Old 10-03-2023, 08:46 AM   #127
ember1205
Hot Camaro
ember1205's Avatar
Originally Posted by havelegs View Post
OK thanks. BTW, Advanced Auto has the oil on sale for $7.43 per quart.
https://shop.advanceautoparts.com/p/...hTerm=supercar
Ordered 11, one extra for good measure
As more oils get certified for either dexos2 or dexosR, I will begin considering running 0W-40 because the pricing will get a bit better with more competition in the market. Until then, I will run 5W-30 dexos1 Gen2 oil and lose zero sleep over it.
Old 10-03-2023, 09:12 AM   #128
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Valvoline dropped their Dexos certified 5w40, and I don't really see an increase in Dexos certified oils other than the thinner grades like 0w30 and 0w20.
'18 1SS 1LE Black, PDR
Old 10-03-2023, 09:19 AM   #129
ember1205
Hot Camaro
ember1205's Avatar
0W-40 and 5W-30 are really the ones that matter most for the Camaro's. New Camaro's "require" 0W-40 dexosR or 5W-30 dexosR for the LT1 motor which is fine except that there's no such thing as 5W-30 dexosR certified oil.
There's nothing wrong with 5W-30 dexos1.
As we see more oils actually hit the dexosR list, the dexos2 0W-40 oils are likely to come down in price because so many people will move to the dexosR version (including dealerships). That's the piece I was really focused on.
Old 12-17-2023, 07:27 PM   #130
WishfulSS
WishfulSS's Avatar
Drives: 17 Volt, 2024 2SS 1, 2014 Boxster S
AS of January 2023 Amsoil Signature 0W-40 meets or exceeds the DexosR specifications. About $12 per quart if you pay for preferred pricing.
WishfulSS is offline   Reply With Quote
Old 01-06-2024, 08:05 PM   #131
NewCamaroOrder
Drives: 2017 Camaro 2SS Nightfall Gray 1LE
Apologies for answering an older post I found earlier in this thread, but I thought it might still be useful to some members.
WJones14: “Why did Chevrolet change the recommended oil from 5W-30 dexos1 to 0W-40 dexos2 when it's still the same engine?”
They switched to Mobil 1, 0w - 40 ESP (Emission System Protection) because owners who tracked their cars and didn't switch back to 5w - 30 right after their track session were burning up their catalytic converters and GM didn't want to pay to replace anymore.
I heard stories (from my dealership, Simpson Chevrolet, here in SoCal) about owners who tracked their cars, drove them home, and before they got home their cats were destroyed. The story goes GM tried to deny the warranty claims but lost. Given the source you can take or leave the info, but I didn't want to take any chances.
I ordered a new 0w - 40 oil cap and switched to that oil. I was getting my oil from eBay at first but now you can get it on Amazon. I have a 7500 lbs. car lift in my garage and do all my own work on the car so switching wasn't a big deal. I haven't had any issues running 0w - 40 ESP oil here in SoCal so that's what I'm sticking with for now.
Hopefully, this is still useful. If not, again, apologies!
NewCamaroOrder is offline   Reply With Quote
Old 02-01-2024, 12:30 PM   #132
Gbassrace
Drives: Chevy Camaro ZL1
Hey everyone...new to the forum and ZL1 ownership. Now doing a first oil change and will be using ESP x3 but will change again soon to M1 Supercar DexosR. Just noticed the GM spec is posted as meets or exceeds D2. Any other info would be appreciated. Haven't yet opened my LT4 WOT at 700miles lol.
Gbassrace is offline   Reply With Quote
Old 02-01-2024, 05:58 PM   #133
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
That will be fine, just make sure you switch over to the whatever type oil they recommend in the manual this week, for warranty reasons. I knew I was going to void my warranty instantly so I use amsoil. When supercar came out it was Unobtainium in my town.
Old 01-24-2026, 12:12 PM   #134
Mech5136
Drives: 2017 Camaro SS
So if I’m reading this correctly, should I use the 0w40 in my 17ss? I do tend to be spirited.
Mech5136 is offline   Reply With Quote
Old 01-24-2026, 02:11 PM   #135
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
You can, but "spirited driving" on public roads doesn't get your oil hot enough to necessitate it. I personally would stick to 5W-30 since it's way cheaper and adequate for street use.
2012 Shelby GT500 with VMP Gen 3R.
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 01-24-2026, 04:35 PM   #136
Mech5136
Copy, thank you.
Old 01-25-2026, 09:50 AM   #137
Mech5136
Last dumb question for a while, Amsol lists their oil as DEXOS one approved, but I don’t see it on the dexos site. Are they approved?
Old 01-25-2026, 06:38 PM   #138
ember1205
Hot Camaro
ember1205's Avatar
I thought AMSOIL claimed to "meet" or "exceed" standards but are not actually certified?
Old 01-26-2026, 12:16 AM   #139
Mech5136
That’s what I was thinking. I’ll just stick with mobile.
Old 01-28-2026, 12:29 PM   #140
NewCamaroOrder
You can get the Mobil1 0w-40 ESP(Emission System Protection) on Amazon pretty cheap. I've even seen it at some local parts stores. The original issue with Mobil1 0w-40 was that during street use it was overheating the CATs causing them to fail. Hence the ESP formulation. GM lists this oil as recommended. I even got a new oil filler cap to reflect the new weight.
You want to make sure whatever you put in is Dexos 2 and if you go with 0w-40 it should indicate some form of ESP (IMHO). If its not you can lose any warranty you may have left. This may seem silly but I bought an extended warranty so I still have a little time on mine. Normally this is a waste but it has helped with the AT issues our cars can have. If your warranty is over, obviously, you can do as you wish.
Our engines came with really tight piston ring tolerances, sometimes as low as 0.008 gap. This doesn't leave much room for ring expansion which is why adding forced induction is so tricky.
Now you have some additional information as to why some members do what they do. You can now decide for yourself.
God Speed!
