03-01-2019, 09:29 AM | #1 |
Drives: Camaro Join Date: Feb 2019
Camaro rs 2010 v6 long tube headers
Hi, I own Camaro 2010 rs v6. I replaced the final silencers on Magnaflow bullets and mounted the x-pipe. I would like to get a better sound yet. I wonder about the long tube headers, is there a difference between bbk, obx or ebay collectors for $ 180 will work the same?
https://www.ebay.com/itm/FOR-10-11-C...4-686492e1fb6e The sound of my car: https://youtu.be/U9gr1TAxKmc |
03-02-2019, 02:19 AM | #2 |
Drives: Camaro V6 Join Date: Oct 2016
I wish the LFX could have headers. Makes me wonder if the exhaust ports in the heads can be ported out to give better flow like a header would.
03-02-2019, 11:29 AM | #3 |
Drives: 2010 rs 2lt Join Date: Aug 2012
I have the BBK Ceramic Longtubes with highflow cats ,sound great, had them on now for 3 years no problems
03-03-2019, 02:22 AM | #4 |
I wonder if long tube headers ebay will sound just as well with the original catalysts
03-03-2019, 10:41 PM | #5 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
The cost would not be worth any benefit. You'd have to pull the heads off and have them sent off to Extrude Hone. For that reason alone, the LFX and every other single port engine is junk in my book.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
03-04-2019, 10:07 AM | #6 | |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
they dont make much in performance parts other and its just more difficult to find someone that works on them for that same reason.
Bone Stock |
03-07-2019, 10:26 AM | #7 |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
Same here (i gutted my cats for the SC) but love my BBK's.
03-08-2019, 02:09 PM | #8 |
What could I do to change the drone effect? I have x pipe installed.
03-08-2019, 03:14 PM | #9 |
Drives: 2012 Camaro LS V6 Join Date: Aug 2016
If the resonated X-Pipe doesn't do enough, you probably J-pipes (aka Helmholtz resonators), for which you will need to calculate the length you will need unique to your car. There are several good forum posts here to follow.
03-08-2019, 04:41 PM | #10 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Magnaflow bullet mufflers are super drony in my experience. Try magnaflow mufflers if you want to keep the sound down.
Edit: Your car also sounds higher pitched than mine, but there's multiple factors to that. Do you have a regular X pipe, or an X muffler in the center? 11386 x muffler specifically
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
03-09-2019, 12:38 AM | #11 |
I usually have X in place of H. Auto sounds good after 2.500, earlier there is a buzz. I wonder if when mounts long tube headers, CAI can be improved?
03-09-2019, 08:21 AM | #12 |
Try the Magnaflow 11386 in place of that regular X. You maintain an x but it'll get the drone and rasp under control. And it'll sound a little deeper.
03-09-2019, 02:53 PM | #13 |
First, install long tube headers, see what will change. I wonder if Magnaflow bullets will give as a central silencer. To buy some sensible final muffler. I wonder what the effect will be?
03-09-2019, 06:16 PM | #14 |
Adding long tubes will make it wicked loud and raspy.
Thread Tools | |
