07-11-2023, 08:53 PM | #1 |
Question about boost
Hello folks,
Question about boost at elevation. Right now I'm in Wyoming and about 6300ft of elevation. The DA is anywhere from 8000-10000ft at times. I have a stock upper (2.50) and a lower 9.60" pulley. Also have a cam with 3.5* over lap and 2" headers. At sea level the car was seeing about 11-12 PSI. On my logs here I'm seeing about 5-6 PSI. I don't have any vacuum leaks. Could elevation and DA play that big of a role in how much boost I'm making? |
07-11-2023, 11:00 PM | #2 | |
Drives: 2019 ZL1 Join Date: Mar 2019
And yes elevation kills boost as well as heat. Move back to sea level
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
07-12-2023, 07:57 AM | #3 | |
At 6300 ft., on a nice day you'll see about 11.7 psia barometric pressure (SAE) in your HPT PID data versus 14.7 at 0 ft. And your blower will make about half as much boost at 6300 because it is less efficient. However, you can change to a smaller blower pulley to regain some of the lost boost. I'm not certain as to how much smaller. At altitude, you need to spin the blower faster and run more spark advance and octane. You'll see the NHRA guys do it this week at Bandimere. My peak hp was at 6183 on the dyno, so I dropped my shift points from 6900 to 6500. I use a small upper (2.75) to increase hp and torque down low and to reach 6500 quicker (but with worse traction), resulting in lower engine and blower rpm. I'm thinking of trying a 2.625.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. Last edited by JSH; 07-12-2023 at 03:01 PM. |
07-12-2023, 08:53 AM | #4 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Someone needs to invent a variable pulley
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
07-13-2023, 06:26 AM | #5 |
Barometric pressure is about 11.9. I just didn’t know that I would lose half my boost lol
07-13-2023, 10:16 AM | #6 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
The altitude and lower boost makes a huge difference. I made 580ish uncorrected in Denver on e70, moved to the east coast at sea level, retuned car and made 740 uncorrected on e50.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
07-13-2023, 11:37 AM | #7 |
If you don't mind me asking, what was your dragy time when you were in Denver and when you moved to the east coast?
07-13-2023, 12:04 PM | #8 |
I don’t have Dragy. The car is completely different animal than it was in Denver. Night and day difference.
07-13-2023, 12:06 PM | #9 |
Would you be able to tell me how much boost you were pushing in Denver as opposed to the east coast?
07-14-2023, 09:32 AM | #10 | |
Here’s a thread on it. https://www.camaro6.com/forums/showthread.php?t=611140
07-14-2023, 10:37 AM | #11 | |
07-14-2023, 10:49 AM | #12 |
Yeah it sounds like you have something going on there. The first things I would check are to make sure you have all the air out of the coolant loop and then make sure you have the supercharger bypass valve adjusted correctly, as it could be causing it to bleed off boost if adjusted incorrectly. A search on here should quickly find the instructions.
07-14-2023, 10:53 AM | #13 | |
Post a log.
07-14-2023, 11:32 AM | #14 | |
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
Thread Tools | |
