Old 05-04-2017, 12:56 PM   #127
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Originally Posted by archer1965 View Post
My 16 had the 1LE suspension upgrade kit installed yesterday. The dealership is working with GM on the suspension flash today. GM engineering has a solution and imminent release of new 2016 software,which they are using on my car today.
I'll post before and after ride height measurements today or tomorrow.
AWESOME! If they can get the 2016 flash to work, I'm buying this kit ASAP.
Eric SS is offline   Reply With Quote
Old 05-04-2017, 08:02 PM   #128
archer1965
archer1965's Avatar
Hang on buying that kit.
the dealership received the flash this morning, it didn't work. GM said they will have the flash available later this year, but for now, it won't work.
2SS Nightfall Grey / Black Rally Stripes / Sunroof
NPP / MRC /1LE Suspension / Nav / M6/ Xpel'd / CAI
archer1965 is offline   Reply With Quote
Old 05-05-2017, 09:31 PM   #129
archer1965
archer1965's Avatar
Got my car back today with front and rear sway bars and toe-rods installed. Noticeable difference in how it drives, even without the springs.
Old 05-23-2017, 08:16 PM   #130
F1FTY
Drives: 2018 ZL1
Full kit with MRC calibration and trailing arms installed.
Haven't gotten a good chance to test it out yet but can note the following changes:
-Steering modes feel closer together in effort now. Tour to Sport to Track no longer have a large increase in steering effort like they did before. It's much more slight and subtle now.
-The car rides smoother and flatter now without the wiggly bouncing around over bumps. One of the things about the FE3 MRC in the SS was that the rear end would wiggle about and the rear didn't feel as connected as it should. That is now gone for the most part.
-Even on Track mode, I don't find the suspension to be uncomfortably stiff. It's just now tied to the car more and flat. Bumps are still controlled quickly thanks to the magnetic shock.
-Steering into turns requires less thought...the car goes into turns now with less delay, it's much more sports car-like. It's not 911-level, but it reminds me of how that car would turn as quickly as you had the thought of turning. It's much quicker to get on to business now.
Simply, this is how the car should come from the factory. There is still plenty of compliance left for grand touring of the car, but the slop has been reduced to where most sports cars start, which is good. That also means that it definitely leaves room for improvement in roll stiffness.
Overall, well worth the cost and time (2 days). I'll measure the ride height change later, it does look like the front ride height has gone down a tad, but that needs to be verified.
F1FTY is offline   Reply With Quote
Old 05-26-2017, 02:09 AM   #131
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
if I do the install will the dealer still do the program?
Old 09-01-2017, 09:25 AM   #132
JCunningham
Drives: 2017 2SS M6
found out yes they have to do the reprogram but GM lied when they say the program is included in the kit. It is not. you do Have to pay the labor to install it. ($100). doesnt mater if you or they installed the parts.
http://www.camaro6.com/forums/showth...02#post9889802
Old 09-06-2017, 07:20 PM   #133
NewCamaroOrder
Drives: 2017 Camaro 2SS Nightfall Gray 1LE
I hated it but I had Chevy do the install because I wanted to keep the track warranty. The trick here was when I ordered the kit and the dealership to do the install the price was all inclusive. It was $1,500 for the kit and $1970 total installed. There was tax and I also bought the GM Performance strut bar but the dealership honored the price from GM Performance. Which worked out because they said they had 14 hours of labor and the MRC computer re-flash and alignment were included. But the price stayed the same.
NewCamaroOrder is offline   Reply With Quote
Old 09-11-2017, 09:39 PM   #134
glenB
Drives: Chevrolet Camaro SS
If they had 14 hours in it then they were pounding the pooch
4 hours for parts install, tops and that's slow
1 hour alignment
1 hour flash
glenB is offline   Reply With Quote
Old 09-17-2017, 01:31 AM   #135
JCunningham
Drives: 2017 2SS M6
i drove my car probably 150 miles befor getting it recalibrated. I didnt notice anything with the recalibration.
Old 09-17-2017, 01:41 PM   #136
oldman
Drives: SS 6 speed of course
I would love to see this kit but with DSS dampers.... One of the reasons I did not order MRC was I wanted DSS dampers.
Old 09-26-2017, 06:17 PM   #137
X-Factor
Chick Racer
X-Factor's Avatar
Drives: 2017 50th 2SS
Newbie here to the 6th Gen. Background story I had a 5th Gen V6 that I pieced together a 1LE Track pack; the car was flooded and it was totaled so i'm starting over. I recently bought a 2017 50th Anniversary, and I'm wanting to add the 1LE Track Pack on it. I see where "Calibration requires programming at dealership (Calibration coding included with package)." But I don't have magnetic ride, would this be something I still would need to do? Thanks!
X-Factor is offline   Reply With Quote
Old 09-27-2017, 01:20 AM   #138
JCunningham
Drives: 2017 2SS M6
No you would not be getting the programing as that is just for the mag ride. Id recommend just going with BMR stuff for anyone thinking of doing this. There is not much of a difference with the 1le kit and I went way beyond just the 1LE Kit. I did a full 1LE install except the ediff that can not be added and shifter. Not much of a difference.
Old 09-27-2017, 09:17 AM   #139
X-Factor
Chick Racer
X-Factor's Avatar
Originally Posted by JCunningham View Post
No you would not be getting the programing as that is just for the mag ride. Id recommend just going with BMR stuff for anyone thinking of doing this. There is not much of a difference and I went way beyond just the 1LE Kit. I did a full 1LE install except the ediff that can not be added and shifter. Not much of a difference.
Ok, thanks so much! I appreciate the help!
Old 09-27-2017, 11:59 AM   #140
BMR Suspension
Let me know if we can help.
Frank Steadman
BMR Sales Tech
336-986-9302
frank@bmrsuspension.com
BMR Suspension is offline   Reply With Quote
