#127 |
I run E85 on sub 600 lift cam and boost, think my rev limiter is at 7250 RPM, I shift at 6900ish. I did the 7250 for 0-60 bragging rights with M6 as there is no shifting needed given my slightly taller tires drag radials.. cheeezzeee I know, just say it is very close to C8 times... There is no reason to push the engine that high, mine was a specific objective.
#128 | |
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
#129 |
The only way to get close or under 3.0 0-60 with 100 wear tires is to not shift on the M6, this can be done on the Zl1's M6 (different first gear), other than 0-60 times, there is little reason to rev the engine past 7000 RPM. A 1LE in a tight road race may carry that RPM in some situations probably in 2nd or 3rd. Back to 0-60 times no matter how good you are at shifting IMO of course, 3.6 to 3.8 is about the best you can do M6 0-60 and shifting 1st to 2nd.
#130 | |
Best I could do was 3.13, thats with rollout. I have never been able to put down full traction with a brake stall. This is stock converter NT555R2's. I even tried 3.73 gears and results were basically exactly the same, I couldn't really tell if I was spinning more with 3.73s but I think I was. Last edited by cmitchell17; 02-26-2021 at 01:17 PM. |
#131 | |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
#132 |
#133 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
a) not on a broken county road b) with more power c) with a smaller diameter, sticky tire
#134 |
Need to use a dragy and not the performance page to measure 0-60.
My best so far from a second gear launch on the street is 3.05 or 2.84 with rollout like the C8 performance page measures. That's how they are reporting such good 0-60 times.
#135 | |
I was never able to get full traction with my NT555R2s, I always have to let it roll out for about .25-.5 seconds before I go full throttle. Funny enough I think this was my fastest 1/8th mile and this was right before it decided to eat its own intake valve haha Also anyone know anyway I can change the title to this thread? I was going to change it to broken stock intake valve seats, so at least someone else could locate it easier through a search? |
#136 |
If you edit your initial post with the advanced editor (press the "Go Advanced" button after clicking "Edit"), it'll allow you to change the title. I do this all the time with my classifieds.
#137 |
Thanks, I changed it so it will help someone find it if they are searching for things on the topic. I know I have never heard of valve seats, especially intake valve seats, failing when putting in a cam or after a valve job or even on stock LT1 applications.
#138 | |
I have to do the same thing on the street. I brake stall to 2k rpm, let off brake, let it roll out a bit then put it to the floor from second gear. That has netted me a 1.75 60ft, 6.9 @ 107mph in the 1/8.
#139 |
![]() Drives: 2017 FIFTY 2SS HCI Join Date: Feb 2022
I know this is an old post but at this point it is well known that the stock seats on the lt1 are powered metal, and with an aftermarket cam with a higher lift they are well known to "chip" and drop into the motor. I went the extra mile and got Frankensteins stage "1.5" (although they were $3,300 heads. They installed ductile seats to correct the chipping issue, Inconel ex valves, .025 mill, and .700 springs, and ported ofc. It even says on the page (correcting the stock seat chipping issue)
https://frankensteined.net/product/l...rted-head-set/
*STG 1.5 Frankenstein ported/milled heads(.025),
*Custom Cam Motion Cam (224,242[.647/.639]) 1 7/8 headers, Ported LT 2 Manifold, Solar Ported 95mm TB, Cold Air Induction CAI, CHE Valve seats, Inconel EX valves, FED/PAC .700 dual springs, VVT Delete, CHE Trunnions, Caddy R Lifters, 3 In Midpipe, NPP Borla atak mufflers, GPI tune. |
