Old 01-20-2024, 09:21 AM   #14603
LeonardS
Originally Posted by TX18ZL1 View Post
LEDS…
First time she was on a left and I saw this handwriting from the factory… ideas?
Attachment 1144957
Rear end setup measurements from the factory.
94 Z28, Black, M6, 595 miles
69 Z28, Dusk Blue, M4
29 Ford Business Coupe
28 Ford Pickup
24 GMC Denali 2500HD CCSB 4x4
22 Jeep Grand Cherokee
13 Ford F150 Crew Cab 4x4
Old 01-20-2024, 05:28 PM   #14604
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Finally got the lowers with the factory holes to put on rear black wing deflectors, and the car sits high enough in the rear to fit my Guinness! It’s was easier to pre install the new deflectors on the replacement arm before installation and didn’t require spacer that comes with the kit, that I didn’t realize they sold before I bought them individually. Now the hard part (due to laziness ) is taking the wheel off and cutting the dust shield.
Old 01-20-2024, 06:11 PM   #14605
CalgaryZL1
CalgaryZL1's Avatar
LEDS…
Attachment 1144957
I don’t have any dial-in reference numbers on mine?
Old 01-20-2024, 06:14 PM   #14606
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
Not a lot to do here but wait for spring...
But at least I can feel better about theft in the mean time! These showed up today.
Amazing for my 2nd keyfob I leave in my house. A tad bulky for everyday carry but I'll make it work.
speedyink1 is offline   Reply With Quote
Old 01-21-2024, 12:27 PM   #14607
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Originally Posted by SSShark View Post
It comes as a package which covers an area 9" x 17'.
Consists of 68 tiles of each color. It just sits on top of the concrete, not stuck.
That looks good! I was thinking about having the whole garage done when I moved a couple years back, but other prioritie$ took precedence. Where did you pick that package up from? It included that edge and corner trim?
Old 01-21-2024, 12:49 PM   #14608
As an alternative, I bought RaceDeck CircleTrak tiles directly from the manufacturer, a 17' x 18' pad that I laid down in a standard size 20' x 25' garage cost $1500 including everything (tiles, edges and underlayment).
I'll also note that a circular surface pattern is much easier to clean that a diamond one, which I learned the hard way.
Old 01-21-2024, 03:53 PM   #14609
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Looks fantastic arpad_m. Great color combo. I went with Swisstrax Diamondtrax tiles.
SSShark is offline   Reply With Quote
Old 01-21-2024, 06:28 PM   #14610
Thank you very much. That product is the best when it comes to plastic garage floor tiles, Sir, great choice on your part as well I just had a super hard time keeping diamond pattern edges clean in my previous garage, that's why I went with a circular pattern this time.
Old 01-21-2024, 06:38 PM   #14611
SSShark
SSShark's Avatar
It's only been a couple of weeks since I've had mine, but so far, so good. The finish seems to be very pretty easy to keep clean. I'll keep you posted as time goes by.
Old 01-22-2024, 02:09 PM   #14612
sactownbwoy
Drives: '22 Camaro ZL1 1LE A10
Because why not and it's mostly for car shows.
sactownbwoy is offline   Reply With Quote
Old 01-22-2024, 02:30 PM   #14613
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
printed the sound tube delete parts in ABS. Also printed a an engine coolant cover in ABS. Will install this week.
I have an O-ring for the intake manifold plug, and will use a butyl rope around the firewall plug.
the engine coolant cover could have benefitted from a raft as some of the internal tree supports came loose, but it's easy enough to clean up the underside that isn't seen anyway.
Daily Driver mileage update: 64k mi. @ Apr 2026
Old 01-23-2024, 12:52 PM   #14614
ZPirate
ZPirate's Avatar
Picked my ZL1 up from having XPEL PPF installed on the front facia, the front lip, the headlights and the part of the front fenders closest to the front facia. I have the same set up on my 1LE and it has done a great job of protecting the front of the car.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 01-23-2024, 01:33 PM   #14615
SSShark
SSShark's Avatar
Hey ZPirate, pricey but man is that stuff is worth it
Old 01-23-2024, 03:45 PM   #14616
ZPirate
ZPirate's Avatar
Hey ZPirate, pricey but man is that stuff worth it
Most definitely.
