Old 02-28-2024, 10:02 PM   #14771
Originally Posted by Bumbleboy92 View Post
Installed OEM footwell lighting
Install was in theory simple but man it sucked soooooo much. I understand the elder folk not wanting to go under the dash as my back still hurts
The bright side, at night it looks great and integrated into the OEM lights, interestingly it takes the same channel as the top section of lights on the doors and radio. I’m sure another wire is meant for the bottom section/cupholder. Fairly certain all it would take is some similar gauge wire and extra LED’s from a donor which I have somewhere to get even more lighting but we’ll see if I ever go under the dash again
Originally Posted by CalgaryZL1 View Post
I like the way it looks, but you just convinced me to skip this upgrade. Your comments brought back memories of installing my integrated front view parking camera that requires installation underneath and behind the glove box.
Originally Posted by SS_Don View Post
I installed this myself also. The hardest part, for me at least, was getting the bottom cover on the passenger side reinstalled. Had the hardest time trying to find the screw holes.
Let me echo these sentiments. When I installed this kit, I swore to never lie again in the passenger footwell upside down, head deep into the footwell and legs on the seatback, trying to reinstall the two rear bolts, grrr. However, the kit definitely adds a lot to the interior ambience, it was worth the pain.
Old 02-29-2024, 01:47 AM   #14772
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
The fear’s there, it took me two hours but two days later I’ve still got a slight crook to my back
100% the longest thing it took, I got one screw in and then the other three would not go in or I couldn’t feel around to find them. Then I also realized one of my main harness wires was in front of the AC ducts causing the whole bottom cover to not be flush which I realized after many attempts
Also I found I could just push the other end of the two pins holding in the glove box after failing to pry them out like the Gen5DIY and many videos said to, got them both out within a minute while my prying attempt took almost 10 minutes
Too many positions in order to fit even one hand, a few times I thought I actually was stuck and had a mini panic but thankfully got out. The frustrating times were when I had the flashlight just right, my position was perfect to see or feel the screw, and the screw or socket was in reach but at my position I could not get it so completely out I went and restarted
But I have to agree, the nighttime ambience is much nicer with the kit, glad I did it but doubt I’ll go back down there again
2016 1LT v6
- Totaled
Happiness: Infinite
Old 02-29-2024, 07:52 PM   #14773
biggjonn
biggjonn's Avatar
Drives: 2017 SS 50th Anniv #241 6M
. . . . Kool Shift Knob!!!
[QUOTE=Buellrider;11407389]Speed Dawg shifter with Barton adapter.
I want to replace my shift knob ... I was checking this out
2017 Camaro SS 50th Anniv .. Stick.
biggjonn is offline   Reply With Quote
Old 02-29-2024, 08:29 PM   #14774
david_acm
david_acm's Avatar
Drives: LT1
I ordered the gear shift emblem but they sent the wrong one...
Other than that, installed the door striker covers, changed my rear diff fluid, and cleaned the engine bay a bit.
david_acm is offline   Reply With Quote
Old 03-01-2024, 02:19 PM   #14775
IndyZrider
IndyZrider's Avatar
Drives: 21 SHOCK ZL1 M6
Had the mirrors painted black and mounted my wang! Gonna put the exhaust and rear suspension parts on this weekend....
IndyZrider is offline   Reply With Quote
Old 03-01-2024, 02:31 PM   #14776
ZPirate
ZPirate's Avatar
I'm SHOCKED by how good your car looks.
Seriously, nice job. I've been thinking about having my mirrors painted Mosaic Black to match the other Mosaic Black trim on the car.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 03-01-2024, 03:18 PM   #14777
cmrothenb
cmrothenb's Avatar
Drives: 2021 Camaro 1SS
Finally installed the the 1LE v2 (84486681) front splitter on my 1SS Sunday afternoon.
On a minor install note, also installed an all metal ODBII port lock and the fob operated circuit cutoff. I'll skip the details of that though..
Oh, you may notice in the pics that 1 set of the 2x4 wheel blocks has 5 tiers and the other 6. My jack could not clear the 6 by a 1/4 inch, so I took it down to 5. I ended up making all four that I built 5 teirs afterward , as that seems enough for my needs.
cmrothenb is offline   Reply With Quote
Old 03-01-2024, 07:06 PM   #14778
Iconic
Miller Time Wisconsin
Iconic's Avatar
Drives: '24 VOM 1SS 1LE M6. 1 of 4
Location: Formerly USA, now planet of the apes bizaroworld
That 1LE splitter really sets the car off very nice.
2024 1SS 1LE M6 rockcrusher in Vivid Orange Metallica. 1 of 4
Iconic is offline   Reply With Quote
Old 03-01-2024, 07:17 PM   #14779
IndyZrider
IndyZrider's Avatar
Ty sir ....the mosaic black does look good!
Old 03-02-2024, 09:35 PM   #14780
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Bought some Satin Pearl White and made some stripes. Not sure I how I feel about them yet, or whether I’ll do part of the trunk too. Either way, it wasn’t a bad way to spend a couple hours.
Old 03-03-2024, 12:28 AM   #14781
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
What if you went with some dark charcoal gray stripes, I think it would look great and much less "in your face" but yet a "subtle strong look"...
Old 03-03-2024, 08:06 AM   #14782
Chutzpah
Chutzpah's Avatar
We’re on the same page I already ordered charcoal gray (as a back up plan) If the sun ever decides to shine around here, I’ll get a better idea if the white is too much for me.
Old 03-03-2024, 10:43 AM   #14783
ZPirate
ZPirate's Avatar
It does. I replaced my ZL1 rear spoiler in Summit White with a Mosaic black ZL1 spoiler. Looks so much better and is a perfect match to the other Mosaic black trim on the ZL1.
Old 03-03-2024, 01:52 PM   #14784
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I've been wanting a black spoiler for my zl1 as well. I just had to get the 19...rip. Looks great man!
