 is offline   Reply With Quote
Old 03-31-2024, 08:51 PM   #14966
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Have you guys seen the waterdrop system, it's on sale atm and has good reviews. Has anyone had any hands on experience with it? Our hard water is 323 ppm and 19 gpg, so I don't think I'll have much luck with any of them.
