Old 03-01-2021, 06:48 PM   #1
fedupdave42169
Drives: 2017 Camaro as convertible
Radar detector mounting.
I have 2021 zl1 with the rear view mirror screen, can you still mount radar below mirror and hard wire into it, I was able to with my 2017ss.
fedupdave42169 is offline   Reply With Quote
Old 03-01-2021, 07:35 PM   #2
EvilZL
EvilZL's Avatar
Drives: 2018 Camaro ZL1
Check out this thread, this should help ya
https://www.camaro6.com/forums/showt...ght=blendmount
EvilZL is offline   Reply With Quote
Old 03-02-2021, 03:26 AM   #3
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
I need to find a place and way to wire up a radar detector in a place that is not visible....
Bangkok_ZL1 is offline   Reply With Quote
Old 03-02-2021, 06:34 AM   #4
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Some say just jam 2 pins in the existing connector but I'm afraid of fire so I used this. It's a pigtail that plugs into a overhead console connector that uses the circuit for the pass airbag light. You can also get it with 2 extra wires for a dash cam.
https://www.gen5diy.com/products/19-...a6fc91d7&_ss=r
Old 03-02-2021, 07:56 AM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
Yes, I mounted the Smartcord on the right-side of the console and ran the power cord to the BCM power lead and the detector cable under the carpet, up the pillar and under the headliner over to the right-side of the detector. The detector is mounted immediately left of the camera.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 03-02-2021, 09:06 AM   #6
Bangkok_ZL1
Yeah, The flash went off and I was filmed doing about 220 in a 90...... That's about 5000 Baht (150 bucks) ticket. Fortunately, my car still isn't registered. I still have the temp plates, so they couldn't trace me.... I didn't know this at the time. But I need to have a detector for all the stationary mounted cameras on the toll road. Soon, I'll have my normal plate and there won't be anymore freebees.
Old 03-02-2021, 11:03 AM   #7
musclesbmf
Drives: 2020 ZL1 1LE A10
I have a 2020 and I could not get anything to work pinning into the back of the mirror. The connectors look totally different from the 2018 or whatever example I saw using the back of the mirror.
I found this online and this is the route I'm going to go:
Mark
musclesbmf is offline   Reply With Quote
Old 03-02-2021, 11:12 AM   #8
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
I couldn’t get anything to work in the overhead on my 2019. Got so frustrated that I ended hiding a wire all the way from the center console charge port to my detector at the top of the windshield.
CW3SF is offline   Reply With Quote
Old 03-02-2021, 11:24 AM   #9
Oopsie daisy
Are radar detectors legal in Thailand, though? Also, your car doesn't exactly blend in, and if they went to the trouble of deploying a camera system, I don't understand how they couldn't trace it.
Old 03-02-2021, 06:22 PM   #10
Bangkok_ZL1
Oopsie daisy
You know, I would think so. This is a government that will toss you in the clink for verbally busting out the king's behavior (true and false). However, I do see them on Lazada (an online buying platform). And they have the good ones, cobra, uniden's R1. They are 500+ bucks. But I fear they'll let you buy, but when it's time to receive it, it has been tampered or you won't get it. Better to bring it from the states. Still, if I got a working one here, I'd try to hide it in a place that's not visible, when you have to stop at a check point and the police look in the car. One cannot play the cat and mouse games here that one can play in the states. There is no "due process" and the constitution for protection.
Old 03-02-2021, 06:39 PM   #11
You know, I wouldn't think so. This is a government that will toss you in the clink for verbally busting out the king's behavior (true and false). However, I do see them on Lazada (an online buying platform). And they have the good ones, cobra, uniden's R1. They are 500+ bucks. But I fear they'll let you buy, but when it's time to receive it, it has been tampered or you won't get it. Better to bring it from the states. Still, if I got a working one here, I'd try to hide it in a place that's not visible, when you have to stop at a check point and the police look in the car. One cannot play the cat and mouse games here that one can play in the states. There is no "due process" and the constitution for protection.
I see, not much different than where I'm originally from, the police could stop you for no reason whatsoever (it's called "routine compliance check"), the burden of proof was on you, and if you decided to go to court, it's basically your word against theirs. Likely still the same way today.
So how about an integrated radar detector? Those are the only truly (nearly) invisible solutions. No matter where you install a portable one like the R1/R3 or the Escort, it's going to be very visible, or useless because it won't have enough range if you hide it behind any panel or component... An integrated one is much more expensive, but I have the impression you would consider it nevertheless.
Old 03-02-2021, 10:16 PM   #12
JSH
JSH's Avatar
Drives: '20 ZLE
You just splice into the Accessories lead on the BCM for power. Detector powers up with the accessories.
2020 ZL1LE A10.
Old 03-02-2021, 11:56 PM   #13
Bangkok_ZL1
Please explain more about this. Give me some examples please. Then I’ll use google to research. I’d google first, but with my luck, I’d research the wrong style and not know it, LOL
Old 03-03-2021, 06:13 AM   #14
ZLE dude
Drives: '18 ZL1 1LE
A lot of high end vehicles install these K40 systems. They have sensors installed in the front grill and rear of the car and have a small display in the dash. I actually ran across a ZL1 in their gallery. These aren't cheap, but they are probably the most concealed system you can get for radar.
https://k40.com/installation_gallery...n-performance/
If they use laser where you live, AL Priority make some pretty nice concealed laser detector jamming equipment also. I have a few friends that have these systems. Obviously, I'm not sure you'd have any installers over in Thailand.
https://www.alpriorityusa.com/
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
