#127 | |
![]() ![]() ![]() Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
Amazingly, the GT350R, despite being 200 lbs lighter than the ZL1 and obviously without a S/C, is also 54/46. CURB WEIGHT ZL1: 3,912 lb GT350R 3,713 lb WEIGHT DIST, F/R 54/46% 54/46% For further comparison, the base GT500 is 4,171 lbs and 56/44. GM did a better job with weight distribution.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
#128 |
I'm certain the 6th gen ZL1 has much better intercooling than the 5th gen, which helps w/ the consistency.
2021 Camaro ZL1 A10
#129 | |
![]() ![]() ![]() ![]() Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
![]() Quote:
Beauty is in the eye of the beholder, and who cares if it has an engine shared with a truck, the Viper's engine is also shared with a truck. So what. ![]() Maybe that's why you are driving a ZL1. Yes I agree that the Mustang exhaust sounds better.
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
#130 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
The LT4's 1.7L blower has a 3.1:1 drive ratio ...to small and fast IMO. The LSA's 1.9L had a 2.6:1 drive ratio. Both generate 9 psi boost. The ZR1's LT5 has a proper 2.6L blower with a 2.4:1 drive ratio generating 9.4-14 psi boost. That's a nice setup. I'm good with the power of the LT1, naturally asperated, with an manual. You can still drive it hard on the street and is adequate for the weight of the car. 12.3 sec 1/4 and 0-60 in 4.1 sec is fine.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
#131 | |
![]() Its amazing that Ford has made so many variations (attempts) and the old SS 1LE still stands up. Chevy isn't even competing anymore and is still relevant. ![]()
#132 | |
The LT4 blower is spinning faster, but the LT4 heat exchangers (HEXs) have a higher cooling capacity than the LSA HEX. For comparison, the LT4 intercooler HEXs have about 10% higher cooling capacity than the LS9 in the C6 ZR1, despite being physically smaller. They are simply a more efficient HEX design (internal ribs to cause turbulence increasing the heat transfer capability). As far as supercharger heat...for any blower (whether on a car or in an industrial facility), the heat of compression is what causes the charge air temperature to increase (heat added to the air stream), which is typically 10-20 deg F per pound of boost, depending on the blower efficiency. So, if both the LT4 and LSA blower are producing about 9 lbs of boost (slightly over for the LT4, not sure on the LSA), the heat increase on the charge air will be directly related to the efficiency of the rotors and blower assembly. The Eaton 1.74L rotors in the LT4 is more efficient than the LSA blower's rotors, so at the same boost pressure the LT4 will be making less heat due to compression. That said, the HEXs are sized for the stock conditions for a given ambient air temperature. Once the rotors are spinning faster, most boost is being made and thus, more heat (obviously). Also, spinning the rotors faster may decrease the efficiency (I'm not certain on that but it's possible), and thus even more heat on top of the extra boost, compounding the heat issue. Anyway, just some HEX 101 for the group...
2021 Camaro ZL1 A10
#133 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
But...but...but Camaro sales suck and nobody wants one and they have to be discounted and you can't see out them...
#134 | |
Drives: 2016 Camaro 2SS Join Date: Sep 2020
Are you talking about the 1LE? Depending on the tests, the LT1 engine is 0-60 3.9 seconds and 1/4 mile 11.9 Car and Driver got 3.9 seconds out of the 2019 Camaro 2SS |
#135 | |
https://www.caranddriver.com/reviews...y-the-numbers/ I personally ran a best of 12.2 sec at 116.4 mph in my 16 2SS A8. It would easily run consistent 12.2 to 12.3. https://www.camaro6.com/forums/showp...&postcount=498
#136 | |
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - Last edited by hotlap; 06-27-2021 at 09:30 AM. |
#137 | |
The best endorsement is this man. Randy Pobst drives a 1LE every day. ![]()
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - Last edited by hotlap; 06-27-2021 at 01:02 PM. |
#138 |
It's like pulling teeth tryna get a laugh in here you guys, haha!! Geez...
The point I was soo desperately trying to make is that the 6th Gen Camaro has been soo awesome in everything that the opposition had to resort to fishing for any silly excuse they could find to discredit it despite the performance it comes with. I remember back when someone stated that they think the V6-1LE could beat the non-PP GT around a track. That is how good it is. The way I see it is that GM poured a lot into the frame/chassis of the Camaro while Ford just tried to work around the lazy chassis they had back in 05. And then you have the Vettes out there pushing things even further. Imagine how things will go when the C8 Z06 shows up and destroys everything Dodge and Ford has to offer. And then imagine the leaps and bounds that the 7th Gen Camaros will have...if there is one...which I think there will be. I mean, the fact that GM hasn't even touched the ZL1 since it was released means that all this time has been spent slowly developing the next thing!! I can only imagine!! |
#139 | |
![]() Quote:
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport Last edited by Bosse'sBoss; 06-27-2021 at 10:09 PM. |
#140 | |
I thought it was a V6 ...but IDK how to tell the difference between it and the turbo.
Tags |
1le, comparison, mach 1, performance, price |
