Old 11-18-2023, 10:04 PM   #14393
SnakeEyeSS
SnakeEyeSS's Avatar
Drives: Camaro 2SS & ZL1
Originally Posted by Camby View Post
Manual says 5w30 is fine for street. Am I missing something here?
Yup, it says 5w-30 Dexos R, of which there is none yet, AFAIK.
Page 237.
If you were reading 236, that's for the 4/6 which says 5w-30 Dexos 1
Maybe a typo, but that is what it says.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red
SnakeEyeSS is offline   Reply With Quote
Old 11-18-2023, 10:20 PM   #14394
Okay, let me try to steer this away from the endless oil weight back and forth: I've just installed a GM carbon fiber shift knob on my car, a nice little touch to the interior. Best of all, I managed to install it with zero damage or scratches to anything in the car, yay. What a long way from my early days with my Grand Am, back then I was afraid to change a bulb, heck, even to pop the hood, no kidding.
That said, there is always a lesson or two to learn, this time it was that there is simply no way around manhandling the shift knob for removal, the plastichrome ring between the boot and the leather wrapped top section of the knob is practically impossible to remove with the knob still on the shaft, no matter what youtube says.
In order to spread the hog ring holding the knob in place, the ring would have to come off, but there is simply no vertical room inside unless a very special tool exists for this single purpose. The good news is that the knob comes off with medium force, no danger to the screen or anything else, and then the plastichrome ring can be removed using two small flatheads or picks that can act as wedges.
Old 11-19-2023, 12:31 AM   #14395
SnakeEyeSS
SnakeEyeSS's Avatar
Bet it goes well with your wheel!
I need to have mine warrantied when I go in, the ZL1 was faded from the factory. Kinda confused how QC missed it.
Old 11-19-2023, 03:51 AM   #14396
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Okay, let me try to steer this away from the endless oil weight back and forth: I've just installed a GM carbon fiber shift knob on my car, a nice little touch to the interior. Best of all, I managed to install it with zero damage or scratches to anything in the car, yay. What a long way from my early days with my Trans Am, back then I was afraid to change a bulb, heck, even to pop the hood, no kidding.
Very nice! I have the same one but been putting off install since I’d have to take apart the knob to swap the covers instead. I want to keep the suede and combine it with the CF top
2016 1LT v6
- Totaled
Happiness: Infinite
Old 11-19-2023, 07:48 AM   #14397
Thanks, brother.
Replacing the cover will be two extra steps, there is a black plastic frame you need to remove (before accessing the two screws holding the cover in place), which I'd be a bit wary about because it's visible and no matter what you wedge between it and the knob, I have no idea how not to scrape it.
Old 11-19-2023, 08:36 AM   #14398
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
Good to know, I'll have to keep this in mind. I want to replace my shift knob with one of these sometime soon. Mine has several dings in it from the previous owner, which drives me crazy because I take good care of my stuff. Not even sure how you'd make those small dings in it.
My Camaro Journal
Old 11-19-2023, 01:22 PM   #14399
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Originally Posted by IndyZrider View Post
Out of curiosity.....why did you go to cbi over katech since you live in Michigan?
Price is the big reason, the second reason is they were referred to me by a Camaro person on here.
I know Katech is known in the industry, but they are almost 2 times more expensive than Livernois, and I don't want Livernois to do the work for me either.
The last reason is because I don't like the fact some of these shops lock out the ECM after tuning, which forces you to go to them for any further tuning needs. I don't like having my hands tied behind a pay wall.
Old 11-19-2023, 02:18 PM   #14400
IndyZrider
IndyZrider's Avatar
Drives: 21 SHOCK ZL1 M6
ah...didnt know they lock the ecm like that...been looking at katech or rpm for my build and tune....
IndyZrider is offline   Reply With Quote
Old 11-19-2023, 04:02 PM   #14401
Anjilslaire
Anjilslaire's Avatar
Drives: 2021 3LT RS A10
Installed some floormats
3D MAXpider Custom Fit KAGU Floor Mat (BLACK) Compatible with CHEVROLET CAMARO 2016-2023 - Front Row https://a.co/d/cngbsTu
Anjilslaire is offline   Reply With Quote
Old 11-19-2023, 04:07 PM   #14402
ZPirate
ZPirate's Avatar
Did the same thing over the weekend in my ZL1. I have them in my 1LE too. Best all season mats available.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 11-19-2023, 04:26 PM   #14403
dfwcowboy
dfwcowboy's Avatar
Drives: 2024 ZL1 M6, 1978 Beechcraft Baron
I did the same thing in mine. I also had them in my 2018, which was totaled. I regret not taking them out because they still looked new after 4 years.
dfwcowboy is offline   Reply With Quote
Old 11-19-2023, 05:31 PM   #14404
MattZ
Drives: 2023 Camaro 2SS - Summit White
Tucked my baby in for a long Michigan winter
MattZ is offline   Reply With Quote
Old 11-19-2023, 08:52 PM   #14405
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
Have had those in my car for the last 7 years and they’re holding up very well. Good choice!
STYLO LT1 is offline   Reply With Quote
Old 11-19-2023, 09:29 PM   #14406
zedts1986
zedts1986's Avatar
Drives: 2024 2SS 6MT
Did my break-in (~1500 mile) engine and rear diff oil changes. Tried getting to the plug for the skip shift eliminator install but my hands are too fat. Decided to call if a day before I broke something…I’ll give it a go another day.
It was fun getting the car up on four jack stands for the first time.
Current: 2024 Camaro 2SS M6, Red Hot, Ceramic White interior, Dual Mode Exhaust, Magnetic Ride Control
Old & Sold: 2019 Camaro 1LT M6, RaceChip GTS, RaceChip XLR, ZZP Catted downpipe, JacFab Boost-o-lator, K&N drop-in air filter, ZZP Intake Tube, PTP turbo blanket, NGK 6510s gapped at 0.022"
Motorcycle enthusiast
zedts1986 is offline   Reply With Quote
