#127 | |
![]() Drives: 2022 Camaro 2SS 1LE Join Date: Nov 2021
#128 |
![]() Drives: 21 Lt1 Join Date: Dec 2016
Haha right! If you did headers you can definitely do the PC. It comes with detailed instructions. Hardest part is getting the crank bolt out
#129 |
![]() Drives: 2016 Camaro SS Join Date: Jul 2020
When I work on my car if I am removing fasteners and such I put them in an old muffin pan, this helps me keep stuff organized and in 1 place for reassembly. Obviously if you are just doing a fresh install it might not be as useful, but you can lay everything out before the install and might help you stay organized.
#130 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
You can get a magnetic pan to hold all the little stuff. From Harbor Freight or similar place. Did Whipple myself and the instructions left some important things out (at the time) but it worked perfectly.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror ![]() |
#131 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2017
I haven’t re-read the whole thread, so this may have already been mentioned. I’d also replace the front seal with an ls3 seal.
#132 |
Ok guys just an update. So I finally got the new build done. 837 whp 719 Tq.
P1-X 12psi, Full E85 ARH 2” catless headers Katech ported stock heads Btr trinity Fore innovations LPE HPFP, +30’s Btr stage 2 blower cam. Forged internals. The before run was p1-x 9psi,MSD, lt4 stuff with DSX. I was running e30 blend prior to the dyno but had to drop it off with 93. It would’ve probably made another 10-15 whp I’m guessing. Trying to load the dyno sheet now Last edited by JP374; 06-14-2022 at 01:19 PM. |
#133 |
Dyno graph
#134 | |
![]() ![]() Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Also, what compression ratio did you go with your forged?
#135 | |
ARH 2” catless headers. 10.5:1. |
#136 | |
Moderator
#137 |
#138 |
Nice results!
#139 |
#140 |
Another update:
I put it back on the dyno last week for a new tune. It made 837whp 719 TQ originally when I picked it up from the shop that did the work. I put on my buddy’s shop dyno and it baselines at 761 whp with the original tune. After getting a new remote tune I ended up leaving with 874whp 742 Tq. Still 12psi on full e85. I think if we would have pulled it up to 7k it might have got closer to 900whp idk. The fuel system is tapped out and MS started to climb. Thx JP Last edited by JP374; 08-23-2022 at 09:55 PM. |
