Old 04-10-2016, 01:52 PM   #127
trz174
trz174's Avatar
Drives: .
Originally Posted by trz174 View Post
Thanks very much for the detailed info. Unfortunately, I'm on the lucky VIN list so it's off to the dealer this week. If you want to check the pan for the raised number at home, you don't have to remove the aero pan. There are two quick ways to let you clearly see the number (or lack thereof).
1. You can see the raised number from the gap behind the crossmember on the passenger side. The gap is to the right in this photo. Use a good light or camera. This requires you raise the car to get into position.
2. Another method is to slide a camera phone up into the gap behind the crossmember and take a few photos. Obviously I'm using a lift, but this can be done without ramps in the driveway with a bit of stretching. Be careful not to hit the exhaust when reaching underneath.
Here's the photo that was taken using method #2.
trz174 is offline   Reply With Quote
Old 04-10-2016, 04:42 PM   #128
Tim Adams
Tim Adams's Avatar
Drives: 2020 Elkhart Lake Blue 1LT Z51 C8
You guys must have awfully long arms. I can't get anywhere near close enough to get a good pic with the car on the ground. I have Race Ramps on the way this week for other stuff so I will use them to check it out.
Ordered-Hyper Blue 1SS, A8, NPP, 56W wheels Built 1/20/16
Delivered 2/12/16!!
Sold 9/17/19 :(
2020 C8 ordered!!
"The greatest sound in the world is a Rolls Royce Merlin over 100 inches"
www.timadamsphotography.com
Tim Adams is offline   Reply With Quote
Old 04-10-2016, 04:54 PM   #129
Logan45
Logan45's Avatar
Drives: 2016 2SS
Bringing mine in tomorrow. Hopefully I get the all clear
Logan45 is offline   Reply With Quote
Old 04-10-2016, 06:56 PM   #130
suzook
Drives: camaro
Originally Posted by JFM-jr View Post
OK even tho my VIN comes up in the recall I climbed under there today and it appears I am good. No raised numbers. Here is a pic I took and circled the area it would be according to the bulletin.
Instead I saw what looked like sharply engraved numbers in the area I circled in blue below. It was hard to see this area and could not get a pic. There was definatley engraved digits in this area so it will not be in the same area as the raised letters would be.
Again VIN ends in 134437 built 12/15
This definitely is NOT the right spot for the raised letters. Just letting others out there know.
Hyperblue/JetBlack
Old 04-10-2016, 07:18 PM   #131
sixbrx
Drives: 1SS Hyper Blue
For a quick way to check, see trz174's posts in this thread which are invaluable. Post #118 will show how to hold your phone to get a pic that is like that in #127. I had the car on ramps which made things easier.
All smooth surface on the pan for me, which means I won't have to have the fix, though I will bring it by the dealer just for a double-check. My car was built Feb 16 2016, was flagged in the recall, VIN ends 146146.
http://www.camaro6.com/forums/showpo...&postcount=118
http://www.camaro6.com/forums/showpo...&postcount=127
Thanks trz174 for the helpful posts!
sixbrx is offline   Reply With Quote
Old 04-10-2016, 08:19 PM   #132
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
I was going to add trz174's 2 posts on the first page before the thread's got merged and my post got "lost" in the middle of it all. Thank you trz174.
As a side note, if you want to download the entire manual you may do so from this post:
Originally Posted by Tr6 View Post
THIS IS FOR 2016 CAMARO SS / 2SS MODELS ONLY. (Also for 2016 CTS-V's)
I know there is a pretty good size thread however, I figured I'd post this here as I do have the bulletin so it doesn't get lost somewhere in the thread and for people to find it easier. GM updated their dealership network SIS (service info system) over night. I called my dealership and made an appointment for monday morning. Make sure you get this checked ASAP as IF you do have it. It is a LONG and PITA process to implement the preemptive (or simply put, fix) process. It will require them to put the entire engine on a cradle to hold it up and get to work. On average, it's a 9 hour work and not everyone can do it, a gen 6 camaro/ c7 corvette specialized tech is the only one who can. So bank on a couple days at least, IF you have it.
Here is the entire Bulletin 30990 in PDF which you can download via my dropbox OR view it via the attached bulletin as PDF here:
https://www.dropbox.com/s/x2pefrimju...letin.pdf?dl=0
Also: Glen has posted here:
http://www.camaro6.com/forums/showpo...5&postcount=68
More info:
http://www.camaro6.com/forums/showpo...5&postcount=73
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 04-10-2016, 08:24 PM   #133
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Pdf here
Old 04-10-2016, 08:31 PM   #134
Baddadss
Baddadss's Avatar
Drives: 2016 Camaro 2SS Hyper Blue
engraved letters. Thank God. I took a video from the top of car and reach down And slid the phone in front of the motor across the silver pan real slow looks like laser # looks to be about 14 numbers long. Begins with 20151204co ?? Also green and a black dot
Baddadss is offline   Reply With Quote
Old 04-10-2016, 08:48 PM   #135
Baddadss
Baddadss's Avatar
This is the pic. Hopes this help
Old 04-10-2016, 09:21 PM   #136
JFM-jr
JFM-jr's Avatar
Please elaborate for us all as this pic is directly off the PDF and there are others who have posted pics in this very thread with raised letters in this EXACT precise spot circled in red (Not the one with # 2) . Maybe I am missing something and if so I would like to know. The orientation of the pic is that the bottom of the pic is the front of the pan. Drivers side left passenger side right
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 04-10-2016, 09:44 PM   #137
F N MUSCLE
F N MUSCLE's Avatar
Drives: 2018 ZL1 1LE
TRZ,
I think I snagged the correct photo of my car. Does this look right? When comparing to yours, I think I'm looking in the right spot. Don't see any raised coding but I also can't see anything engraved either.
F N MUSCLE is offline   Reply With Quote
Old 04-10-2016, 09:50 PM   #138
63falcondude
63falcondude's Avatar
Drives: 16 Camaro, 11 Stryker, 00 Explorer
I went from the top of the engine bay with a cell phone recording and found an etched date followed by AO something. It was where JFM jr circled in blue in a previous post. Could not see anything raised further back.
Just open the hood and slide your phone a bit below the crank pulley. Went in a second time with an endoscope to make sure.
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015
3000 1/8/2016 (TPW 2/1)
3800 2/1/2016
5000 3/5/2016
63falcondude is offline   Reply With Quote
Old 04-10-2016, 10:05 PM   #139
JFM-jr
JFM-jr's Avatar
Thank you I was just going to ask if anybody that has found the laser etched numbers confirm it was in the area I had circled in blue.
Rotofab
11.0@124.9
Old 04-10-2016, 10:21 PM   #140
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
The original post has been updated since the two threads on this subject were merged.
SPARTAN sui is offline   Reply With Quote
