10-01-2018, 12:32 PM | #127 | |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
Pulling the fuse only differentiates itself from track mode exhaust (fuse in) by not closing the valves at cruising speed below 2000rpm in 5th or 6th gear.
MJK3888 Instagram Link
10-01-2018, 04:59 PM | #128 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Maybe it's because I have no 2ndary cats, but I couldn't tell any difference after I pulled the foam.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
10-02-2018, 07:45 AM | #129 | |
Drives: 2016 Camaro SS Join Date: Sep 2018
10-02-2018, 04:34 PM | #130 |
I pulled that tube apart, stuffed rags in both ends of it and snapped it back together. Much better.
10-03-2018, 07:51 PM | #131 |
Shifts under load
I stand corrected. I drove with the windows up and you definitely hear the fake sound more. Yuck.
10-04-2018, 07:36 AM | #132 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
I just installed a CAI air box and while I had the stock one removed I also removed that ugly sound tube from the engine compartment. I capped off both the intake tube and the firewall where the sound tube was connected. I really didn't like the sound when I simply pulled the foam out of the tube so decided to just eliminate the whole thing!
10-23-2018, 04:20 PM | #133 |
Shifts under load
Putting my foam back in. Prefer none of the piped in sound.
01-24-2019, 07:41 PM | #134 | |
Drives: 2019 1LE 2SS Camaro, 2011 Z07/Z06 Join Date: Nov 2013
What did you use to cap off the intake and firewall tube?
2011 SSB Z07 CFZ 3LZ Z06, 2004 SGM M3, 2019 2SS 1LE Camaro, 1990 RC30, 1993 CBR900RR
01-30-2019, 08:30 AM | #135 |
2018 Camaro 1ss M6
Drives: 2018 Camaro 1SS M6/ LT4 SC Join Date: Mar 2018
is there a sound difference from just removing the foam and removing the whole unit? I didn't like the sound from just removing the foam.
02-03-2019, 10:42 AM | #136 |
Drives: Camaro Join Date: Sep 2018
Here is the answer to every question here.
Buy a Roto-Fab CAI with sound tube delete & your done. Oh wait that's to simple...lmao! |
02-08-2019, 04:41 PM | #137 |
Drives: Black 1SS Join Date: Dec 2018
I tried it idk what I hear but it sounds different and i like it haha
04-24-2019, 12:12 PM | #138 | |
16 Camaro 2SS Convertible
Drives: 2016 Camaro 2SS Convertible Join Date: Mar 2019
https://www.harborfreight.com/11-in-...iABEgI1n_D_BwE
2016 Hyper Blue 2SS Convertible A8 MRC NPP |
04-24-2019, 12:34 PM | #139 |
Ok, I just read through all 10 pages of comments in this thread ( shoot me, lol ) and I didn't see much mention of vert owners doing anything with the sound tube. Since we have a soft-top or a no-top situation, we probably hear the exhaust much more than you coupe guys, so I can't imagine that this would benefit us much. Especially since I have NPP. Pulling Fuse #51 to go all the time loud would give me plenty of sound, but really piss off my neighbors when I fire up the beast at 5am to go to the gym. lol
I am thinking that I might just remove the tube entirely so that I can reduce the noise in the cabin, since I get plenty of exhaust sound already and I do not need to add engine noise on top of the road noise that we already get in the verts. Also, the sound tube deletion would give me a way to route wires through the firewall to get constant power for my dash cam. Bonus!
04-24-2019, 03:59 PM | #140 |
"M1SS1LE"
Again to clarify this is to allow more induction noise into the cabin. It has no effect on the actual air intake. A sound tube, transmits vibrations from air in the intake system to vibrate a diaphragm. Those vibrations are then transmitted through the tube and into the cabin. No actual air passes through the tube. This is the same concept as holding your ear against a door to hear the sound on the other side amplified.
Removing the sound tube has no effect on performance! Only cosmetics and maybe a few ounces of weight reduction. In fact it will reduce the induction noises heard. You are making the engine sound quieter by removing this tube. The foam in this tube was a quick solution to fix the odd noises that were heard under cylinder deactivation in Automatics. This thread is simply to inform people that it is possible to allow more sound into the cabin by removing the foam that is muffling the tube. It should only take 30 seconds and costs no money. If you like the sound great, if not no sweat just put the foam back in.
