03-26-2021, 07:59 AM | #14771 | |
Drives: 2017 2SS 50th Anniversary Edition Join Date: Aug 2011
Line lock is what’s on the ZL1 that holds the front brakes so you can roast the rear tires. Sent from my iPhone XS Max using Tapatalk
1100 - 04/29/16 | 2000 - 05/03/16 3000 - 05/04/16 | TPW 6/6 - 05/09/16 3100 - 05/25/16 | 3300 - 05/28/16 3400 - 05/31/16 | 3800 - 06/14/16, #125 Built! 4200 - 06/29/16 | 5000 - 06/29/16 6000 - 07/08/16 | Club F1FTY |
03-26-2021, 10:50 AM | #14772 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
The 2017 Camaros DEFINITELY have launch control. Need to be in Sport or Track mode. Double-tap traction control button to enable Competitive Mode. Then follow the other steps as posted above. You must hold the brake pedal all the way down (hard) before pushing accelerator to the floor briskly. If you don't press the brake hard enough, RPMs won't set and it won't work.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
03-26-2021, 01:43 PM | #14773 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
fROM PAGE 241 OF THE 2017 OWNERS MANUAL....
Launch Control A Launch Control feature is available, within Competitive Driving Mode, to allow the driver to achieve high levels of vehicle acceleration in a straight line. Launch Control is a form of traction control that manages tire spin while launching the vehicle. This feature is intended for use during closed course race events where consistent zero to sixty and quarter mile times are desirable. Launch Control is only available when the following criteria are met: . Competitive Driving Mode is selected. . The vehicle is not moving. . The steering wheel is pointing straight. Manual Transmissions . The clutch is pressed and the vehicle is in 1 (First) gear. . The accelerator pedal is rapidly applied to wide open throttle. The Launch Control feature will initially limit engine speed as the driver rapidly applies the accelerator pedal to wide open throttle. Allow the engine rpm to stabilize. A smooth, quick release of the clutch, while maintaining the fully pressed accelerator pedal, will manage wheel slip. Complete shifts are described in Manual Transmission 0 229. Automatic Transmissions . The brake pedal must be firmly pressed to the floor, equivalent to a panic brake event. . The accelerator pedal is rapidly applied to wide open throttle. (If the vehicle rolls due to wide open throttle, release the throttle, press the brake pedal more firmly, and re-apply the accelerator to wide open throttle.) After the vehicle is launched, the system continues in Competitive Driving Mode. Competitive Driving Mode and Launch Control are systems designed for a closed course race track and not intended for use on public roads. The systems are not intended to compensate for lack of driver experience or familiarity with the race track |
03-26-2021, 05:50 PM | #14774 | |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
That's for the A8 not the manual trans. |
03-27-2021, 12:14 PM | #14775 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Thanks for the info, guys.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
03-28-2021, 09:18 AM | #14776 | |
Drives: 2SS FIFTY Join Date: Oct 2018
I ONLY FOLLOW GOD. PRE
“LA MAKINA” |
03-28-2021, 09:20 AM | #14777 | |
“LA MAKINA” |
03-28-2021, 09:23 AM | #14778 |
I leave you the ebay link of the Chinese who sells my design.
Regards https://www.ebay.com/itm/Car-Door-19....m46890.l49292
“LA MAKINA” |
03-28-2021, 09:33 AM | #14779 |
Message 14094, page 1007, they appear as the projectors are, although it is not the same projector model of the advertisement, the Chinese manufacturer makes it in a cylindrical projector to integrate it.
“LA MAKINA” |
03-28-2021, 09:41 AM | #14780 | |
“LA MAKINA” |
03-28-2021, 12:03 PM | #14781 | |
Thanks for the link! Sent from my iPhone XS Max using Tapatalk
03-30-2021, 07:35 PM | #14782 |
Drives: 2017 Camaro SS FIFTY Join Date: Dec 2016
03-30-2021, 09:03 PM | #14783 | |
Drives: '17 2SS H50 Vert Join Date: Apr 2016
Diode Dynamics Smoked Side Markers, GM Dark Tails & CHMSL, GMPP-CAI, Mishimoto Catch Can [Pics Here] |
04-05-2021, 09:40 PM | #14784 |
Getting an intermittent “Service air bag” alert. I’ve already had to have the driver’s seat bag replaced but that was under warranty. Tried pulling codes but my code reader isn’t showing any active or stored codes. I see a dealer visit in my future.
Tags |
50th, club fifty, f1fty, fifty |
