![]() Drives: N/A Join Date: Nov 2015
Time between layers
Good evening peeps, I had a question for those of you following the BF polish -> wet diamond -> crystal seal approach. How long do you usually wait before moving on to the next step, and how do you prep before starting the next step?
![]() Drives: 2016 Summit White 2SS (Auto) Loaded Join Date: Jul 2016
Here is what I do, wash car with Dawn soap and then clay using the suds for lubricantion then re soap the panels and rinse - dry car- polish car, I wipe down panels with alcohol/ water spray then apply CS. Also I will say using Glens line
![]() Drives: 2LT, Blue Velvet, Kalahari, Convert Join Date: Feb 2016
I found this on a Corvette forum. It appears to be true based upon my experience using crystal seal.
BLACKFIRE Crystal Seal Dry Time: 1-15 minutes Cure Time: 15 minutes-4 hours Recommendations: Wait 4-5 hours for additional layers, particularly in cool or damp climates. In Use: Crystal Seal begins cross linking on contact and in most cases is fully cured with in 1 hour unless you live in an extremely cool or wet climate. By the way, Blackfire Wet Diamond Polymer Spray, when used as a spray detailer over crystal seal, really brings out the depth and shine.
2LT, RS, V6, A8, Vert, Blue Velvet, Kalahari, Split Silver rims, Convenience & Technology pkgs
#4 | |
How about the wait between polish and seal? I think I read 8 to overnight somewhere. If you wait that long, I'm guessing just the water and alcohol solution to prep for the seal? |
Here is a quote from the same Corvette forum:
BLACKFIRE Total Polish & Seal Dry Time: N/A, work into the paint until nearly clear and remove immediately. Cure Time: 15 minutes-2 hours Recommendations: Wait 2 hours for additional topping, particularly in cool or damp climates. In Use: If applying Total Polish & Seal by machine, the machine agitation of the product (or vigorous hand application) greatly accelerates the cure time. You can remove Total Polish & Seal with Wet Diamond Polymer Spray to increase protection instantly.
#6 | |
![]() Drives: 2017 2SS 50th 2012 TFE RS 2LT Join Date: Oct 2016
Thread Tools | |
