![]() Drives: Camaro ss, Cadillac, Kawasaki ZRX, Join Date: Apr 2016
TS & P chop monster cam?
There was an article in August road & track about the Texas Speed & Performance chop monster cam adding 125 hp to a stock 6L LQ4 motor , with headers. Has anyone here installed this cam in there LT1?
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I am pretty sure you're not going to get a LS cam to work in a LT.
TSP told me they were going to redesign their 'VVT" cam series for the LT's. A lot of the shops have given up on trying to make cams work with the cam phaser and he said it would probably be a long time before it happened after they did their Hemi cams. I am not fully convinced their cams are as optimized as they claim, but maybe given their high durations and lifts, did design their VVT cams with that in mind and when they come out with their new line maybe the specs will seem more tame? |
#3 | |
#4 | |
![]() Drives: 2017 SS 6sp Join Date: Jun 2014
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Yes the lockout works but the valve events of the VVT cams are not ideal for deleting VVT.
2016 NFG 1SS A8
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
A cam alone is not going to add 125 HP either at the crank or at the rear wheels. Not even with a tune.
2018 Camaro ZL1 1LE NFG; ARH 2 headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
#7 |
gen 5 lt1 vt-3cam w/+32% fuel lobe 235/239 .645/.635 116 lsa ported heads,1-7/8 headers 0degree phaser limiter DOD delete kit this set up tuned to pull power from 3000 rpm 535hp at wheels good driveability this was done on a 2017 ss 6sp.
#8 |
Can anyone report how good their "VVT" cam is with VVT still enabled? I am really curious how my 228/236 VVT Stage1/2 would perform with at least a 10 degree lockout, I really would want to know if it would improve idle quality any too. With my cam anything below 1000 rpm starts to get rough. Idle isn't too bad but it does buck and surge at a rolling idle which gets really annoying, it will also surge and buck right when you apply a little throttle from a stop until it gets revved up past 1000 rpms. If I could do it over I probably wouldn't have gone with a cam this big, especially if I knew how little power it gained.
#9 |
My first cam had a 22 degree limiter TSP, no tuner would fool with it.
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 6th gen Join Date: Aug 2013
Mechanically, different lifter preload changes the idle. I had an adjustable drivetrain once with drop in hydraulic lifters and spent a lot time playing with different preload. you could get more or less chop and idle vacuum by moving from one end of acceptable preload spectrum to the other.
22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28 dragpack - 11.68@122
16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) |
#11 |
We've installed a lot of their VVT cams and there is some power in advancing the VVT some on the smaller cams. The stage 3 and the El-C7 they recommend the full lock out. I don't think these cams are really meant to be messed with. The stage 1, the SV and even the stage 2 like a little advance at wot.
#12 |
So does the lockout set it retarded a certain amount of degrees? Stock cam is advanced when at 0* and retards 10* up top at wot
#13 |
lock out is set to 0 degrees.
2016 NFG 1SS A8
#14 |
If you retain vvt with an aftermarket cam, you’re trying not to overpower the cam phaser right?
Wouldn’t you want to run beehives? Also, wouldn’t a bigger fuel lobe significantly increase load on the phaser? I’d like a cam but really want a working vvt and beehives. Just a first crack, something like a custom cam motion 218/226 114+7 Something that will come on early and fully run out of steam by 6800rpm shifting 6650rpm The vvt set to 0* would get me down to a 107icl, does that sound right? I guess I’m gonna start looking for ptv limits
16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) Last edited by 6spdhyperblue; 08-09-2020 at 02:28 PM. |
Thread Tools | |
