01-29-2024, 07:24 PM | #1 |
Drives: 2024 ZL1 M6, 1978 Beechcraft Baron Join Date: Jun 2018
Parking brake doesn't automatically release
It doesn't happen every time, but about 1 out of 3 times the parking brake refuses to release when I let the clutch out. Never happened on my M6 RS.
Has anyone else ever experienced this? If so what was the fix action? |
01-29-2024, 07:52 PM | #2 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
One thing I notice on my 24SS1LE is after I release the brake and I start out of the garage they pop like they are letting loose. Happens whenever it sits overnight not so much on short trips.
01-29-2024, 10:18 PM | #3 |
Drives: People crazy with my sexiness Join Date: Jun 2023
It may be electric but there still may be components that need lubrication or adjustment in the mechanism.
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023 2024 2SS 6MT coupe Sharkskin/Light gray Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers Gray painted split spoke wheels Illuminated footwells/illuminated bowtie |
01-30-2024, 07:30 AM | #4 |
Drives: 2018 Hyper Blue Metallic SS 1le Join Date: Oct 2023
hold up, wait a minute...I just bought my 18 1le in October, so you're telling me, I dont have to actually fiddle with the button, when I'm ready to drive off?
01-30-2024, 08:19 AM | #5 |
Yes it has an automatic release. If you have an automatic transmission it releases automatically when shifted into drive or reverse. If you have a manual it releases automatically as you lift off the clutch and accelerate in gear.
01-30-2024, 09:02 AM | #6 | |
Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
I noticed the auto brake off feature, but I dunno, probably just me, but I prefer using the damn button |
01-30-2024, 10:00 AM | #7 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Mine always feels weird, sometimes it pops out and sometimes I feel like it's stuck and doesnt let me move(I never try to push through it though). I have a Manual. I normally always unlock manually with the button now.
01-30-2024, 10:36 AM | #8 | |
SS with the brembros has cable style parking brake system. I believe the stock RS has the screw-type piston system. |
01-30-2024, 02:17 PM | #9 |
Got mine!
Drives: 2021 LT1 RS - Orange Crush Join Date: Mar 2011
I have a '21 LT1 Auto, when the parking brake is engaged and I'm ready to go, I just give a little gas and she breaks free. It does not release when putting into drive or reverse as someone said in a previous post, but releases when giving some gas after putting into drive or reverse.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
01-30-2024, 02:45 PM | #10 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Have you been having wetter than usual weather? As we know brake discs will show a little rust after sitting for even a short while when put up wet. If the rear brake pads are pressed up against it at that time, they may be a little reluctant to let go. I think the "pop" some folks are experiencing is normal.
I know on my manual if I forget to release the brake, the car will "remind" me it's still set with reluctance to pull away when I'm letting out the clutch. If I start to go a second time without releasing, she'll go without issue (self-release), but that's something I try not to do cuz I'm conscientious (anal) about clutch/drivetrain wear and try not to use 1 more RPM than necessary to pull away smoothly without stalling. Been driving manuals for 50 years and I still don't want to look like an amateur! OP maybe your clutch sensitivity is just getting better? But if she just won't let go, I'd take the time to release and take her to the doctor- I mean dealer. |
01-30-2024, 03:38 PM | #11 |
Drives: '23 2SS RSblue 6MT, sold '19 ND2 Join Date: Dec 2021
It will release on on clutch out and throttle, but I dont like the feeling as there is a bit of delay from the release and it seems like the car will stall. I always manually disengage the e-brake so its routine.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 |
01-30-2024, 05:17 PM | #12 |
Drives: 2021 3LT RS A10 Join Date: Nov 2021
I was today years old when I learned this, thanks
01-30-2024, 08:50 PM | #13 | |
01-31-2024, 09:04 AM | #14 |
I think you have the cable release system. I think a good start would be to put this on a lift, or back it up on ramps (chock the front wheels). Then watch and listen to the linkage as someone engages and disengages the brake. You may have something binding, which I think is most likely. if not the cable, then maybe in one of the rear hubs. Hopefully you can tell which one to pull.
Thread Tools | |
