07-21-2020, 08:04 PM | #1 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Zl1 headers
So im looking into getting some headers and xpipe and use my npp suitcase.
The shop that I would like to use recommended a kooks system which is headers with green cats and there xpipe. The problem is its expensive $3400. So I was thinking using maybe the new CSP headers and figure out what x-pipe I can use. Has anyone tried the CSP and hows the fit and finish? What are members running with there stock suitcase? |
07-21-2020, 08:23 PM | #2 |
Kooks and ARH are great, but take a look at Dynatech. American made and full stainless construction like the other 2, but found the pricing to be much more reasonable.
07-21-2020, 08:31 PM | #3 |
07-21-2020, 08:33 PM | #4 | |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I have kooks 2" ceramic coated catless. Im pretty sure I paid $1500 for them with the catless pipes. Are they charging you the $3400 for install and tuning? If so then add a few more things to make the tuning worth it. If the 3400 is for the part and install that is a bit pricey. If the 3400 is just for the parts. Run, run away, run away fast. They are robbing you. |
07-21-2020, 08:42 PM | #5 | |
That's just headers,green cat,xpipe Kooks 22602600 Kooks 22605381 |
07-21-2020, 08:51 PM | #6 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Whoever that performance shop is......run! No way, headers and x-pipe should cost you $3400.
07-21-2020, 08:56 PM | #7 |
Drives: 2018 hyper blue ZL1 1LE Join Date: Nov 2018
The green cats are expensive. Nice to cut down on the raw gas smell. I had vengeance install the coated headers and green cats. A little while later I brought the car to a local fab shop with a texas speed x pipe. He worked his magic and tucked the x pipe up into the tunnel, covered the tunnel with heat reflective lining, etc. Using the Texas speed as a starting point saved time for him and now I have a custom x pipe that's nice and tucked like stock. It might be worth a look for you to try the same formula.
07-21-2020, 09:09 PM | #8 |
07-21-2020, 09:14 PM | #9 |
Drives: 2018 Zl1 A10 Join Date: Jun 2020
I paid $1800 for my ARH (Headers,cats,Xpipe)
$3400 seems excessive! |
07-21-2020, 09:22 PM | #10 |
07-21-2020, 09:36 PM | #11 | |
If you want a great set of headers with a full Xpipe check out the Stainless Works headers. We have some great deals running for forum members at all times and the quality is second to none. 2016+ V8 2" LONG TUBE HEADERS - HIGH FLOW CATS 2016+ V8 2" LONG TUBE HEADERS - OFF ROAD The full Xpipe is a great idea. We consistently make more power on these LT4 cars when we remove the crushed pipe in front of the muffler. |
07-21-2020, 09:43 PM | #12 | |
The ARH headers went in easier than the stock manifolds. Probably the easiest headers install I’ve ever done. I did get mine on sale a year ago, $3400 stilll seems like a lot |
07-21-2020, 10:38 PM | #13 | |
Do they work with the npp suitcase? |
07-22-2020, 08:30 AM | #14 |
Anyone running the stainless works headers with x-pipe to suitcase?
Thread Tools | |
