#127 |
![]() ![]() ![]() Drives: 2023 ZL1 - All Bolt On's Join Date: Dec 2022
#128 |
Quick update: Andrew at CSP Racing says "The Tune is Great" after 5 separate tweaks! So, the only thing left on my short list is to: 1) replace my steering wheel with my new carbon fiber one I got from carbonaddons, and 2) add the DSX Flex Fuel kit. Also, I've already made the decision that I will be shipping my ZL1 to Andrew's shop this fall for a stage 3 or stage 4 package ! Also, I will be getting my ZL1 on a dyno soon at a local speed performance shop that seems to have really good reviews !
#129 | |
![]() Drives: 2023 ZL1 Join Date: May 2022
2023 ZL1 A10 Convertible (copper-free brakes)
________________________________ 1973 Triumph GT6 2018 Mustang GT Convertible 2009 Viper Roadster 1970 Olds Cutlass Supreme Convertible 1967 Chevelle SS396 Convertible 2013 Corvette 427 Convertible 1965 Mustang Fastback (Shelby GT350 clone) 1969 Camaro RS/SS 350 Convertible 1967 Mustang Fastback 289 'HiPo' 2005 Viper SRT-10 Roadster 2003 Corvette Coupe 2001 BMW E46 M3 Coupe |
#130 |
#8ZL1Man - Love the red leather grips !!!
I got mine installed tonight! It took me about 5 minutes to complete ! Stock vs New carbon fiber! |
#131 |
Ugh... Started her up this morning to drive to my client, immediately noticed the [Service], [ESC] and the [Traction Control/StabiliTrak] warnings were on. I did a "Dismiss Message", and all but the [Traction Control/StabiliTrak] went off. Not sure if this is related to replacing the wheel, or if I'm back to a glitchy gauge issue like I was having before. Then, as I started driving, I noticed the wheel was probably a grove or 2 off center toward the left when driving straight. It bugged me enough that I pulled around the block and parked it back in the garage. A side note: When I took off the stock wheel to install the new one. Behind the wheel, there was a circular black plastic reel type part with two separate flat electrical ribbon cables (about 1/4" width) wound around it, both wound in the same direction. I've not been able to find any reference to what this is, or the proper procedure to make sure it's reinstalled correctly. I assumed just wined it around the disc, making sure it's not so tightly wound that when the wheel is turned all the way to the right, it doesn't over stress the ribbon cables or snap them? I have no clue!
Edit: I did find a video that shows this guy (Zander13) struggling with the same plastic disc part, but his didn't unspool and come off like mine did. Here is a screen cap showing the part: Edit #2: Found exactly a video from Muscle Car Central where he describes that no one else he saw replacing the wheel and he issue with the black plastic reel coming off... but he did and he warns that you should use a screw drive to push inward on the plastic ring to keep it from coming off with the wheel. It looks as if it's related to the "heated" steering wheel option. I'll re-do my install later this evening ! Last edited by 2023_ZL1-AUTO; 04-11-2023 at 10:03 AM. |
#132 |
I found out from my client who has a mechanic shop, that the part I'm referring to is called a "coil clock spring" assembly for heated steering wheels. He said make sure the winding allows free rotation fully in both direction the wheel can turn or it will snap/damage the electrical ribbon cable feeds. So I will re-do this later tonight and also fix the issue with the wheel not being dead centered while the wheels are pointing straight. That process I'm not looking forward to! How do you know the wheels are exactly 100% pointing perfectly straight before putting the wheel back on. You would think, GM would have a notched/keyed type slip on where you could only put the wheel on exactly where it belongs! Funny thing is, I can see in my stock wheel photo above, the wheel seems slightly turned to the right just a bit vs being exactly straight. I totally missed that when I put the new wheel on last night ! Live and learn !
#133 |
![]() Drives: 2023 ZL1 A10 Join Date: Nov 2021
Alignment machine , in the old days , not unless they have a new way of doing these days .
#134 |
It's really interesting... all the videos I watch people doing the wheel swap, they literally just pull off the old and slapping on the new. I guess I didn't realize my wheel was slightly turned to the right already. I will guestimate and try again and again until I get it right. It's crazy... I'm having a deja vu moment with this but not sure why since I've never replaced a steering wheel before!!!
#135 |
I'm sure you'll get it .
#136 |
#137 |
![]() Drives: 2023 Camaro ZL1 Convertible Join Date: Apr 2023
Carbon Fiber Interior
Hi all. New member but longtime lurker, I do want to thank all in this forum for the wealth of knowledge and advice. It's been very helpful through my researching exactly what it is I wanted to buy, and I'm pretty pumped to say I'm taking possession of my new '23 ZL1 convertible 6 speed in a couple days. (Sharkskin with carbon fiber hood insert)
I'm gonna take it easy on the mods until my factory warranty expires, but I'll be doing a Roto Fab dry CAI and an AWE touring axle back right away. I do have to say that for such an impressive piece of engineering, I think GM got a little lazy with the interior so I'd like to add a few carbon fiber inserts like what you've pictured already. Nothing too crazy, just to refine the inside a bit. It seems like everything I find just tapes on to the existing panels. For those of you who have used these does it look cheap or does it look like it could be factory installed? Can you tell it's a covering on the factory part? How's the fitment? The alternative would be to remove all the panels I want carbon fiber and have them dipped but I'm not sure if that's necessary. Thanks in advance |
#138 |
Not a good update! I managed to get the winding re-done, but in all my efforts try to do so multiple times. The flat ribbon cable has become wrinkles and now it makes noises when I turn the wheel. I will either need to attempt to order additional GM parts to replace that entire assembly or wave the white flag and take it to a dealer and have them repair it. OMG, this was the worse experience of doing add-on up to this point. Also, I'm still getting the warning messages like I did a few weeks ago such as Rear Axle System Off, ESC, Power steering Angle sensor error can't reach emergency position, and a few others. I'll leave the battery disconnected over night and see what it does in the morning. But I'm not comfortable really driving the car with that ribbon cable sounding so noisy.
#139 |
You can't DIY an unwound clock spring, time to head to the service department and cut your losses.
#140 | |
I do think the warning lights are just like last time I had them. It was caused by an electrical short, thus causing the warnings. Once I fixed the short (replaced the cable and gauge), everything was normal. This seems to be about the same issue, the ribbon cable is in bad bad shape at this point so I figure it's shorting out some where along the line. |
