Old 06-03-2017, 07:08 PM   #127
slick3
Drives: Garnet Red - 20 ZLE
GLAMCEM, could you take a few pictures of the modifications you had done next time you have the wheels off? Looks great man, its too bad you cant get those rears tucked.
slick3 is offline   Reply With Quote
Old 06-03-2017, 09:44 PM   #128
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Rear also don't look bad at all. I am not sure if I included the pictures before or after we did -1.6 camber so I will take some more pictures. Even with the 325s it only sticks out a little bit. I could get some good quality adjustable toe links in the future if I want to add more camber without losing the toe in on rears but at this point it doesn't really bother me
If you want you can do the same and slightly add more camber and call it a day with the above solution.
Which modifications are you referring to btw? I have included most of them here on this thread
glamcem is offline   Reply With Quote
Old 06-05-2017, 03:15 PM   #129
glamcem
glamcem's Avatar
Yesterday's event at the Ridge (RMP) was very crowded so I couldn't get enough time to improve my previous best lap. However, car felt better with additional camber
I did my best lap after the warm up lap and -as you can clearly see in the video- I forgot to hit the "define finish lap" or "start recording" sorry for the shaky video
Without the miss-shift and/or few more laps I believe I could've seen 1:52s easily
Old 06-06-2017, 01:07 AM   #130
glamcem
glamcem's Avatar
And some pictures from the yesterday's event
Old 06-07-2017, 01:37 PM   #131
glamcem
glamcem's Avatar
Created a small HowTo for C7 Z06 fender flares install
http://www.camaro6.com/forums/showthread.php?t=497622
Old 06-07-2017, 02:10 PM   #132
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Man the 1LE looks like it's ready to eat the tiny Caterham! Great pictures.
No rubbing with the tires sticking out past the fenders?
Old 06-07-2017, 02:52 PM   #133
OminouSS
OminouSS's Avatar
Drives: Red Hot track candy
Glam, did you go with camber plates? It is time for me. I ate up a brand new set of tester Hoosiers in 4 sessions. It's going to be a challenge getting past the -2.0 I have now as I already had to grind the strut. But I'd like to be able to run A6's for competitions and I just cant afford to throw out $1600 after 3 - 4 sessions. That was brutal. This car will need -3.0 to survive the outside edges.
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
OminouSS is offline   Reply With Quote
Old 06-07-2017, 03:07 PM   #134
glamcem
glamcem's Avatar
Thanks, I named that picture "JAWS" :P
No rubbing issues btw
Sure, Hoosier recommends -3.0 camber for the R7s. Do you have the stock wheels?
This is what's been done to my front suspension (photo credit : Provoste). Basically my mechanic extended the upper camber bolt hole to give a bit more camber up front. I am now at -2.9 camber up front and -1.6 at the rear:
Old 06-08-2017, 01:26 PM   #135
glamcem
glamcem's Avatar
Update: Decided to install the DBA rotors before my track event tomorrow. I've used the OEM rotors for about 6 events and figured it would be better if I just keep them for the future or as a spare.
I also replaced the pads with a bit more aggressive compound (ST47 F / ST45 R)
Will report back
Old 06-08-2017, 01:31 PM   #136
glamcem
glamcem's Avatar
Decided to try ST47 F / ST 45 R compound this time , since I was going to replace the front rotor rings anyways.
ST43s after 6 event still look great, I will keep them as a spare
Old 06-08-2017, 01:33 PM   #137
glamcem
glamcem's Avatar
Since the oem wheels are gone, I also ordered some 18" Apex wheels to be used with slicks. Apex 18x10.5" +22 F / Apex 18x11" +25
I will see how they fit
Old 06-08-2017, 02:25 PM   #138
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Very cool. I look forward to your feedback on the pad compounds. Also, the low wear on those ST-43's is nothing short of remarkable.
Old 06-08-2017, 03:18 PM   #139
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | DenaliHD | E92M3
Keep me posted on the pads and the 18s... I'm still weighing my options on both pads and tires.
Might even be interested in the ST43s if you want to sell them.
'17 SS 1LE - 1LAP 1LE (Now with more 447!)
'24 Denali Ultimate 3500 DRW
'22 Kia EV6 First Edition
'12 E93 M3
'25 911 (ordered)
Formers...
'18 RS3 (1 of 2) Cumulus Blue | '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 06-08-2017, 03:50 PM   #140
glamcem
glamcem's Avatar
Sure, I will share my feedback here and in the track pads thread
