View Poll Results: Who has experienced an oil pump failure?
2016 or earlier 25 14.97%
2017 57 34.13%
2018 77 46.11%
2019 3 1.80%
2020 4 2.40%
2021 1 0.60%
Voters: 167. You may not vote on this poll
Old 09-20-2024, 11:48 PM   #1387
taylorforschool@gmail.com
PKG4U
taylorforschool@gmail.com's Avatar
Drives: 2018 ZL1
I’ll go ahead and be the guinea pig for everyone else. 5/18 build 20k miles and it’s going until at least 2028 when warranty is up until it gets a katech. Have 2020MY OEM pump if absolutely necessary in meantime but I’m gonna call the pot with my hand gentleman. Obviously will keep informed but after monitoring this thread and my own experiences im not as worried as some others
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S
Mods after Warranty “Imma keep it stock”
taylorforschool@gmail.com is offline   Reply With Quote
Old 09-21-2024, 01:15 PM   #1388
ZL1 C ya
ZL1 C ya's Avatar
Drives: 2018 ZL1 Camaro Convertible
So to be clear, you have a 2020 pump in the vehicle, or the 2020 pump is on the shelf just in case??
ZL1 C ya is offline   Reply With Quote
Old 09-21-2024, 06:17 PM   #1389
Z OH 6
Drives: 2021 Red Hot ZL1
2020 pump on the shelf just in case is what I read.
Old 09-21-2024, 06:51 PM   #1390
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
There's no flaw in the later pumps from 2019+. Its almost unheard of to see a failure in those years even with higher mileage. The very very few I've seen can be chalked up to normal wear and tear or just a factory defect that could occur on any part. I would say these pumps just aren't as robust as they should have been, certainly not like a Katech pump.
GM also change the oil viscosity change to 0W40 in 2019. No explanation was ever given for that. I changed my 2017 over to 0W40 at 15,000 miles. I never had an issue, till I chickened out and swapped out my pump for a Katech pump at 40,000 mile.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 09-21-2024, 07:03 PM   #1391
PKG4U
Drives: 2018 ZL1
Correct. Thanks
Old 09-22-2024, 08:17 AM   #1392
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
My car was fine until I changed the oil per their ZLE track prep sheet.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is online now   Reply With Quote
Old 09-22-2024, 11:32 AM   #1393
ZL1 C ya
ZL1 C ya's Avatar
What is your Build date???
Old 09-22-2024, 12:09 PM   #1394
nighttowl
nighttowl's Avatar
I think its 8/17
Old 09-22-2024, 02:47 PM   #1395
zain
zain's Avatar
Drives: ZL1
what happened?
zain is offline   Reply With Quote
Old 09-23-2024, 06:56 AM   #1396
gblaue
gblaue's Avatar
BTW, my build date was 11/16
Old 09-23-2024, 07:27 AM   #1397
nighttowl
nighttowl's Avatar
Originally Posted by zain View Post
what happened?
When i got back home I changed the oil and the idle oil pressure dropped 10 psi.
I took it to the dealer who had a chevy service engineer come out. He stated I installed the oil filter wrong and put the wrong oil in it. They did an oil change and sent me on my way. I said it was BS and the car was not fixed but was told nothing more would be done.
I didnt realize at the time what was really happening, which was that they were effectively voiding the warranty.
When the pump finally gave out Chevy customer service said I f%cked it up when i installed the oil filter wrong and put the wrong oil in it. They offered to pay 5k but only if a chevy dealer would do the repair, but the chevy dealer would not touch the car unless it was to replace the entire engine.
I had Wragth repair it. They pulled the engine, there were metal shards from the blades in the pump breaking up in the pan and main oil passage from the pump.
The main bearings were worn through the babbitt, but the rod bearings were OK. the Main bearings were replaced and I went with a Katech pump along with a cam install.
Old 09-23-2024, 07:36 AM   #1398
Z OH 6
I would say coincidence, its unlikely a fresh oil change would cause the oil pump to break. I think it was just time that yours finally gave up the ghost.
Old 09-23-2024, 07:43 AM   #1399
jvandy50
Drives: 18 ZL1-1LE, 10 JKU
Probably so, but I wonder if the heavier 15w50 could have changed anything (or he did say wrong oil, so I'm assuming here also)
jvandy50 is offline   Reply With Quote
Old 09-23-2024, 09:59 AM   #1400
nighttowl
nighttowl's Avatar
I suspect the pump was a bad one, but I think it was the 15-50 that destroyed it.
