Old 09-15-2015, 02:04 PM   #127
obzidian
obzidian's Avatar
Drives: 98 camaro turbo
Originally Posted by Bhobbs View Post
The ls9 was too expensive. That's why they built the LSA.
It also says less than 6.46. It says less than 4.0 to 60 but the SS already does it in 4.0. The ZL1 better be way under 4.0.
Exactly.. but how much lower is the question.
If it's marginal then the weight is up.. if its not then the weight is down.
3900lbs. @ 650hp is 6.0
4100lbs. @ 650hp is 6.3 :(
As per the LS9/LSA, the rarity of that engine is the reason as to the cost. In reality, the additional components are not the sole reason as to difference in price between the two. Furthermore, its a corvette vs camaro thing... things now be shifting however till now everyone knows the corvette gets the more potent engine options. With that, just like the LT1 and the LS7, these powertrain packages have a target hp goal and the engineers have to figure out a way to get there.
Some times with a larger rotor pack, some times with a smaller rotor pack.
At the end of the day this is all just conjecture.
obzidian is offline   Reply With Quote
Old 09-15-2015, 02:05 PM   #128
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Originally Posted by Doc View Post
They're Goodyears; you can just make out the GOOD (logo) YEAR on the top of this tire.
Attachment 744306
They might even be a new tire just for this car for all we know.
Yeah, but they seemed to have removed the size information. Is it a square setup? This is really starting to bug me...not going to get any work done today.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 09-15-2015, 02:11 PM   #129
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
Your working here, so your good...and that does look like a square set up to me.
Old 09-15-2015, 02:13 PM   #130
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Looks like a square setup; maybe 295-305/19? They don't have wheel well extensions so maybe they're 295.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 09-15-2015, 02:13 PM   #131
Leviser
Drives: 03 BLK SSS, 13 BRM ZL1.
Originally Posted by BahamaTodd View Post
#HPSIX
The 5th gen Z/28 internal GM code name was "HP"...
9:24: https://youtu.be/sI9rXm8fhLk?t=9m24s
Thanks for posting this BahamaTodd.
Tires look to be same width on all 4 corners. Same as the Z28.
Even though the rims are ZL1. Also seeing a tow hook which also makes me think more of a track car.
I look forward to a new ZL1 but still thinking this could be a Z28?
Thanks for posting pics and vid.
Leviser is offline   Reply With Quote
Old 09-15-2015, 02:14 PM   #132
Bhobbs
Bhobbs's Avatar
I understand GM has different goals to meet but reducing power makes no sense.
Old 09-15-2015, 02:15 PM   #133
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Camaroless for now...RIP "Big SexZ"
Team Corvette said that they could not get the required emissions target out the next LT based LS7 at the hp target that they were seeking but that does not mean that this engine could not still be used in the new Z/28 since it does not need to have a much greater hp target as compared to the hi po top dog Corvette.
Next gen L88 would be a great successor to the LS7 and GM has already re-registered that name so it could be reasonably optimistic to assume this is the path they will go. The Z/28 only needs to lose more weight and bump up the power to combat the GT350R and the likes. We already have the proven formula now we just need to continue the evolution of what's been done going forward.
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
Old 09-15-2015, 02:19 PM   #134
RenegadeXR
RenegadeXR's Avatar
Drives: 2011 Camaro SS
This car looks downright scary. I think we have a competitor to the hellcat.
RenegadeXR is offline   Reply With Quote
Old 09-15-2015, 02:21 PM   #135
Z28sr2fast4yall
Z28sr2fast4yall's Avatar
Drives: 83z,86z,90rs,91rs,92rs,94z,95rs,95z
Apparently the new z28 doesn't need more power or weight loss... If the 2014 z28 beats the gt350 already. The unofficial time is faster than that of the gt350's "official" time... But, to drop the weight even more and bump the power... Wouldn't hurt, and it just gaps the competition even more...
Z28sr2fast4yall is offline   Reply With Quote
Old 09-15-2015, 02:23 PM   #136
Z28sr2fast4yall
I think this is the z28... There's a lot of characteristics that belong to a track car vs a street car... The zl1 would be suited for the hellcat challenge... But, this I think is the z28...
Old 09-15-2015, 02:26 PM   #137
KMPrenger
KMPrenger's Avatar
I just can't imagine at all, why in the word they would stamp any kind of performance data on the side of the car. Maybe they did, but is seems almost silly to me to speculate what kind of performance numbers it could mean. (still fun to speculate though lol)
My opinion....I can't see GM producing a hi-po LT1 variant making 500+ HP solely for the Camaro. It would have to go in other vehicles as well...otherwise the cost is going to be huge.
So that's why I think this car is likely the next Z/28, with an LT4 engine. Z/28 will soak up the ZL1, just like Z06 has soaked up ZR1.
Old 09-15-2015, 02:27 PM   #138
hotlap
hotlap's Avatar
This^^^ the Z/28 is starting out lighter so it doesn't need a big HP jump to move to the next level like the Z06 did. That aborted big displacement NA Z06 engine would work fine for a Z/28
Ronald Reagan -
Old 09-15-2015, 02:27 PM   #139
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
It has a tow hook; looks like a roll cage inside; VERY wide low-profile Goodyear tires all the way around; the Z/28 flow tie; there's no mistaking that front is intended to let this car breathe. I'm guessing this is the Z/28 development car.
Attachment 744300
I'll guess that:
VID = Vehicle I.D.
PWR<6.46 = Power to Weight Ratio. Which, if this is a Z/28 they've probably taken 100 lbs out of it compared to the SS which is 3,685 lbs so figure 3,585 lbs. Divide 3,585 by 6.46 you get 555 hp.
0/100<4.0 = 0-100kph in less than 4 seconds?
LG>1.0X = Lateral Grip greater than 1.0
#HPSIX = High Performance Sixth Gen.
So guess what boys and girls...they don't consider the SS you're buying to be high performance!! ROFL This bodes very well for the Z/28 and should cause much heartburn at other companies and forums.
Hi Doc, if you look at all the pics you can see the tire size in the front is smaller this in the past was to the LT/LS/SS and last the ZL1 not the Z/28 or the 1LE if GM stays true to form, this is a ZL1 car, there are more clues, what looks like a heat exchanger at the low part of the grill, now for the numbers.
If this is the Zl1 (and i think it is)with the pic you posted to get to the power of less then 6.46 that car will need to have 600+ HP here is how.
Car is going to come in at 3900LB, so to get better then the 6.46 you need to have more then 600HP, that only gets you to 6.5 why do i think its going to be that heavy, 1SS comes in at 3685lb add mag ride, add 6 piston up front, add heavy rear diff and all the cooling needed, and we will be luck to stay at 3900lb and if we are say 50lb more more hp needed to keep the 6.46 right.
so with that look to see 640hp and you will be at 6.17 now that will be a fast car, better pic for you all.
2SSRS@Gen5diy is offline   Reply With Quote
Old 09-15-2015, 02:27 PM   #140
SSNYSTR
SSNYSTR's Avatar
Drives: Black 2011 Camaro 2SS
No one else noticed the flowtie? I'd agree it's another track Z28
SSNYSTR is offline   Reply With Quote
