Old 03-10-2022, 01:56 AM   #127
redcoats1976
nice...liking the color and stripe combo.
redcoats1976 is offline   Reply With Quote
Old 03-10-2022, 05:33 AM   #128
Gen6cyl
Gen6cyl's Avatar
Drives: Chevy Camaro 2021 ,rs, v6, manual
Thanks for the feed back on 87 vs 93.I can't say it makes more power on 93, it feels like it does.It does act better,runs smoother and sound better on 93.;That should be better for life of engine.
Gen6cyl is offline   Reply With Quote
Old 03-10-2022, 05:38 AM   #129
Gen6cyl
Gen6cyl's Avatar
Originally Posted by Wynotme View Post
I picked up my new Camaro 3LT V6. I love it! Smooth engine, nice power. Impressed by the ride and handling as well.
Good looking car.How much$
Old 03-11-2022, 03:40 PM   #130
Kontrol
Drives: 2022 Comaro 3LT
I have a V6 3LT on order and im very excited for it!
Kontrol is offline   Reply With Quote
Old 03-13-2022, 06:12 PM   #131
Wynotme
Drives: 2023 Chevrolet Camaro 3LT V6
Thank you! I originally was going to get Satin Steel, but so glad I went with the Riverside blue. I like the stripe since I do not see many with the side spear and it looks retro.
Wynotme is offline   Reply With Quote
Old 03-13-2022, 06:18 PM   #132
Wynotme
Thank you! Sticker price was $43,490.
Old 03-13-2022, 06:18 PM   #133
Wynotme
You will love it!
Old 08-07-2022, 03:57 PM   #134
Camrochris
Drives: 2020 Chevrolet Camaro 1LT 3.6L supe
NOBODY IS HAVING "clutch overuse warning light?
With the 2019-2022 3.6 1LT being hit hard woth these recalls that GM will not cover. It isn't a consumer use problem. Its a DEFECT. I have plenty of room for clutch engagement. I thing some sxrew wasnt torqued down correctly.
Camrochris is offline   Reply With Quote
Old 08-07-2022, 04:19 PM   #135
Camrochris
Exclamation "Clutch overuse warning light back again after 2000 miles. (8100 now).
You will love it!
Mine looks very similar. You need a suspensiom to lower the body down 1.5". I am really happy with my Bilstein Nordschliffe suspension with lowering springs. Coilovers in back and PSS dual action struts. It has 2 separate suspensions in one at the front. The bottom part absorbst potholes and whatnot while the top part is programmable to allow a lot of feel to very little. Very cool and well worth $1200. I am happy with the whole car excrpt the clutch. Did you know the brake master cylinder is shared with the clutch hydraulic system. They are poor bedfellows. Chevy kept the same master cylinder that used to go to the power steering and just re-routed it to the clutch. The only way I can drive my car is to brake lightly, drive lightly, and turn off trac and ESC OFF. AS WELL. That will give me 2 hours of drive time. SAD GM SAD.
EVERYTHING ABOUT THE CAR I Love other than the clutch. Even the lack of vision isnt really a problem. But hsving the car lurch back snd forth during shifts when the trans temp gets to 159°-185°
It just shifts poorly. No more snick snick onto gear when the brake/trans fuid gets high. I suspect the clutch itself us NOT the problem. Please give me advice if you can guys.
Old 08-08-2022, 01:21 AM   #136
Gen6cyl
Gen6cyl's Avatar
I got my car new 1-2-21 , it has 35 k miles now. The clutch has been the worst thing about the car. I can't say it has got any worse than when new, maybe I deal with it better. I drive with traction control off. I will try turning off tc and stability off to see if it helps.
Old 08-08-2022, 03:00 PM   #137
Anjilslaire
Anjilslaire's Avatar
Drives: 2021 3LT RS A10
Interesting. I just checked and there are no recalls for my 2021 3LT. A10, maybe?
Anjilslaire is offline   Reply With Quote
