#127 |
![]() ![]() ![]() ![]() Drives: 2008 Pontiac G8 GT, Shelby GT500 Join Date: Mar 2011
Agreed, I'm willing to bet almost anything that somebody is gonna hit 10's with a stock ZL1 in stock form at a track like ATCO. It's just a matter of when.
#128 | |
Skip to 6:51. 2 dynographs are shown, one of the Hellcat, the other of the ZL1. Forget about the peak numbers and everything, I'm curious, why does the torque in the LT4 gradually drop as it approaches redline while the Hellcat torque curve remains relatively flat all the way to redline? What would we have to change in the LT4 to get a similar looking torque curve? Seems like that torque up there would be beneficial, especially for the A10 guys with those short gears since the car would be spending a lot of time in that RPM range at WOT.
#129 |
![]() ![]() ![]() ![]() Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
#130 |
![]() Drives: Camaro Join Date: Mar 2017
Doesn't sound like very good tracks then because I can basically hammer down from a stop light on the street and it mostly sticks and it's not even a prepped surface. And so what if you have to roll into it at the track, let's not pretend that is a difficult task. It's literally point and shoot and that's a testament to how well done this car is.
19 ZR1 | 16 Viper GT | 09 Z06 | 94 LS1 GT | 16 Denali | 19 CTS
http://www.gonicd.com |
#131 |
It's a combination of the pathetically small stock LT-4 camshaft, the smaller blower, and less head flow. But the majority of it is the small cam and even a "small" aftermarket cam will fix it right up.
#132 | |
Even putting in a "baby" cam gains big for the LT4. I know a guy that put a cam that's not even considered a stage 1 cam, hardly any chop at idle, and put up good power and a better curve while driving as good or better than stock. |
#133 | ||
![]() ![]() ![]() ![]() ![]() Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
#134 | ||
Lmao, I know the guy, we have the same car currently. I've been searching for "ZL1 vs Hellcat" on youtube on a daily basis and sort the videos by recently uploaded and came across his video. I was skipping around and saw the graph. |
#135 |
This is good info as well all on one sheet.
#136 |
FASTER!
Drives: Challenger Hellcat, 2SS Camaro Join Date: Apr 2008
I think the reason the torque falls off is the baby blower they put on the ZL1. 1.7L ?? It's also likely maxed out as is on that big 6.2L engine. Hellcat pulley swap and tune and you're talking 800+RWHP easy and 9s in the 1/4.
I think a larger SC like the Whipple 2.9 or similar would make a huge difference on the ZL1. I've personally played with my buddy's C7 Z06 and I expected it to pull on me in my Hellcat and it did not. 50 - 150 we were side by side. I figure C7 Z06 weighs less than the ZL1 (?) so not sure how one will actually do against a Hellcat with a someone that knows what they're doing. The MPH in the 1/4 seems similar so that is something to keep an eye on as that will really tell the tale. Hoping the guy who posted slips earlier can hit Beech Bend with me this fall and we can do some compares and maybe a little fun grudge race. |
#137 | |
That sheet isn't really very accurate. The cam durations are WAY off, the LT4 is using the .050 specs and the Hellcat is showing total advertised duration.
#138 | |
Where can you find the accurate specs? I tried googling it and can't seem to find anything straight forward for the Hellcat, which is surprising. |
#139 | |
![]() Drives: 15 ZL1 red hot A6, 17 ZL1 Black A10 Join Date: Nov 2015
#140 | |
