09-23-2019, 05:46 PM | #1 |
Drives: 2018 Camaro 2ss Join Date: Sep 2019
Corsa Double Xpipe into stock NPP
Just Purchased Corsa xpipe (14788), only want a little bit more sound from NPP, I know I have to cut npp. so will the xpipe fit to the stock suitcase?
Is anyone going this setup would like to share? |
09-23-2019, 05:47 PM | #2 |
Drives: 2018 Camaro SS Join Date: Feb 2018
From what I've read this will fit no problem.
09-23-2019, 05:49 PM | #3 |
09-23-2019, 05:53 PM | #4 |
Wait, your the dude with the a8 with that ticking problem right? I may be wrong, but i thought autos need afm valves on the mid pipes. Not sure what deleting it, might throw a code or sound like crap in v4 mode. Will let someone who knows the autos better chime in.
09-23-2019, 05:56 PM | #5 | |
I read lots of AFM valves. probable will plug it and zip tie somewhere under the car |
09-23-2019, 07:04 PM | #6 |
Drives: 2017 1ss 1le Join Date: Sep 2015
does this corsa x pipe remove the secondary cats?
09-23-2019, 07:37 PM | #7 |
It does, appleman.
09-24-2019, 02:02 PM | #8 |
Drives: 1SS Hyper Blue Metallic, MRC, NPP Join Date: Apr 2016
Blackbee: If you wouldn't mind posting up a sound clip once you have installed the X Pipe because I'm seriously looking at the same set up. Let us know if there is any drone too.
09-24-2019, 06:09 PM | #9 |
Sure. I will record and post. But I live in ca. Can’t ship directly. Got wait for a while
09-24-2019, 06:28 PM | #10 |
It does not look like it's going to bolt right up. It's designed to fit the Corsa Axle back. Look at the side towards rear of the car and you will notice the reduced diameter ends. That is so it will slip right inside the Corsa axle back and clamp it with a band clamp. With the stock NPP muffler the ends will but, so it will need to be welded.
2016 NFG 1SS A8
09-24-2019, 07:32 PM | #11 | |
09-24-2019, 07:49 PM | #12 |
I'll try once more...The X pipe is reduced on the ends which makes it the same diameter as the stock NPP pipes so the Corsa axle back will slip on to the X pipe.
So no The X pipe will not slip onto the NPP pipes. You will likely need the hooker black heart crush pipe deletes to use as adapters or take it an exhaust shop and have it welded.
2016 NFG 1SS A8
09-24-2019, 09:44 PM | #13 | |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
Corsa
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
09-24-2019, 09:56 PM | #14 |
Ok so it comes with the sleeve adapters if using the stock NPP muffler. Good deal!
2016 NFG 1SS A8
Thread Tools | |
