![]() Drives: 2023 1SS 6 speed Join Date: Aug 2023
dealer mounted my rear lic plate crooked.
leaving it up to some guy working flat rate to drill the proper dimples was not a good Idea by GM. its off enough that people can tell its crooked. now.. to clearance my lic plate mounting holes, or.. try to make new holes.
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
Well that would piss me off, I would just modify the plate
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
You got a pic?
![]() Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
My dealer was too scared to do it so I drilled the holes myself. I'm glad it went that way!
![]() Drives: 2024 ZL1 Join Date: Apr 2023
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
#7 |
![]() Drives: 2014 Buick Regal GS AWD Join Date: Jan 2008
Use the plate as a template. Leave one side in, put a level on the bottom of the plate, tape it and drill out the other hole. Use the higher of the two. That way when you drill out the other, it's covered. If you use the lower one, there is a chance you might see the oblong hole. Good Luck. Sorry that happened.
#8 |
![]() ![]() ![]() Drives: People crazy with my sexiness Join Date: Jun 2023
Just tilt your head
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023 2024 2SS 6MT coupe Sharkskin/Light gray Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers Gray painted split spoke wheels Illuminated footwells/illuminated bowtie |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
My dealer put the screws in on my '22 crooked too. I had to drill out the license plate holes to get it level. You also may be able to redrill inside the holes in the bumper and move the center(s) slightly to fix the level.
#10 |
The bumper covers have dimples in them where the screws go. I wonder if some covers have a bit of core shift or whoever puts the screws in just isnt hitting the center of the dimples.
#11 |
they just didn't do it right. the old square inserts were fool proof.
#12 |
![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
The idiot who drilled mine out at the dealer shifted the holes to the right. There are very clear dimples on the back bumper. A 4th grader could drill them in the center. Tells you what kind of people get hired at dealers.
#13 |
The bumper covers are typically EPDM, which is basically polypropylene with a stiffener. A drilled hole should be an easy fix with a glue gun, as hot glue sticks are polypropylene. Give it a nice squirt so it bulges on both sides, then maybe flatten the one side with a piece of waxed paper. When it cools you can redrill it.
#14 |
or maybe plastic repair epoxy. I just elongated two of the screw holes on the plate. maybe 1/8th at least
| Thread Tools | |
