#127 | |
As to octane boosters, those that actually work all contain MMT and are thus technically illegal for street driving, maybe the caveat is a standard disclaimer.
#128 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
So you are correct, An LT4 fuel system will be required to run any E contents above E-10 Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#129 |
![]() Drives: White 2024 1SS M6 Join Date: Nov 2023
I was watching a video the other day from one of the popular Camaro shops on the east coast. They were doing a LT1 M6 car that dyno'd around 406 whp stock from the factory. They went with a full bolt-on set-up, cam, heads, 2" headers, exhaust, MSD intake, CAI, and Flex fuel. They ended up picking up about 210 whp with factory fueling. I was wondering, if a boosted set-up needs fueling to add 200 whp, why wouldn't a NA build need it as well ?
#130 | |
Yeah, I'm aware of E85 requirements. Surprised there is any headroom at all for the blower with the stock LT1 fueling. I had a FBO/E85 C7 that was running at 85% IDC, for all practical purposes maxed out. Sorry for the drive-by posting earlier, had limited time. Here's the installation instructions for the supercharger kit. (page 2) https://cdn.shopify.com/s/files/1/05...f?v=1709848646 Also, page 1 has a corrosion warning. Last edited by tortilla-flats; 12-02-2024 at 03:25 PM. |
#131 |
Thanks. Wondering if that voids the warranty from Magnuson if you up the fueling bits?
#132 | |
![]() Drives: 2022 Camaro 2SS 1LE Join Date: Nov 2021
d1sc w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, mamo ptb, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
#133 |
Another question on the TVS2650 kit. Does the included tuner preserve the AFM/DOD functionality or is it turned off?
#134 | |
![]() ![]() Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
#135 | |
So just using random numbers... due to parasitic losses associated with FI, a FI set-up really needs enough fuel to make say 50 more hp than a NA motor to net the same 200 whp gain ? |
#136 | |
I wouldn't say the "same" 200 hp. To make BIG power NA you usually have to sacrifice somewhere else, where an sc will typically increase across the board.
| Tags |
| gasoline, octane, supercharged |
