Old 12-09-2023, 02:50 PM   #14449
TurtleSS
TurtleSS's Avatar
Drives: 24 Camaro 2ss 1le M6 Riptide
Washed and installed the roto fab (was extremely simple, but the directions aren’t clear on removing the expansion can and plug from the stock elbow)
Ordered: 2024 2ss coupe 1LE Riptide
Placed 8/29/23 1100
9/29/23 - 9/30/23 found and picked up same car in stead
10/5/23 order still at 1100
TurtleSS is offline   Reply With Quote
Old 12-09-2023, 07:51 PM   #14450
Socal Shock
Socal Shock's Avatar
Drives: 2020 SS
New spoiler.
Very nice. What are the details?
Socal Shock is offline   Reply With Quote
Old 12-10-2023, 03:32 AM   #14451
Chevelle vs Camaro
Chevelle vs Camaro's Avatar
Drives: 2018 Camaro SS
Originally Posted by 02WhiteWs6 View Post
reupholstered one seat with leather. I'll save the rest for next week.
If those wrinkles don’t work themselves out, look up steaming leather seats on YouTube
Chevelle vs Camaro is offline   Reply With Quote
Old 12-13-2023, 12:31 AM   #14452
Chevelle vs Camaro
Got some new Conti DSw06+ all the way around…
Old 12-13-2023, 12:42 AM   #14453
Mr. Tallahassee
Mr. Tallahassee's Avatar
Drives: Red 2018 Chevy 1LT RS Package
Lot of crusing
Mr. Tallahassee is offline   Reply With Quote
Old 12-13-2023, 12:56 AM   #14454
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Well, not today, but tomorrow, installing some RST P1X Lowering Springs from Phastek... Supposed to give a 1.25" drop on MRC cars... I'll be sure to get some before and afters... When I went from my stock SS wheels/tires to 1LE spec wheels/tires, I picked up about a 1/2" of wheel gap (and I thought the gap was a little excessive before the new wheels/tires) so hoping this will look really good and give the car a very aggressive stance... I still want some fender/tire gap but just nowhere what I have now (which is only maybe 0.50" to 0.75" more than my buddies 1LE), I just don't want it to look like a ricer with the tires all up in the wheel wells, but I don't think that will be the case...
So, I found out today that some of the bolts that need to be removed on the rear are in fact TTY (Torque-to-Yield (i.e. Single Use)) bolts, so that added about $60 to the project... Funny on all the install videos no one ever mentions replacing the bolts (and I'm sure many don't) but I'm going to just to do things per the Service Manual... (I'm still short 1 bolt but picking that up in the morning...)
Old 12-13-2023, 09:42 AM   #14455
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
I actually did this job a couple weeks back installed Eibach 1LE pro kit springs. For the rear, I used the method in Lethal's video and instead of undoing all the outer arm bolts, I only did the one inner LCA bolt which made things a lot faster. If you have aftermarket exhaust though, the passenger side LCA will hit the exhaust when lining back up. I had to wedge the exhaust sideways to swing the LCA up to line back up. Definitely helps to have a second set of hands there.
https://youtu.be/zTTdWRUchow?si=4baOUsro3QDgJ1N_
Build thread for photos
https://www.camaro6.com/forums/showt...=612717&page=4
SSEssence is offline   Reply With Quote
Old 12-13-2023, 06:44 PM   #14456
2SS Capt
2SS Capt's Avatar
After doing some measuring we decided the P1X springs were going to be too much of a drop so postponing the project for now, may go with the Eibach lowering springs instead as they only drop about 1" or slightly less...
Old 12-13-2023, 07:08 PM   #14457
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Damn, I was hoping to see that ricer look!
Old 12-13-2023, 08:51 PM   #14458
2SS Capt
2SS Capt's Avatar
Did you do the spring replacement on a lift? Or QuickJack?
The job doesn't look too difficult overall...
Old 12-14-2023, 10:27 AM   #14459
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
Was doing a walk around today, making sure everything was staying mostly dry and all that. Was looking underneath and noticed the exhaust...are they supposed to look this derpy? I mean...I don't know how they would **** that up at the factory, but my mind needs to know, lol
(To be clear it's the "crimped" section I'm talking about)
speedyink1 is offline   Reply With Quote
Old 12-14-2023, 10:37 AM   #14460
SSEssence
Instagram: Sangstah
Did it by myself in the driveway with a standard jack and suv jack stands. Not too bad, took me 4 hours from start to finish and I installed CT5 blackwing front brake ducts and oil change while I was under there.
Old 12-14-2023, 10:39 AM   #14461
SSEssence
Instagram: Sangstah
Yup the factory crimped section is normal. Most people replace it with an aftermarket exhaust or x pipe.
Old 12-14-2023, 01:24 PM   #14462
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Yep - normal. GM in its wisdom to make “one size fits all” crimps all models of exhaust this way as the convertible models need the clearance for some underside bracing. FWIW - numerous people report that this crimped section is not causing any measurable power restriction at stock power levels.
476 rwhp/440 rwtq (sold)
