04-27-2024, 09:42 PM | #1 |
Drives: 2023 ZL1 1LE Join Date: May 2018
Check engine light after exhaust install..
I just installed a GT Haus exhaust. 150 mi. Later I get a check engine light. Has anyone run into this before? Car only has 5700 mi on it.
2023 BMW X4M Competition (Downpipes, Midpipes, Intake, Exhaust, Tune)
2023 ZL1 1LE BC Forged KXO5, 325/345 Toyo R888R, KPMF Satin Pearl Wrap, GT Haus Exhaust, Girodisc/Carbotech AX6, Race louvers. - Incoming Harrop 2650, Cam etc.. |
04-27-2024, 09:46 PM | #2 |
what code?
04-27-2024, 10:03 PM | #3 |
Is there a way to pull the code off the driver information center?
04-28-2024, 12:22 AM | #4 |
2020 Shadow Gray 2SS
I don't think so, you'll need an OBD-II reader, they are cheap on Amazon, small plug in dongle that hooks to your phone... $30-$50, WELL worth the investment...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
04-29-2024, 05:25 AM | #5 |
no...that trick only works on Corvettes (a C5 can).
04-29-2024, 05:26 AM | #6 |
Probably P0300 like I just had
04-29-2024, 07:18 AM | #7 |
If it's a cat back, you probably have a small leak at the connection pipes.
2016 NFG 1SS A8
04-29-2024, 09:51 AM | #8 |
I found a video on Youtube and ordered the Veepeak which should be here today. Once I find a 10 year old kid to show me how to use it, I will get the code smiling1:
04-29-2024, 10:46 PM | #9 |
The Code is showing as P0420 (Catalyst system efficiency below threshold Bank 1)
I have changed out more cat backs than I can count, I have never seen this before. Any ideas?
04-30-2024, 06:00 AM | #10 |
Drives: 2023 ZL1 - Modified All Bolt On's Join Date: Dec 2022
I had something similar after installing my long tube headers on my new ZL1. I had accidently sliced one of the wires on the wiring harness that extended to the O2 sensor. I would double check all wiring and make sure all connections are tight. Even though you might not have working around that area. I would double check all wiring connections for the O2 sensors.
2023 ZL1 Auto - CSP 2" Long Tubes by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port | Griptech 2.3" Upper | ATI Super Damper w/9.45" (18%) Lower | TooHigh PSI Port Injection w/Siemens 875cc Injectors | Brisk RR14S Plugs | Granatelli Malevolent Coil Packs | Katech Low Profile Billet Valve Covers | Katech Duel Fuel Pump System | MightyMouse Wild 1000HP CC | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 285/305 | Katech Tuned | Straight E85 = 784rwhp / 678rwtq @ 19psi
04-30-2024, 07:48 AM | #11 |
You have a leak around the connection by the secondary cat. All you have to do is google code p0420 and 430, you will see how common this is on this platform. A tiny pin hole leak will trigger it.
2016 NFG 1SS A8
04-30-2024, 09:28 AM | #12 |
There are no secondary cats, this system removes them. I will take it back to the shop and have them adjust to make sure there are no leaks.
04-30-2024, 05:07 PM | #13 |
04-30-2024, 09:26 PM | #14 |
snall exhaust leak will cause that code...start the car on ramps and feel for a leak at the front connection pipe area where the slip connection is located
Thread Tools | |
