#127 |
Here is screenshot of log. I am kind of surprised too tbh.its a little fat because the LTFT are positive and adding 3% on top but that shouldn't matter there is plenty of fuel system.
#128 | |
![]() Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
Something can’t be right in the cooling system for it to do that. Air in the lines, pump isn’t working, tank is really low on fluid… something. We’ve done several consecutive pulls on mine with no ice, and even if the temp starts higher with hotter water, it circulates enough to keep it around that temp on WOT.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
#129 | |
#130 |
Yea, it has a Rhodes 7.5 gal. tank. It's not flowing as spec'd. It should turnover the tank volume 4 or 5 times per minute. Sometimes MAT goes to 105, other times 140-160. Need a new pump... I think. It's not a pulley issue.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 11-13-2022 at 08:39 AM. |
#131 | |
A pump not moving the water as spec’d would definitely explain the issue. Easy fix at least.
#132 | |
Of course, I don't know what it did on the dyno with the 112mm because... I don't have any logs
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#133 |
High MAT and lost hp problem has mostly gone away but remains puzzling. MAT might be 150 on a pull and 120 the next. Could the thermostat cause this? Lowest temp today on last pull (at the track). Very odd.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 11-13-2022 at 08:09 AM. |
#134 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
#135 |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Lol. He is all over the place with his responses. He don’t know if he’s coming or going.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#136 |
Is your pump external or internal and what capacity? Rule 2000, or Rule 3700 or?
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 11-13-2022 at 08:38 AM. |
#137 |
It is a standalone Stewart EMP pump. They are rated at 7.7 gpm if I remember correctly.
#138 |
Rule makes water pumps with much higher capacities. Are higher volumes/min. a benefit to cooling?
2020 ZL1LE A10.
