#14407 |
![]() Drives: 2024 2SS 6MT Join Date: Dec 2019
Did my break-in (~1500 mile) engine and rear diff oil changes. Tried getting to the plug for the skip shift eliminator install but my hands are too fat. Decided to call if a day before I broke something…I’ll give it a go another day.
It was fun getting the car up on four jack stands for the first time.
Current: 2024 Camaro 2SS M6, Red Hot, Ceramic White interior, Dual Mode Exhaust, Magnetic Ride Control
Old & Sold: 2019 Camaro 1LT M6, RaceChip GTS, RaceChip XLR, ZZP Catted downpipe, JacFab Boost-o-lator, K&N drop-in air filter, ZZP Intake Tube, PTP turbo blanket, NGK 6510s gapped at 0.022" Motorcycle enthusiast |
#14408 |
![]() Drives: '24 ZL1 A10, '70 Olds 442 W-30 Join Date: Sep 2023
#14409 |
![]() Drives: 2024 ZL1 Join Date: Apr 2023
I drilled 4 holes in the back of the car. I thought it was metal but turns out it's just plastic.
#14410 |
![]() Drives: '23 1SS 1LE Shadow Gray Join Date: May 2022
Finally blacked out my wheels. Turned out much better than I expected
#14411 | |
#14412 | |
![]() Drives: 2023 Camaro 2SS - Summit White Join Date: May 2023
Found here |
#14413 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Speaking of car covers. I was not going to put my cover on during storage but the other day it was so nice here for two days I took it out for a ride. But I did notice that the pipe for the fire sprinkler system was dripping water droplets with rust on car. So I ended up putting the cover on.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
#14414 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
#14415 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Ya RPM is up there for sure. Not sure if they lock ECM's or not, but I know Katech and Livernois does.
#14416 | |
Moderator
#14417 | |
#14418 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
It was a nice weekend decided to drive it on Saturday afternoon when it warmed up. Had a blast.
![]() Sent from my iPhone using Tapatalk Pro
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#14419 | |
![]() Drives: 2024 2SS 1LE Join Date: Aug 2022
Suck that I needed to pull the strut tower brace to get to the bottom chamber service port.
2024 2SS 1LE | 6MT | PDR | Riptide Blue Metallic | Bought - 10/14/23
2024 2SS 1LE | 6MT | PDR | VOM 1100 - 9/29 9000 - 10/31 |
#14420 |
![]() ![]() Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
No problem. The top tank shouldn't need to be topped off, it should naturally pull from the reservoir tank on the bottom. Not a big deal if you were just half an inch below the line, always good to keep an eye on it though.
