12-24-2018, 08:57 AM | #127 | |
www.jannettyracing.com
12-24-2018, 09:02 AM | #128 | |
The delta gains should be the same but you will start as a lower number in my experience 540-550 on 93 Absolutely please feel free to stop in any time and I am always at limerock and Palmer with the BMW club HPDE events. Aside from power mods we do chassis scaling, alignments, suspension, brakes, wheels tires etc. We can really dial your car in for you. Ted.
12-24-2018, 09:03 AM | #129 | |
Drives: 2017 Camaro ZL1 Join Date: Aug 2018
"Too much timing from the tune, causing detonation and heat to build in the cylinder walls, taking out the piston rings and causing major oil consumption." This is just an example of an excuse the dealership could use to get out of replacing a new motor under warranty. Whether or not it's true, you'd still have an uphill battle to prove otherwise. If you don't have the funds to fix what's broken then I'd suggest no more than minor bolt-ons. (exhaust or intake). |
12-24-2018, 02:36 PM | #130 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
Didn't realize they were so different, after doing more research and thinking about the impact those differences would make, your response makes sense
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
12-29-2018, 07:34 PM | #131 |
Drives: ZL1/335i Join Date: Apr 2014
Ted, could you give us more data on the maximum power gains with the headers? There look to be some big gains at say 6500 rpm as the manifold curve noses over. My guess was 40 whp up top, but that was just from trying to read the graph. Thanks
12-29-2018, 10:24 PM | #132 | |
Drives: Grandad's C2 L89 Join Date: May 2017
Ted; My thoughts are to upgrade intake and exhaust in stages to get a few more miles out of my warranty, then JRE tune via HPtuners, with bolt on's in place. If I can get 40-50 wHP and TQ on race gas without spinning the blower faster, E85 or methanol, I'm extremely interested. Thanks in advance for your thoughts.
2018 ZL1 1LE sw/PDR
12-30-2018, 04:25 AM | #133 | |
How much, if at all, do you think the cold weather and race fuel effected the throttle closure on the baseline runs?
12-31-2018, 08:52 AM | #134 | |
Ted
12-31-2018, 08:55 AM | #135 | |
Add a Rotofab and you are there but the tuning is what really unleashes the power as the factory calibration did leave a lot on the table which is out of character for GM. Ted
12-31-2018, 08:57 AM | #136 | |
Ted
12-31-2018, 09:26 AM | #137 | |
Drives: 18 ZL1 A10 Join Date: Nov 2008
=Bobby
ZL1::J-E-T-S JETS JETS JETS |
12-31-2018, 09:34 PM | #138 |
So I assume this wouldn’t matter as much for an auto like the A10 since it would shift exactly at 6500rpm and would shift faster?
01-01-2019, 09:33 AM | #139 |
I need to ask a real ignorant question Ted.
So if I did all the bolt ons as you did and had the car tuned on 93, would I have to install another tune to take advantage of just changing over to 100 octane fuel or would the system adjust on the fly? I couldn’t afford 100 octane everyday, but have access at the road course pumps. Thanks
2018 ZL1 - Garnet Red, NO Sunroof, A10, PDR, Carbon hood insert = Perfect
01-01-2019, 09:45 AM | #140 | |
