#127 |
![]() ![]() ![]() ![]() Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
ADM uses GM sourced parts, including the blower. ADM provides a 12-month parts warranty, but your GM factory powertrain warranty is gone. Your body/paint/electronics warranty (minus ECU/TCU/BCM) remain intact.
#128 | |
Drives: Anything I want Join Date: Oct 2008
Would be glad to help you out. Thanks Andy |
#129 |
![]() Drives: 2017 Chevrolet Camaro 2SS Join Date: Oct 2017
You mean the powertrain warranty from Magnuson, not the GM powertrain warranty already on my Camaro from the factory, right? I don’t see how the GM powertrain warranty will be intact with any aftermarket supercharger. I was wondering if the supercharger from the ZL1 would allow me to keep my GM powertrain warranty intact.
#130 | |
#131 |
![]() Drives: 2014 corvette Join Date: Oct 2016
Can a lt4 Blower from a 16 zo6 be used on the lt1 in the Camaro with the adapter plates. I have been told the snout is a different lenght is that true.
#132 |
![]() Drives: '99 Vette, '02 SVT Focus Join Date: Feb 2018
There are offset pulleys available to retrofit, the bigger challenge is the wider manifold bolt pattern and needing the heads drilled and tapped.
#133 |
That is what the adapter plates are for.
#134 |
I have the adapter plates. We're do I get the retrofit pulley. ?
#135 |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
How much boost does this blower generate for this setup?
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#136 |
![]() Drives: 2019 CTS-V Join Date: Feb 2016
8-9ish.
#137 |
Actually, page three had the results. Now the numbers make sense...running 10psi to redline.
It stayed at 8.5 until after 5550 due to the restrictive nature of this car,it then moved slowly to 10.2
#138 |
Yeah every car is a little different. Mine peaks around 9 to 9.5.
#139 |
#140 |
Port geometry
I will disagree with that. You prove it on your end and then I will prove that it doesn't on my end.
