Old 01-05-2022, 08:39 AM   #127
Kerry
Drives: 2019 2SS Camaro
Anybody know if this would work on a vert?
Kerry is offline   Reply With Quote
Old 01-05-2022, 08:48 AM   #128
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
Thanks @Evansa22! I’ve got it at the back of the driveshaft tunnel as I didn’t like all of the cuts & bends I saw on other installs. I did have to have the muffler “clearanced” a bit to clear my bigger driveshaft but love how it came out.
Edit: Crap, not sure why the top pic is upside down lol
Classy way to do what I did, which was BFH the muffler into submission around that area! lol
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 01-05-2022, 03:33 PM   #129
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Hard to tell due to the location of the resonator. Might work. Might not. This post has some of the best pics on these forums of the vert's bracing: https://www.camaro6.com/forums/showp...76&postcount=8
Well it is what you see when you lie down under the car and look back over the top of your forehead, but just in case FIFY
Old 01-05-2022, 04:21 PM   #130
TXCSSU
Drives: 2022 ZL1 M6/Nissan Leaf
My solution would be a louder stereo system....
TXCSSU is offline   Reply With Quote
Old 01-05-2022, 06:07 PM   #131
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Thanks @Sakudog! Appreciate you trying this out first for the rest of us. I actually did the BFH initially but my OCD wouldn't let me live with myself...so back to the shop for surgery it went.
Thanks @Gunkk!
Old 01-15-2022, 12:20 PM   #132
Kerry
I think it work on the vert. What about power? I was thinking going through the secondary cats to quite it down, but now I really like the sound clips. Maybe a toss up power wise between the 2 with about 700 wheel power wise?
Old 01-27-2022, 01:33 AM   #133
vampire
vampire's Avatar
Drives: '19 M2C / '19 ZL1
After some careful research, I settled in on adding a Magnaflow X-pipe muffler...
I just ordered one.
thank you.
vampire is offline   Reply With Quote
Old 01-27-2022, 06:05 AM   #134
Joshinator99
Moderator
927 WHP through the Magnaflow center muffler with no signs of excessive back pressure at all in my build…
Old 01-27-2022, 12:37 PM   #135
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
Did you have to remove that black tunnel brace for this install?
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 03-24-2022, 09:59 PM   #136
Vileintent
Drives: 2017 Camaro ZL1 A10
I just finished doing similar mods - 2650R, 2" Kooks headers, both Cats removed, Kooks 3" full exhaust connected to AWE touring axle back exhaust and ... it's WAY too loud!
Fun yes, but not practical and will certainly exceed some track sound limits.
After reading this thread I bought the magnaflow 12469 muffler and I've been to 3 shops and none of them think they can make it work. They think it's too tight in the tunnel or will affect clearance. Two of them were also not keen on working on a car with no cats which could be part of it too.
I'm thinking of putting the OEM exhaust back (with valves) back in place hoping the suitcase muffler can take some of the noise down. On track, the valves will have to be open. I sure hope it'll put me under the limits else I'm not sure what to do.
2017 ZL1 Black, A10
Build: Magnuson 2650R, 103NW Throttle Body, Rotofab Big Gulp, Kooks 2" headers, Catless, AWE Touring exhaust, JRE Smooth Idle Cam, Katech Oil Pump, Elite Catch Can, JMS Fuel Booster
Vileintent is offline   Reply With Quote
Old 03-24-2022, 10:23 PM   #137
Kerry
valve open will be just as loud. Its just basically a straight pipe out with the valves open. Been their done that. I put 2 vibraint 1142s on mine. Still pretty loud wide open but somehow not so bad. Guess it just sounds better.
Old 03-25-2022, 05:51 AM   #138
Z OH 6
Drives: 2024 CT5-V Blackwing
My exhaust shop said the same thing when I wanted it installed, after they started on it, they realized it will fit. Its a tight fit but it fits without any issues. I think most exhaust shops don't want to do it because there's not much clearance so it takes a fair bit of time to do all the welding properly.
Z OH 6 is online now   Reply With Quote
Old 03-26-2022, 12:58 AM   #139
airtroop01
Drives: 2018 Cadillac CTS-V
Hey! So did your power numbers improve?
I’m going the same route… made great power with the stock exhaust but wanting a bit more and have some ARH 2” headers getting Cerakoted, high flow cats that are getting surgically gutted so they look legalish and and this magnaflow muffler. To hell with the Smog nazis! Hopefully the pics on here from folks that have done it will be enough for them to try as well.
airtroop01 is offline   Reply With Quote
Old 03-26-2022, 01:44 AM   #140
Vileintent
I'm currently working with Ted to get tuned after all my changes. Currently at round one of tuning so a few iterations to go and then I'll put it back on the dyno and see where it lands, hoping for over 800.
2017 ZL1 Black, A10
