Old 04-09-2017, 02:53 PM   #127
Summit1le1ss
Drives: 2017 1ss1le
Ok, what I have confirmed.
We have vented and heated seats.
We have the correct GM harness for vent/heat seats without memory.
The signals are active to red and ground.
There are fuses installed for heat and vent.
Next, is pull the ac controls and and see if there are plugs there. Some how it wouldn't surprise me. I ran out of time for the day. I only saw one different harness in the entire ac system from 2ss.
Wish GM would hury the hell up with service manual already!!
Summit1le1ss is offline   Reply With Quote
Old 04-09-2017, 03:03 PM   #128
DenverTaco07
DenverTaco07's Avatar
Originally Posted by Summit1le1ss View Post
Any v61le owners here? Your seats should work.
So my fan controller worked, on one speed (low). Amps were different, which I knew. Time to make a CB with the correct currents.
So it looks like this.. 12v going to CB and to fan. Wire pw (3 sep wires with diff volts/amps) into switch, then switch to fan. I order 2009 Acura TL Sh awd switch, has both heat and fan control. 12v +/- and pins for lo/med/hi heat and fan all for $17. 35650-TK4-A01 part #.
Until I get a real diagram this is what I'll do. Once I get the CB built I will post a how to or offer to those that want.
Edit: the only thing to consider is blade stop. If the fan stops it sends a signal and tells the car to stop sending power to not cause any issues. A think a PWM speed sensor and cutoff should do the same thing. I'll draw out the CB later today.
Anyone here better with this than I am? Please chime in. I'm a Novice at best.
You look like an expert from where I stand.
Old 04-09-2017, 03:32 PM   #129
bub
Drives: '17 1SS 1LE & '15 Corvette Z06
Did u ascertain if there is just the 1 fan under the seat or 2 like the 2SS?
bub is offline   Reply With Quote
Old 04-09-2017, 04:19 PM   #130
Summit1le1ss
Drives: 2017 1ss1le
I did not. I simpley removed the lower fan. I think it's designed to blow on the bottom and up the back.
Old 04-10-2017, 05:33 AM   #131
Summit1le1ss
Drives: 2017 1ss1le
Took the easy route after a little research.
IGBauerhin is the manufacturer of Recaro and GM heated seats and steering wheels as well as vented seats.
And... They offer the control boards separately. For both fans and heat. Occams Razor again.
I emailed for pricing and more info.
Old 04-10-2017, 03:32 PM   #132
bub
Nice. If it's just a matter of running switched 12V to this module we will be good to go.
Old 04-10-2017, 03:32 PM   #133
bub
That was my take as well.
Old 04-10-2017, 03:39 PM   #134
WILWAXU
WILWAXU's Avatar
Drives: 2019 Crush ZL1 1LE
That sounds great!
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
WILWAXU is offline   Reply With Quote
Old 04-10-2017, 04:37 PM   #135
DenverTaco07
Old 04-10-2017, 05:54 PM   #136
slick3
Drives: Garnet Red - 20 ZLE
Sounds like this will be a nice mod. If we can tie it into some physical buttons that would be nice. Factory buttons would be cool but from the past few pages I have gathered that its not possible.
slick3 is offline   Reply With Quote
Old 04-10-2017, 06:06 PM   #137
WhyUMad1LE
Drives: 17 SS 1LE
I can't be 100% certain without seeing the back of the 2SS heat/vent buttons. It could be as simple as replacing the car side seat harness and plugging in the switches.
Old 04-10-2017, 06:19 PM   #138
Summit1le1ss
Drives: 2017 1ss1le
This is what I'm lead to believe.
I pulled the trigger already and order one. 2ss AC controls.
With a diagram I already know I can figure out. We have done this before with a 2015 mustang.
Old 04-10-2017, 10:11 PM   #139
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Nice I wonder if the extra buttons will do anything. Guess we will find out. The can bus will be interesting.
thescreensavers is offline   Reply With Quote
Old 04-10-2017, 11:00 PM   #140
Chevy71
Drives: 2016 2SS
I have vented seats in my car, you can't even tell they are on.. you aren't missing much!
Chevy71 is offline   Reply With Quote
